Front Wheel well splash guards or covers?
Discussion in '5th Gen 4Runners (2010-2024)' started by jakeright, Apr 26, 2017.
  1. Apr 26, 2017 at 9:12 AM
    jakeright
    jakeright [OP] New Member
    2016 Toyota 4Runner Limited Pearl White
    I have a 2016 Limited Edition and it's Pearl White, which means the black bolts in the wheel well are extremely obvious under the panel behind the tires. I've search a bit and can't seem to find a cover or splash guard that goes all the way up to the last bolt to cover? Is there such a product?
    Also, it should be mentioned that I have fixed step rails.
  2. Apr 27, 2017 at 6:37 AM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    TAKE a picture ..
    Stuck CAPS likes this.
  3. Apr 27, 2017 at 7:36 AM
    Stuck CAPS
    Stuck CAPS Truck killer
    Alex
    2007 Nautical Blue Metallic Limited V6 4x4
    ARB Bumper, Some Stuff, Some Other Stuff, and some Stuff.
  4. Apr 27, 2017 at 7:46 AM
    jakeright
    Here are a couple pics
  5. Apr 27, 2017 at 8:15 AM
    jester243
    Dan
    Spokane, WA
    little shot of white plasti dip? or get some touch up paint from the dealer? :notsure:
  6. Apr 27, 2017 at 9:21 AM
    brochacho
    brochacho New Member
    2018 Sequoia TRD Sport
    Limited models don't have mud flaps? As @jester243 color match touch up paint might be your best bet.
  7. Apr 27, 2017 at 9:39 AM
    Stuck CAPS
    Alex
    or you could just paint the inner part of the flare black, i imagine it'll get dinged up anyway
  8. Apr 27, 2017 at 11:02 AM
    jester243
    Dan
    Spokane, WA
    I don't think they do, my dad was trying to find some and for his limited there were no options. However, he has the retracting running boards so if you don't have those I would imagine you could put the factory ones on. :notsure:
  9. Apr 27, 2017 at 11:35 AM
    j cat
    j cat New Member
    massachusetts
    I would never run with no mud guards my sr5 came with mud guards front rear. I however did not like the fronts TOO SHORT .. So I installed aftermarket fiber glass re-enforced guards. used all those OEM fasteners to lock it in place .. 10X more durable than toyota part.
    I used a piece of card board made a copy of the hole locations then put holes in the cardboard then mounted on vehicle did some tweaking .. then placed on after market guard drilled the holes and mounted it .. so far working great NO crap on the sides or the side step..
    cost for the guards was $25..
