Has anyone actually fixed the misaligned fuel door?
Discussion in '4th Gen 4Runners (2003-2009)' started by Stuck CAPS, Apr 26, 2017.
  1. Apr 26, 2017 at 3:50 PM
    Stuck CAPS
    Stuck CAPS [OP] Truck killer
    Alex
    2007 Nautical Blue Metallic Limited V6 4x4
    ARB Bumper, Some Stuff, Some Other Stuff, and some Stuff.
    My fuel door is misaligned. It'll pop open with the lever just fine, but opening it up, even when pulling on it to avoid scraping, I'll scrape it against the body. Is my only real option getting a new fuel door? Or has someone actually figured this out, so I can stop it from scraping, so I can just touch it up?
    keakar likes this.
  2. Apr 27, 2017 at 4:47 AM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    2007 4runner SR5 4WD
    Lol, how do we have the same issues. Still looking into what I can do to stop it. Wish the fuel door was attached with screws like my old Tacoma instead of rivets so I could remove it and modify it.
    keakar likes this.
  3. Apr 27, 2017 at 5:07 AM
    bahndrvr
    bahndrvr New Member
    Trevor
    Melbourne, Fl
    03 SR5 V8 4Runner
    2003 4Runner SR5 v8 - Temp Front: Top hat spacer 2.5" on Tacoma struts/springs Rear: TJM/King heavy extended Tacoma shocks 315 BFG AT KO2's (35's) Thrush Welded muffler and rear watermelon delete with turned exit K&N drop in, and extra filter delete Strengthened/Welded passenger side front diff mount Front diff drop - due to the top hat spacer and massive droop.... Scion headunit CB Other stuff done, 6th 4Runner:)
    Didn't realize this was a wide-spread issue, would be as easy as drilling out rivets, replacing with screws for the adjustability, didn't have this issue on my 04 v6, but definitely have it on my 03 v8:) Once I get to a point where I have tinker time I'll fix it and put the fix up here, but that's not going to be really soon/quick.
    keakar likes this.
  4. Apr 27, 2017 at 7:27 AM
    Stuck CAPS
    Alex
    FJ guys have this problem too :(
    keakar likes this.
  5. Apr 27, 2017 at 7:29 AM
    Teamroper
    Teamroper New Member
    2000 Silver 4Runner
    Yep. Have an '06 with the same problem.
    keakar likes this.
  6. Apr 27, 2017 at 4:59 PM
    mr5vtps
    mr5vtps New Member
    Charles
    2008 Titanium Metallic 4x4 Urban Runner
    My 08 Urban Runner has same problem.
    keakar likes this.
  7. Apr 27, 2017 at 5:00 PM
    wnelax04sr5
    wnelax04sr5 New Member
    Ethan
    CT
    2004 SR5 4X4 Galactic Gray
    ive just been scratching my paint for 6 years, i think im numb to it
    keakar likes this.
  8. Apr 27, 2017 at 8:07 PM
    Stuck CAPS
    Alex
    both my runners have and I'm wanting to stop it now
    keakar likes this.
  9. Apr 28, 2017 at 5:56 AM
    keakar
    keakar New Member
    louisiana
    2006 4runner sport 4.7L V8 (white)
    same thing for mine too, thinking the same thing, drill out rivets, add washer behind it for that clearance not to scrape and then screw or rivet it back on.
    how can you get access to the back side of it? just in case I want to use screws with nuts behind it
    well hell then, shouldn't there be a recall to fix it? scratching paint finish has to be a problem with rust at some point?
  10. Apr 28, 2017 at 7:55 AM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    I'll look more into it this weekend since it seems to be a common problem. My 04 did not have this issue.:notsure:
  11. Apr 28, 2017 at 9:21 AM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    On my former '14 Taco, I just put a plastic putty knife in the gap at the hinge, and bent the door away from the hinge.
    Steve
    keakar likes this.
  12. May 5, 2017 at 2:03 PM
    grave
    grave New Member
    mine creaks really bad when opening it, is that the issue at hand?
    i just thought the previous owner bent something and i just deal with it. didn't know it was a common issue.
