Headlights after lift
Discussion in '5th Gen 4Runners (2010-2024)' started by morfdq, Jun 3, 2023.
  1. Jun 3, 2023 at 6:26 PM
    morfdq [OP] New Member
    Just did an Eibach Pro 2 lift on my 22 4 Runner. It lifted the front approximately 3 and the rear 1 inch. Ever since I’ve noticed people flashing their lights at me when I have my headlights on. Am I supposed to adjust the headlights as well? Even with the lift I know there are F150s that are still higher than mine. Thank you
  2. Jun 3, 2023 at 6:36 PM
    Patwashere
    Patwashere New Member
    ID - Idaho
    yes adjust them. Don't be "that guy"
    kolter45, Old Tanker and grizzlypath like this.
  3. Jun 3, 2023 at 6:44 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    a few goodies
    Correct, after I did my lift / level, I got flashed a few times. The adjustment is easy, and the way the headlight cuts off at the top, it is easy to see the effect of the adjustment.
  4. Jun 3, 2023 at 6:57 PM
    rmiked
    rmiked New Member
    Fort Mill, SC
    I have not lifted my ORP but I would think raising the front more (3”) than the rear (1”) you have changed the angle by inclining the front aiming higher. If you lifted them the same (say 2” front and rear) then the angle stays the same but the elevation is 2” higher. I would think the angle change necessitates the adjustment more than if you raised front and rear the same?
  5. Jun 3, 2023 at 8:25 PM
    Thank you everyone
  6. Jun 3, 2023 at 8:53 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    As peeps said, ya it's part post lift that shops typically take care of
  7. Jun 3, 2023 at 9:07 PM
    4runningMan
    4runningMan New Member
    New Mexico
    That lift effectively just raised the front end 2 inches relative to the rear. That makes a huge difference in beam height at a distance.
  8. Jun 3, 2023 at 10:41 PM
    5six
    5six New Member
    55_4Runner
    GTA, Ontario, Canada
    2022 Black TRD ORP
    I put masking tape on my garage door where my low beam cut off was before lift. After lift just adjusted them to the same height. I think they’re too low (maybe originally like that from dealer), so now park a few feet in front of my wife’s car and adjust so it’s just below top of her dash.
  9. Jun 4, 2023 at 3:19 AM
    redneck pilot
    redneck pilot New Member
    DFW
    2023 4Runner TRD ORP
    Easy to adjust. Find a flat surface by a flat wall. Position the vehicle 25’ from the wall. Measure 3’ up from the ground on the wall, apply a line of painters tape at 3’ and as wide as the vehicle. Adjust the low beams until the top of the beam is at your 3’ tape line. Finished.
  10. Jun 4, 2023 at 7:30 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Falken Wildpeak 265/70R/17 load E
    It's not the height of the lights
    With diagrams - https://www.to4runner.net/adjustment-1409.html
    I wish this were in the owner's manual. I was looking for the adjustment screws when this topic came up.
    NorthernSailor likes this.
  11. Jun 4, 2023 at 8:01 AM
    Thank you thank you thank you. I was wondering what the correct height was
    redneck pilot[QUOTED] likes this.
  12. Jun 4, 2023 at 8:02 AM
    Thank you everyone. Much appreciated. I absolutely don’t want to be “that guy”.
  13. Jun 4, 2023 at 8:05 AM
    NorthernSailor
    NorthernSailor New Member
    Alberta
    2023 Black 40th Anniversary
    Elka 2.0's up front, Sherpa rack, WeBoost Overland cellular booster, Nokian Outpost rubber
    How I wish we had auto levelling headlights as an option. I had a Ford Transit in New Zealand that had a little roller switch on the dash to adjust the aim height of the headlights...put a bunch of stuff in the van, lower the lights. Unload the stuff, raise the lights back to the empty height.
    I generally have to aim my lights every month because it will be empty for a few weeks, then loaded for a trip, then pulling a boat, then empty again. But at least I don't get flashed all the time anymore, and it is actually fairly easy to adjust. My next plan is to figure out how many turns to adjust for my typical camping weight, trailer weight, etc. and see if its repeatable without actually doing the wall measuring thing.
  14. Jun 4, 2023 at 8:52 AM
    Wow. Thank you so much. I really appreciate it
  15. Jun 6, 2023 at 1:29 PM
    captainSteve
    captainSteve 23 Lunar Rock ORP
    Steve
    Toledo, Ohio
    2023 Lunar rock ORP
    Yep I tow my Seadoo often, got flashed alot the first time towing in the dark. now I keep a 8mm racketing wrench in the glove box and adjust the beams when I need too. simple 1 min adjustment
  16. Jun 6, 2023 at 1:31 PM
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    Its not the height, its the aim. lifting the front more than the rear effectively aims the headlights higher. Not sure how it affects how the TSS crap works.
  17. Jun 9, 2023 at 7:40 AM
    thanks everyone. Got them aligned last night. I appreciate the help
    2Toys and Steely123 like this.
  18. Aug 19, 2023 at 10:05 AM
    WATTS
    WATTS New Member
    I have a 23’ TRD Pro…. I can’t see shit at a distance with low beams. The hard cut off is so bad. Highs are fantastic… It’s gotta be the downward tilt of the front end right ? Just switched to Miromotos and it’s the same thing. It’s a brighter light and I love the look but damn, I guess I need a lift/balance kit now for front end ?
  19. Aug 19, 2023 at 10:26 AM
    kmeeg LionRunner
  20. Aug 19, 2023 at 11:33 AM
    Oakboro, N.C
    The rear of our local Food Lion grocery store near the loading docks had a perfect flat area with a smooth white wall to facilitate adjusting headlight height.
  21. Aug 19, 2023 at 11:42 AM
    My factory LED headlights on my 21
    were giving me the same problems since day one. On a dark road, the brightness in the fore ground and the sharp cut off made it seem like I was driving into a black hole. Yes, they are horribly adjusted from the factory. However, They can stand quite a bit of upward adjustment before you start pissing off other drivers.
    It’s easy to adjust them…but getting a lift to avoid messing with those pesky adjusters sounds perfectly reasonable as well :D;)
  22. Aug 19, 2023 at 12:44 PM
    WATTS
    WATTS New Member
  23. Aug 19, 2023 at 12:46 PM
    WATTS
    WATTS New Member
    Funny you should mention adjustment. The dealer adjusted them to the highest the could go. Soooo that is when I decided to switch them out and still the aftermarket do the same. And yes. It is like driving into a black hole. It’s scary. I’ll do a slight lift in front. See how that goes.
  24. Aug 19, 2023 at 3:29 PM
    That’s surprising. Did you verify that they’re actually as high as they go? Mine go high enough that the sharp cutoff starts to soften due to the reduced angle. And high enough to get the high beams flashed at me by every oncoming driver. Mine aren’t at max adjustment because these LEDs are quite painful to look at directly if you’re an oncoming driver.
  25. Aug 19, 2023 at 3:44 PM
    4runningMan
    New Mexico
    Get some diode dynamics SS3 Pro fogs. They help a lot. Just can’t run them in traffic due to glare (although they claim they’re ok to run in traffic, my experience tells me otherwise).
    Low beams + DD Pro fogs are better than high beam only imo.
  26. Aug 19, 2023 at 4:39 PM
    WATTS
    WATTS New Member
  27. Aug 19, 2023 at 4:40 PM
    WATTS
    WATTS New Member
    Yah. I verified. And if the aftermarket’s which are basically brand new everything, meaning the whole headlight is replaced, then that should have fixed it. But it didn’t … so basically the front end being too low is my issue in my opinion.
