Fumoto Oil Drain Valve
Discussion in '5th Gen 4Runners (2010-2024)' started by BobbyB, Mar 2, 2021.
  1. Mar 2, 2021 at 1:17 AM
    BobbyB
    BobbyB [OP] Where the road ends, Fun begins!
    Bob
    Marietta, GA
    2021 White TRD Off Road
    I have used Fumoto Oil Drain Valves in several of my vehicles over the years to avoid the eventual stripping of the threads in aluminum oil pans and for the convenience they bring.
    I’ve never had a problem with one and am considering using one on my 2021 OR when it gets to its first oil change (has 1400 mi) in a couple of months.
    I would like to hear what experience others have had using one on a 4R whether it is good or bad before I put one on my OR....
    thanks for your input..
    kolter45 and ruiz4251 like this.
  2. Mar 2, 2021 at 1:43 AM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    Works great
    Make sure to use a drain tube especially if your 4 is lifted!
    Honz likes this.
  3. Mar 2, 2021 at 5:37 AM
    Tuco S.
    Tuco S. New Member
    I've been using Dimple magnetic drain plugs for years in all my vehicles, and currently have one installed in my 4R since the first oil change. The removable doors in most skid plates (both oem and aftermarket) aren't quite wide enough for my liking. I've already had some oil spill under the skid plate when the drain plug is first removed, and don't want it dripping on my driveway and garage floor. I also don't want to remove skid plates every time I change the oil, so I ordered a Fumoto F133S with the short nipple cap attachment and tubing. Apparently the new Fumoto valves have a much larger orifice to let the oil drain in less than half the time compared to the older ones. Very nice unit, but I haven't installed it yet.
  4. Mar 2, 2021 at 5:47 AM
    Bannerman
    Bannerman New Member
    2021 Offroad Premium
    I installed on my 2021 when I changed the oil at 1000 miles but wont have a report on how well it works for another 9000 miles. :D
  5. Mar 2, 2021 at 7:04 AM
    I have one on my 2018 and on the wife's Subaru.
    Quick and easy.
    I love them!
    LCJ77, Toy4X4, A&P and 2 others like this.
  6. Mar 2, 2021 at 10:23 AM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    There doesn't have to be an "eventual" stripping issue just don't break your arm tightening them.
  7. Mar 2, 2021 at 7:13 PM
    Lightning03
    Lightning03 New Member
    2019 TRD PRO
    I put one on my 2019 TRD Pro along with replacing the plastic oil filter cap assembly with a metal one. No issues with the Fumoto, these are two upgrades I’m glad I made.
    hallcs, Toy4X4, A&P and 5 others like this.
  8. Mar 2, 2021 at 7:33 PM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    What Lightning03 said :)
    Toy4X4 likes this.
  9. Mar 9, 2021 at 6:43 AM
    I went with the short nipple (F133S). There is no directional change with the way the oil drains. You could change the direction of the flow with F103SX if that interests you.
    I haven't had to use a drain tube on mine because I take off the stock skid plate. If you have an aftermarket skid plate with one of those small, removable windows I could see using a drain tube or getting F103SX.
    A&P[QUOTED] likes this.
  10. Mar 9, 2021 at 7:36 AM
    TeamBLUE
    TeamBLUE New Member
    Northern Cal
    2018 4Runner
    I bought this same valve for my 4R and it was the best purchase yet. Makes life super easy!! I would highly recommend this for any car/truck really if you are doing your own oil changes.
    nimby and A&P like this.
  11. Mar 9, 2021 at 10:04 AM
    Tuco S.
    Tuco S. New Member
    How thick is the oil pan at the drain? I would assume it's about 3/16" (0.19 inch) if it's steel. I measure 0.45 inch from the end of my Fumoto's threads to where it sits flush at the pan, which doesn't account for the crush washer. I would guess it probably sticks up about 1/4 of an inch above the bottom of the oil pan. It looks like the pan at the bottom is roughly 12" by 4", so that would be approximately 0.2 quarts of old oil remaining in the pan if my estimates are correct. That's nothing to worry about considering there will be almost a full quart of old oil remaining in the engine even if you remove the drain plug and replace the oil filter. It couldn't hurt to remove the Fumoto every now and then to drain any residual crud at the bottom.
  12. Mar 9, 2021 at 1:23 PM
    canadian.bacon
    Snowland
    ‘22 Tesla Model Y
    Also curious, with the valve in, does it drain the little metal shavings, or they get stuck around the valve ? Like, does the valve come up a bit and it won’t allow the oil to fully drain ? If I have to take it off, then what’s the point of having it in the first place ?
  13. Mar 9, 2021 at 2:44 PM
    Tuco S.
    Tuco S. New Member
    I pulled this from the 2019 Toyota Repair Manual. I don't think this engine is unique in this regard.[​IMG]
  14. Mar 9, 2021 at 2:47 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    I’ve had mine for around 20k miles. Love it. just make sure you get the shorty so your cover plate still bolts on
  15. Mar 9, 2021 at 2:50 PM
    Tuco S.
    Tuco S. New Member
    Fumoto claims on their FAQ page that the threads should be flush with the bottom of the pan on most vehicles. I'll try to measure and verify it when I do my next change.
    canadian.bacon[QUOTED] and A&P like this.
  16. Mar 9, 2021 at 3:02 PM
    Tuco S.