    Stuck CAPS[OP] likes this.
  13. May 17, 2017 at 7:58 PM
    Stuck CAPS
    Alex
    that's the sound, if you see can see between the door and the body, it'll prob be really scraped up
  14. May 23, 2017 at 4:02 AM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    Fixed mine this past weekend, not for the faint of heart people, I ended up taking a plastic rod about 3/8" in diameter rounding the tip and I placed it on the area wear the fuel door was rubbing and I tapped it a few firm times with a hammer.
  15. May 24, 2017 at 8:14 PM
    Stuck CAPS
    Alex
    just to space out the body line and the fuel door?
  16. May 25, 2017 at 4:37 AM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    Yes
  17. May 27, 2017 at 5:45 PM
    wnelax04sr5
    Ethan
    CT
    filled up at a full service gas station today and the attendant cringed opening the door. after 6 years i might try to fix it
  18. Jun 9, 2017 at 11:20 AM
    poncho65
    poncho65 New Member
    New England
    New factory fuel doors are about 60 bucks from some of the online parts sources. It's very easy to simply drill out the 2 rivits on the old door. Attach the new door with 2 pan head phillips stainless screws with a serrated nut, or nut with lock washer. Gently pull back the rubber material around the fill neck for access. The fix is cheap and easy to do.....no more creaky, mis-aligned door rubbing on your paint!
  19. Jun 12, 2017 at 9:05 PM
    Stuck CAPS
    Alex
    Is this painted or not?
  20. Jun 15, 2017 at 11:39 AM
    poncho65
    poncho65 New Member
    New England
    The fuel doors come through in primer. You can have them painted to match....I installed mine "as is". Being that it's now attached with screws, I could take it off anytime and have it painted.
    4RunningNashville likes this.
  21. Jun 20, 2017 at 7:29 AM
    bahndrvr
    bahndrvr New Member
    Trevor
    Melbourne, Fl
    03 SR5 V8 4Runner
    I messed with mine while at a gas station the other day, completely fucked it up lol. IT rubs worse now and having issues with the release working now, DOH. I'll actually have to remove it and fix it, probably just remove, reattach with screws and paint with a paint pen and clear it.
  22. Jun 20, 2017 at 12:34 PM
    Stuck CAPS
    Alex
    That's the boat i was in, I just put a towel over it and punched it reasonably soft a few times tbh. It only rubs beyond open 90* now.
  23. Jun 30, 2017 at 9:03 AM
    MP21
    MP21 New Member
    1998 T4R 4x4 V-6 & 2008 T4R 4x4 V-8 & 2004 T4R 4x4 V-8 & 11 Sequoia Platinum
    98 T4R 2" lift 235/85r16 Hankook Dynapro M/T 07 T4R 3" ToyTech Lift with Bilstein 5100 front and rear 255/70R18 BFG A/T Ko2 JBA uppers 04 T4R 4x4 V-8 Currently stock
    Yes, bought a new one. Total cost for rivets and door was less than $80 and I just bought spray paint in my color code online. Then cleared it and was done.
  24. Jul 26, 2017 at 1:55 PM
    grave
    grave New Member
    forgot about this thread... a few months ago i smeared some lithium grease along the hinge and between the door and where it scrapes and... no more squeak! i'll probably have to reapply occasionally but that's fine with me.
    specifically:
  25. Oct 1, 2017 at 3:12 PM
    Ric
    Ric New Member
    Ric
    Glad Im not the only one, with this issue.
  26. Dec 5, 2018 at 1:20 PM
    djremix
    djremix New Member
    Alain
    2004 4Runner
    none except aftermarket Alpine touchscreen
    Sorry to revive an old thread. I have the same issue with my 04 4Runner. I bought a new door, painted it but I want to know from the guys that replaced the door, what did you do about the little spring that pops it open, there is none on my new door and I can't quite figure out how to get the old spring out and on to the new one...
