Front/Rear Dashcam wiring question
Discussion in '5th Gen 4Runners (2010-2024)' started by bk77459, Apr 24, 2024.
  1. Apr 24, 2024 at 11:42 AM
    bk77459
    bk77459 [OP] New Member
    Bryan
    Sugar Land, Texas
    2022 4Runner Limited
    Is there a Front/Rear daschcam setup that DOESN'T need a wire/cable to the rear camera? I'm worried about interior rattles if I run a wire to the rear camera.
  2. Apr 24, 2024 at 11:46 AM
    I ran mine down the door sill to the rear and only went up at the back to avoid having to run it down the entire length of the headliner but also because I have a moonroof. The wireless ones I have seen are more backup cameras.
    bk77459[OP] likes this.
  3. Apr 24, 2024 at 1:24 PM
    Short answer: No.
    They all need cables & wiring. What you want is a wireless camera. Just wire it up. Wires & cabling doesn't rattle around.
  4. Apr 24, 2024 at 1:44 PM
    Photon_Chaser 42465 and counting…
    NorCal Coast, CA
    21 TRD Pro
    On my dash cam I only needed to route two cables, +12v/ground pair and a USB-C.
    Across headliner from the overhead console, down the A pillar, bottom drivers and passenger door kickplates, up the B pillar and back under the headliner to the rear window…easy peasy and no rattles.
    Edit: The USB-C provides Data and Power to/from the rear camera, the +12V/Ground pair is for something else.
  5. Apr 24, 2024 at 3:27 PM
    crashdb
    crashdb How Did I Get Here?
    Dave
    Manassas, VA
    2022 TRD-OR-P
    Little Tree Air Freshener
    I had one cable to run for mine. I was able to run it through the headliner with only taking off the door weatherstripping. I can confirm through serious off-road testing that it doesn't rattle. :)
  6. Apr 26, 2024 at 12:46 AM
    wing2
    wing2 New Member
    Richard
    2024 SR5 Premium
    I have not seen any wireless dashcams. I have front and rear cameras in my Tundra. It was easy to run the wire,well hidden, and no noises.
  7. Apr 26, 2024 at 6:09 AM
    sympley76
    sympley76 New Member
    2021 4Runner Limited
    Similar here, ran 2 wires across windshield to the A pillar on driver side and then 1 wire down to fuse box, and other through the weather stripping by the headliner all the way to the back. Was really worried about pulling down the weather stripping by the headliner but it was way easier than I though, took like 5 minutes if that. No rattling or any other issue so far.
  8. Apr 26, 2024 at 6:19 AM
    wayfus
    wayfus New Member
    wayne
    none yet
  9. Apr 26, 2024 at 7:45 AM
    crashdb
    Dave
    Manassas, VA
    2022 TRD-OR-P
    Yup. It just pulls off and presses back on. Just have to run it through the pillar trim. It took 10 minutes.