    Tuco S. New Member
    My pleasure! I suppose it could be worse right? I hear Bugatti charges something like $25k for an oil change because they have to take the entire engine apart to get out all the old oil.
  17. Mar 9, 2021 at 3:20 PM
    Charlievee
    Charlievee Not new member.
    That's what i found when i looked into them. Part number specific.
  18. Mar 10, 2021 at 10:25 PM
    Saitama
    Saitama New Member
    Steve
    San Francisco
    Stock 20 ORP
    Prinsu Full Length Rack, BFG K02's, Midland MXT275
    I love mine. Fits under the stock skid so no chance of damage. Got clear plastic tubing from Lowe’s, which slows the drain a bit but makes it super clean to run directly inside the pan. Easy peasy.
    nimby likes this.
  19. Mar 20, 2021 at 12:06 AM
    POWERPLANTHOMER
    POWERPLANTHOMER New Member
    JAMES
    2020 TRD OR PREMIUM, 2021 TRD OR PREMIUM KDSS
    Just installed yesterday on my 2021 with RCI aluminum skid plates, I flushed 3/4 quart through the valve to test. The hole in the skid plate is more than big enough to not make a mess, works great, well next time I will enjoy it.
    BubbaJr23 and nimby like this.
  20. Jul 21, 2022 at 8:41 PM
    blackcloud08
    blackcloud08 They're Watching Us....
    I like the Femco better, might be worth a look.
  21. Jul 21, 2022 at 9:31 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    The oil filter. Change the oil and filter every 5000 miles.
    Toy4X4 likes this.
  22. Jul 21, 2022 at 10:30 PM
    Ramrod88
    Ramrod88 4Runner on Corolla budget
    New Orleans
    22 TRD OFF ROAD
    We have the benefit/pain of having a cartridge oil filter. Im thinking about shoving a small, coin size magnet in mine next oil change
    ReRunner[QUOTED] likes this.
  23. Jul 21, 2022 at 10:49 PM
    2019 TRDP w/Kangs brah!
    I have used their valves before on other vehicles without issues. I went with Stahlbus on the Runner and GTO. It was mostly to try something new but it has been a good product on both vehicles.
  24. Jul 21, 2022 at 11:18 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Interesting.
    The front diff, rear diff, and transfer case have OEM magnetic drain plugs. But not the engine oil drain plug. At least for my 2018. Maybe Toyota didn’t think it was necessary since the filtration is so good.
    You’ve been using an after market magnetic plug?
    Toy4X4 likes this.
  25. Jul 22, 2022 at 12:14 AM
    If one does his or her oil changes at the 5000 mile intervals, and to the dealer for the 10k intervals, will the dealer be able to handle the Fumuto valve? Or is it asking for trouble?
  26. Jul 22, 2022 at 1:12 AM
    BobbyB
    Bob
    Marietta, GA
    I installed a Fumoto oil valve on my wife’s 2013 Mazda CX-9 when it was new. She takes it to the dealer for all oil changes and other service and having the Fumoto valve on has never been an issue….. I would say it depends on the dealer but I’ve not experienced an issue..
    Cheers,
    Bob
    nimby, Captain Spalding and Toy4X4 like this.
  27. Jul 22, 2022 at 2:13 AM
    I explained to a service writer at a dealership, that we went to for the 10k 'free' oil change that we had a Fumoto valve and ask him "do you know what I'm talking about?" You could have heard a pin drop, as the 'puzzled look' came over his face. Luckily.. a tech was standing within earshot and said "yeah, I've dealt with several." The service writer boy told him, "you have the job of changing oil on this one." So while there may be some people that have NOT heard of these types of drains, their popularity is increasing daily. They are not something 'new', as they have been used on construction equipment new from the factory, and other applications where oil is a bit harder to change. We have them on things at home ranging from our Arctic Cat 4 stroke snowmobile to our lawn tractor to our 4Runner, no failures, they are pretty full proof.
  28. Jul 22, 2022 at 4:13 PM
    Loco x Toyota
    Loco x Toyota New Member
    Cedar Park, TX
    TRD Pro Solar Octane
    I have valvomax
    its a more elaborate design with dust cover.
    I have use them for so many of my vehicles for years, never any problematic issue.
    The only slight problem is on some later model year Toyotas such as Venza, RAV4, Corolla, there's very tiny clearance between the plug and plastic underbelly cover. It'll bend the cover a little, but not a functional problem.
    On the 4Runner it works perfectly with RCI skid plate access
    Screen Shot 2022-07-22 at 6.12.05 PM.jpg Screen Shot 2022-07-22 at 6.12.25 PM.jpg
    icebear and Toy4X4 like this.
  29. Jul 22, 2022 at 5:33 PM
    Trail Addict
    Trail Addict Professional Driver on a Closed Course
    2022 4Runner TRD Pro
    Tama1968 likes this.
  30. Jul 22, 2022 at 8:28 PM
    Tama1968
    Tama1968 New Member
    Florida
    2018 SR5 Premium Magnetic Grey Metallic/2019 SR5 Celestial Silver
    yeah Fumoto has an Amazon store front. Started using Fumoto's on my Blazers 20 years ago and almost every vehicle all along. Had one or two where I did not due to clearance concerns but never had an issue with them.
    Toy4X4 and nimby like this.
