Frozen Parking Brake cable 99 4Runner Limited
Discussion in '3rd Gen 4Runners (1996-2002)' started by Fiiisherman, Mar 13, 2018.
  1. Mar 13, 2018 at 8:53 AM
    Fiiisherman
    Fiiisherman [OP] New Member
    steve
    1999 4Runner
    I'm troubleshooting a frozen Parking Brake cable on my 4Runner.
    I checked under the truck and the cable and mechanism for each back wheel is free and moves and applies braking to each rear wheels (as it should) when each cable pulled by hand.
    The cable that seems to be frozen is the center cable that comes from the handle to the connection at the rear.
    Anyone ever seen this?
    Any way to un-freeze this cable?? PbBlaster maybe???
    Could the problem be in the handle mechanism itself?
    Another question..
    Is the Parking brake cable sold as one assembly that includes the cables for each rear wheel plus the center cable that goes to the handle inside the truck?
    I'm looking at a Dorman #660124 Cable (Rock Auto). Is this the cable I need?
    I will appreciate any response
    thanks
  2. Mar 13, 2018 at 1:35 PM
    Roman
    Roman New Member Vendor
    Roman
    The cable is all one assembly. I can't speak for the aftermarket part, but there are options on the OEM cable. If you'll shoot me your VIN, I can look up the correct one for you.
    jester243 likes this.
  3. Nov 1, 2019 at 11:28 AM
    Fiiisherman
    steve
    1999 4Runner
    well, I finally got around to changing the cable assembly this week. This could have been a easy job if not for 2 things. #1. I had to drop the driveshaft (end at transaxle). Toyota placed a brake cable mounting strap over the driveshaft inside the tunnel. You must drop the shaft to access the one bolt that holds the cable above the shaft. The driveshaft tunnel is not wide enough to allow your hands to reach the bolt with a wrench. That was a pisser .........#2. The Dorman cable that I used had incorrect hole diameters on the two clevis ends that attach at the brake backing plates at each rear wheel. I had to drill out the holes 1/32" before I could install the shoulder pins and secure the cable to the parking brake actuator at each rear wheel. It was a real pisser because I already had the cables on the truck before I found this mistake, so I had to drill the holes bigger while laying on my back under the truck......so if you use the Dorman cable be sure to check hole clearances to make sure that your existing pins will fit the holes. The rest of the cable assembly looks Ok, just a little "light weight" for the job. Time will tell. I did opt for the cheapest cable, and that is what I got.
