Harbor Freight compressors; alternative to ARB twin?
Discussion in 'Off-Roading & Trails' started by SendInTheCavalry, May 29, 2021.
  1. May 29, 2021 at 5:56 PM
    SendInTheCavalry
    SendInTheCavalry [OP] New Member
    M
    Ohio
    Trd Pro
    I was at my favorite odds and ends store, Harbor Freight.
    I noticed these relatively small air compressors. 2-3gal..
    They are really compact and could probably be taken off of the “frame” and made even smaller. They would need to be run off of AC power. I think most guys have some kind of inverter..
    Anyhow what are your thoughts?
    Badbob76087 likes this.
  2. May 30, 2021 at 6:35 AM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    Personally I use ryobi 1gl w/6Ah also have a spare 4Ah
    ^HF compressor looks good too
  3. May 30, 2021 at 6:41 AM
    SendInTheCavalry
    M
    Ohio
    Trd Pro
    This one also caught my eye, but $60...!! To good to be true!!??
  4. May 30, 2021 at 6:59 AM
    kbp810
    kbp810 rebmem wen
    As a comparison to the ARB twin, the ARB twin puts out 6cfm, where as it looks like this Harbor freight only puts out 2.
    The twin would still be way faster, and enough to run many air tools.
    Not saying for sure to buy a twin over this; just highlighting one big initial difference that I see.
  5. May 30, 2021 at 7:05 AM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    ^ good observation how many air tools will you run on this set up if any
    Also $500+ vs $160 vs $60 vs $120 just sayin
    kbp810 and SlvrSlug like this.
  6. May 30, 2021 at 9:51 AM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    The 4Runner inverter is specified at 400W. That’s about 3.3 Amps. These AC compressors will probably exceed that, plus consider the surge current when powering them on.
    jetmechG550 and Jynarik like this.
  7. Jun 7, 2021 at 4:43 PM
    spencermarkd
    spencermarkd New Member
    Spencer
    Pullman, WA
    2007 Driftwood Pearl SR5
    If it's the same inverter that was in the 2nd gen tacoma it will trip the 400w stock inverter if the pressure is already built up. At least it would with the 1 gallon one I have and my old taco. It'll build pressure initially, then trip when it goes to pump again against the 80 or 90 PSI already in the tank. It's amazingly quiet though. If you had a larger inverter/battery setup already it'd be a solid option.
  8. Jun 7, 2021 at 4:56 PM
    HF compressor is 7.1A.
    Good luck running that from the 4R outlet.
  9. Jun 7, 2021 at 5:41 PM
    spencermarkd
    Spencer
    Pullman, WA
    You're right for the one he linked. For the 1 gallon it's only 2.8a, that was the one I had and was referencing working. My bad for making it confusing.
    Dillusion[QUOTED] likes this.
  10. Jun 10, 2021 at 1:23 PM
    jetmechG550
    jetmechG550 New Member
    Frank
    2021 Off Road Premium
    How long would it take to go from about 18psi to 35psi? The flow rate is horrible
  11. Aug 18, 2021 at 3:53 PM
    Kwikvette
    Kwikvette Kwik Fab
    Multiple
    Viair has been in the game for a long time.
    Some people run a 300P for up to 33's with ease, so for that reason I run a 400P for my 33's.
    $200 on Amazon, can't go wrong as it's a quality air compressor.
