From stock 22 ORP to Moab-ready for $2,500?
Discussion in '5th Gen 4Runners (2010-2024)' started by Wildfish, May 20, 2024.
  1. May 20, 2024 at 12:57 PM
    +1 on the air system
    That's all I have just air and tires right now next for me is sliders I just can't pick!!
    akakaiser likes this.
  2. May 20, 2024 at 1:06 PM
    H1M72
    H1M72 New Member
    West Columbia, SC
    2024 TRD PRO
    Use the 2500 and buy a cheap ass
    xj, save the 4runner
    Acesandeights and akakaiser like this.
  3. May 20, 2024 at 1:48 PM
    Acesandeights
    Acesandeights #34
    2024 ORP
    What's your rating system 1-4, 1-5, 1-10?
  4. May 20, 2024 at 2:09 PM
    Pavo
    Pavo New Member
    My falken wildpeak at3ws have been amazing in dry and wet and snow and I wheel more than 90 percent of the population I run 10ply e rating though. I used to run ko2s and those are pure garbage in snow (turn rock hard no matter how low you air down)
    bigshmoop likes this.
  5. May 20, 2024 at 2:25 PM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    We knew going in that I was going to scrape some, there was a go around, but I wanted to do it.
    everyone else had a lift and bigger tires than me.
    I just put a 3inch lift this weekend.
    roooo[QUOTED] likes this.
  6. May 20, 2024 at 3:21 PM
    lowflyer
    lowflyer New Member
    2023 TRD ORP w/ KDSS <2021 Venture w/o KDSS <line of Tundras
    I agree with the sentiment that the stock 4R is very capable as is. I do a lot of remote desert driving in deep sand and rocky ledges, slick rock, sometimes mud. I don't do, and have no desire to do, advanced rock climbing. I don't need my 4R to be sexy looking. My 4R is stock except for tires. It actually came with rock sliders, which I removed:) In about 50 years of offroading I've never needed them. I use off road tires and my brain to avoid much trouble. But, YMMV, each to his own.
  7. May 21, 2024 at 4:26 AM
    Wildfish
    Wildfish [OP] New Member
    2022 4Runner TRD Off-Road
    Again this is all fantastic advice. And I know these kinds of questions are answered often, so I appreciate everyone taking the time. One more question about armor: do you think it's reasonable to keep the stock skids (trd off road, not pro) until they are beat up and then replace them? I'd love to defer the cost. But I keep hearing they are inadequate. I still have the temp tag on and I've already scraped the front skid...
    Acesandeights likes this.
  8. May 21, 2024 at 4:32 AM
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    You can damage a TRD pro in Moab.
    if you had a Subaru you can wheel “out in Moab” without damage.
    What kind of trails will you do? There isn’t a single prescription of what Moab requires
    icebear and Wildfish[QUOTED][OP] like this.
  9. May 21, 2024 at 4:33 AM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    You only have a front engine skid and fuel tank skid. Both are thin steel and can take some abuse. It really comes down to what trails you plan on doing and if they have obstacles/rocks. Once you take a solid hit on transfer case or transmission the skids would have been worth it.
    Rear diff also. Yes it's solid and steel but also the lowest point. I added extra armor around it knowing it will take some hits. I feel your pain on where to prioritize $ on brand new truck.
    Wildfish[OP] likes this.
  10. May 21, 2024 at 6:55 AM
    Wildfish
    Totally understand. My plan was Fins N' Things, with the option to bypass really tough stuff if necessary, though would like to give some obstacles a try!
  11. May 21, 2024 at 7:09 AM
    2021venture
    Todd
    2021 Venture
    Trail report from another 4r last week
  12. May 21, 2024 at 7:12 AM
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    I watched quite a few vids before I started modding my 4R. The common theme was to get sliders first. If you ding the rocker panels, they are very difficult and very expensive to repair. For your $2500 budget, you can get sliders and tires. You may have enough $$$ left for an air compressor, but you can air up at a gas station in town. My 1st trip to Moab, I aired down to 18 psi and left it there for the duration. Only aired up before leaving for home 5 days later. The longest drive to a trail from town was about 1/2 hour at highway speed.
  13. May 21, 2024 at 8:38 AM
    CA4runner
    CA4runner New Member
    Nor Cal
    2019SR5
    6112s, TRD F2 wheels
    Improving the approach and departure angles would help.
  14. May 21, 2024 at 2:54 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    One way to do that is take the bumper off lol
    Noticed this was quite the trend at Toyota Jamboree this year xD
    icebear and 2021venture like this.
  15. May 21, 2024 at 3:30 PM
    That’s actually a good idea. Then you can reinstall after the trip.
  16. May 21, 2024 at 3:32 PM
    Agent_Outside
    Built 2011 T4R Limited
    Tires, skid plates, sliders.
  17. Jun 3, 2024 at 9:34 PM
    Yobruhitsme
    Denver
    Ineos Grenadier
    Nick B, icebear and roooo like this.
