FS: [Houston, TX] 1987 4Runner 5-Speed- Black with gray interior 183k miles $6500
Discussion in '4Runners For Sale' started by turbosteven, Apr 7, 2019.
  1. Apr 7, 2019 at 9:24 PM
    turbosteven
    turbosteven [OP] New Member
    Steven
    1986 4Runner 22RE
    None
    Okay 4Runner fanatics, here it is, your next ride!!
    Here is a link with some pretty pictures:
    https://spark.adobe.com/page/xMteJJyQlBKu5/
    Here are the details:
    For Sale: 1987 Toyota 4Runner DLX - $6500
    Gray carpeted interior with split rear fold-down seats and carpeted rear cargo area (Never Flooded !!) 183,000 miles
    This is an all original, unmolested 1st generation 4Runner that is in good running condition with current Texas inspection (6/19). Some rear cargo trim pieces are missing from previous owner.
    The interior passenger area carpets have been removed and thoroughly cleaned and the seats are in good condition (See pictures). All lights, turn signals and brake lights work.
    Dashboard is cracked - as are all of them !
    New items within the last 6 months include:
    Radiator- new aluminum core with Japanese radiator cap and new Toyota OEM hoses (all 3).
    Alternator -Denso Remanufactured
    Starter - Denso Remanufactured
    Fuel Filter - Toyota OEM
    NGK OEM Spark plugs
    New Spark Plug Wires
    Toyota OEM Rotor and Cap
    New vacuum lines (Toyota OEM)
    New battery
    New front main seal
    New catalytic converter, muffler and tail pipe
    New valve cover gasket.
    New PCV valve and rubber grommet
    New rear brakes
    New distributor shaft O-ring
    Newly rebuilt front hubs - 4WD works well !!
    New thermostat, rubber gasket and fan clutch.
    New wiper blades and wiper washer motor
    New dashboard lights (many were non-working or missing)
    New aftermarket CD/stereo with USB/AUX input for your smart phone.
    New gas tank, sending unit and Denso fuel pump.
    All mechanical parts purchased from either 22REPERFORMANCE dot com or other reputable Toyota OEM retailers. Another good source for parts is The 4Runner House in Garland, Tx.(Dallas) should you need anything else.
    This was originally a South Dakota vehicle, as such, there is rust on the fenders and some on the undercarriage. See pictures.
    This would be a great hunting vehicle, restoration project, or daily driver. Very reliable engine\transmission combination on a mid-80's Toyota. Everything works except the rear riper arm. It moves, just does not apply pressure to the window. Both the heater and A/C work!!!
    The previous owner tried to put an aftermarket cruise control, but failed miserably. I have disconnected it as it was causing a constant high-idle.
    This vehicle is only for sale because I have a much nicer one with no rust and fewer miles. Otherwise I would keep it and do the repairs to make it nicer. I drove the truck from South Dakota to Houston in terrible condition from neglect and abuse, and it still made the trip without problems !!
    This is a daily driver at highway speeds - runs well !!!
    Just recently thoroughly cleaned the injectors (Seafoam), throttle body intake and cold start injector. Also cleaned the engine bay. The 16-inch tires are in good shape with plenty of tread.
    Not in a hurry to sell and I will only accept CASH in person. Please email me if you have questions.
  2. Apr 7, 2019 at 9:31 PM
    turbosteven
    Steven
    1986 4Runner 22RE
    None
