Fridge Slider Install Questions
Discussion in '5th Gen 4Runners (2010+)' started by kanye_asada, Nov 21, 2021.
  1. Nov 21, 2021 at 8:18 PM
    kanye_asada
    kanye_asada [OP] New Member
    Hey All,
    I have a SetPower AJ50 and I'm planning on ordering the slider for it. I have a few questions as to how to mount it to the cargo area of my T4R.
    Why do some folks mount/bolt it to a piece of plywood instead of mounting/bolting it direct to the T4R?
    If you are mounting/bolting it to a piece of plywood, are you mounting the plywood directly to the T4R then the slider to the plywood?
    If needed to drill into the T4R, how do I go about it? I don’t have a rear sliding cargo tray
  2. Nov 21, 2021 at 8:41 PM
    Cowboy59
    Cowboy59 Enjoy the Adventure
    N. Florida
    My 4R has the slide out tray. I took out the slide out tray and installed an Aiden James slide out board to the existing rails that my slide out tray was on. I then secured my fridge to board, for which it was made. By mounting it to the board you can slide the fridge out. If you don't have the slide out tray, you would still likely want to mount a fridge to rails so the fridge can slide out for more accessibility.
  3. Nov 21, 2021 at 9:07 PM
    kanye_asada
    would it be best to mount the rails directly to the 4Runner (drill thru the carpet) or drill a piece of plywood to the 4Runner and then bolt the rails to the plywood? Any benefit of doing one or the other?
  4. Nov 22, 2021 at 6:37 AM
    MTB Chris
    MTB Chris New Member
    San Diego, Ca
    Underneath the carpet is just foam. Depending on how heavy your fridge, plus gear you carry, it probably won't sit level after awhile. Something like a base plate will help support the load and keep things level
    kanye_asada [OP] likes this.
  5. Nov 22, 2021 at 8:17 PM
    newlife
    Knoxville TN
    2020TRDORP
    All of them.
    So the benefit of a base plate for us at least is we mounted ours into already installed factory threaded holes. Then bolted out fridge and slide to the base plate along with our drawer. It creates less holes and a more stable platform for changing it up in the future. Locating the factory holes is easy if you’re inclined and don’t mind punching a small hole into the factory sheet metal covering them. Here is a picture of our baseplate installed. E51CF249-ACDF-4F02-A3FF-424D6A0D3C69.jpg
    with this baseplate installed. We then installed our boxes for the fridge and dual drawers directly to the baseplate. This setup did not last long as it just limited the space too much. but taking it out was as simple as taking a few bolts out leaving the platform still in tact still looking as good as before. 8A5ADA2D-F645-4F69-AB10-08AB30B1E9A3.jpg
    When we decided on how the finished and current setup would be installed in the 4R it couldn’t have been easier with the base plate. Put the slide where we wanted it then mark and drill our holes, add some t nuts to the underside and remount the base plate then mount the fridge and new drawer in. Easy as pie. 47466C2A-9472-406D-9B90-D61612A055EE.jpg
    long story short you don’t need a base plate but if you are mounting accessories or say a drawer and a fridge would you rather have a bunch of holes through your floor or none?
    MTB Chris likes this.
  6. Nov 22, 2021 at 9:40 PM
    kanye_asada
    This is exactly what I imagined. Mind if I ask for your specs? dimension of base plate, bolts used to mount it to factory holes, how you located the factory holes, etc?
  7. Nov 23, 2021 at 4:22 AM
    Dinosaur Overland
    Dinosaur Overland New Member
    Alabama
    2019 trd offroad
    https://www.youtube.com/watch?v=nT3TWfTZ5xU&t=1s
  8. Nov 23, 2021 at 7:43 AM
    newlife
    Knoxville TN
    2020TRDORP
    All of them.
