Fuel pump power
Discussion in 'New Member Introductions' started by Pitbull67, Jul 27, 2017.
  1. Jul 27, 2017 at 2:20 PM
    Pitbull67
    Pitbull67 [OP] New Member
    Phil
    2004 4Runner
    None so far
    I recently had to Replace the fuel pump and i know No one else has ever done this but i didn't know i could unplug the wires from under the driver side rear seat. So i ended up pulling the wires out of the plug no big deal fixed that issue but now I'm not getting power to the sending unit and have checked and changed relays and fuses any one else ever had this issue ? If so any help would be appreciated
  2. Jul 31, 2017 at 12:33 AM
    larramo
    larramo 3ed gen faithfully
    larry
    clearlake ca
    4 runner
    3" lift but mostly all stock not a scratch on it it is pristine condition amazing for being 19 years old.
    sound like it time for a volt meter. you need to check all the wires and make sure you got them all right i would get a volt meter and double check the wires or run a positive line to the fuel pump to see if it is working.hope this helps LARRY B.
