Hand Held Air compressor opinions please
Discussion in '5th Gen 4Runners (2010-2024)' started by jake1530, Feb 13, 2025.
  1. May 30, 2025 at 1:54 PM
    #61
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    That is interesting! My old analog 88p took forever. Maybe it was just do for replacement? It would take nearly half an hour to air up my 34" (285/75/17) from 13-35 psi.
    Regardless I'm with you on the size. The 88P is staying in the vehicle at all times but the 400P will be reserved for wheeling trips. It's a little too large to tote around at all times.
  2. May 30, 2025 at 10:41 PM
    #62
    Scarif_1
    Scarif_1 New Member
    Oakland
    2020 TRD ORP
    Discounted Viair 400P Amazon open box. Perfect for 33s. The inflator gun is awesome.
  3. May 31, 2025 at 3:06 AM
    #63
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    The AAA portable tire inflator works for me.
  4. May 31, 2025 at 5:41 PM
    #64
    OdyRunner
    OdyRunner New Member
    I have been running the Ironman air champ pro 5.65 CFM a couple of years now. I typically air up 33in tires from 18-20 PSI to 36-45 PSI depending on how loaded I am. Airing up is pretty quick 12-16 mins for all 4 tires and that’s doing it one tire at a time. Living in the desert I have aired up in 100 plus degree heat on a few occasions and running the BDR and other longer trails I have aired up and aired down multiple times in a single day with no issues.
    I did just purchase the morrflate quad 4-tire hose kit so it might be even quicker going forward.
  5. Jun 5, 2025 at 4:33 AM
    #65
    Greg D
    Greg D TJ312
    TJ312
    2013 4runner
    I carry Milwaukee M18 inflator and impact.
  6. Jun 5, 2025 at 9:34 AM
    #66
    ArizonaJK
    ArizonaJK Collector of Hobbies
    Phoenix, AZ
    2024 Underground OffRoad Premium
    Same approach I take as well… I keep a compact Viair 85p in every vehicle in case of roadside emergencies, and have a Viair 400p that I bring with for offroad.
  7. Jun 6, 2025 at 8:51 AM
    #67
    kolter45
    Denver
    Inferno Pro & BRM Sport
  8. Oct 30, 2025 at 2:56 PM
    #68
    lowflyer
    lowflyer New Member
    Southwest
    2023 TRD ORP w/ KDSS <2021 Venture w/o KDSS <line of Tundras
  9. Oct 30, 2025 at 2:59 PM
    #69
    lowflyer
    lowflyer New Member
    Southwest
    Anyone have experience with Samout compressors?
  10. Oct 30, 2025 at 3:40 PM
    #70
    JakeTheSnak3
    JakeTheSnak3 Whoever.
    Jacob
    Concord, CA
    Swift Runner
    I recommend one of these. https://www.lasfit.com/collections/tire-inflator
    That unit at the bottom of the listings I have had since 2021, and the larger one, second from the top I purchased last spring. I can attest to the quality of their products. They work for me.
  11. Oct 31, 2025 at 6:02 AM
    #71
    Oscar likes this.
  12. Oct 31, 2025 at 11:40 AM
    #72
    Exactly.
    I will add that I’m way more enthusiastic than I thought I would be about the feature that allows you to set a target pressure, and then the compressor automatically shuts itself off when the tire is at that pressure. With my knees and back the thought of ending a day of driving bent over or kneeling on a hot desert floor or pavement is not appealing.
    2Toys likes this.
  13. Oct 31, 2025 at 2:54 PM
    #73
    Pentangler
    Pentangler Happy Member
  14. Oct 31, 2025 at 9:47 PM
    #74
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    ive been using option 2 for years with mine. I've had some of these straps for other things and I thing the small one works great (or it could be another size from another brand, I don't recall exactly). I also have the morflate that airs up 2 tires at once. It's not as bulky and cumbersome as the quad and still efficient .
    https://www.amazon.com/dp/B07CZGQNY3?th=1