    While mark and merrys video was a great one. Mounting the platform was actually a lot easier and less complicated for us than how they did there’s. They did a lot of angle cuts and tools the average joe doesn’t have. I believe all I did was was some scrap 1x4 for supports, 4 m8 bolts (factory thread size) and a 33 1/3x 41 1/4 board. I have the measurements I think in my build thread. The hardest part of our entire install was unbolting one of the exhaust heat shields to access the back passenger rivnut and snaking my hand around/near the fuel tank to find the driver one. As you can see in our picture if you zoom in it butts up nicely to the angled piece in the back for the tie downs.
  9. Nov 23, 2021 at 7:49 AM
    kanye_asada
    yep that's why I wanted to know how you did it, I didn't want to remove that piece or have to deal w/ angles. Do you have a link to your build thread? I tried looking thru your profile, but didn't see anything
  10. Nov 23, 2021 at 9:43 AM
    NotAnotherWhite4runner
    NotAnotherWhite4runner New Member
    ‘14 SR5
    Total Chaos upper and lower control arms S2 shocks upfront. 37” toyo MT Tons of little extras
    I just used a piece of 3/4” oak plywood and used 3 anchor points to the body then bolted the fridge slide to that. Solid as I could hope for. Also built a slide out and I didn’t want a lot of holes in the body itself
    Shadow_T4R and MTB Chris like this.
  11. Nov 23, 2021 at 10:31 AM
    Shadow_T4R
    Shadow_T4R New Member
    Josh
    2019 MGM TRD OR 4Runner
    Bilstein 6112 + 5160S | JBA UCA | Icon 2" Rear Springs | Cooper Evo MT 285/70/17 | Spider Trax Spacers | ToyTech Diff Drop | ARB Diff Breather | C4 Low Pro Bumper | X2Power AGM Group 31 Battery | Voltage Booster | Diode Dynamics SS3 Sports | ARB 50qt Fridge | Custom Built Gear Plate
    I built a base plate to mount my slide out on. I didn't want to do anything to the interior that's not 100% reversible. I use existing tiedown points to hold it in place. I also raised my base plate to match the rear seats when they are fold down, so everything is level. I sleep in the back of my 4runner when camping, and the hump was a back killer. Bonus to being raised, I was able to add in a small pull out table to cook on.
  12. Nov 23, 2021 at 10:54 AM
    kanye_asada
    I'm liking this idea, what did you guys use to anchor it down to the existing tie down points (I'm assuming the existing D-Rings in the front and back)?
  13. Nov 23, 2021 at 10:56 AM
    ‘14 SR5
    I actually used self tapping sheet metal screws into the body in the rear drivers side corner and then two more behind the rear seats and anchored it to the body.
  14. Nov 23, 2021 at 2:16 PM
    Shadow_T4R
    Josh
    Behind the seats I used to slightly longer 10mm bolts in the stock tiedown locations, like the AJC gear plate. I counter sunk them into the wood so they sit flush. At the tail gate, I used hooks on turn buckles and attached to the D-rings. for my slide, I used t-nuts/blind nuts on the bottom to bolt the slide down with. I wanted to be able to completely remove the fridge and slide, for hauling purposes.
    I could do a small writeup on it soon. I'll be pulling it out of the truck this weekend to add L-track for tie down points. I could do it then.
  15. Nov 23, 2021 at 3:08 PM
    kanye_asada
    Let me know if you do, I'm interested to read it.
  16. Nov 23, 2021 at 3:28 PM
    rageandlove
    rageandlove New Member
    In another forum, but an overview of three different sleeping / fridge / table platforms that I have built. I didn't use a slide because I wanted to keep the whole thing flat for other uses (e.g. hauling hockey gear) but you totally could. Measurements and (entirely reversable) mounting covered. [​IMG]
  17. Nov 30, 2021 at 8:28 AM
    Shadow_T4R
    Josh
    This is by far the best setup I've ever seen! It's very similar to what I am doing with mine now.
  18. Nov 30, 2021 at 4:14 PM
    kanye_asada
    all wonderful setups, but for what i'm looking for: i'm going to just get a board cut out and anchor it the way aiden james is doing so. going to try this out and if needed, i'll probably customize some brackets to slide over existing tie down points and call it a day.
