Fox 2.5 Performance Elite Series
Discussion in 'Suspension' started by AccuTune Offroad, Nov 17, 2023.
  1. Nov 17, 2023 at 3:26 PM
    AccuTune Offroad
    AccuTune Offroad [OP] New Member Vendor
    2.5" Fox Suspension
    Fox has their new 2.5 Performance Elite Series shocks now available for the 03-24 4Runners. If you are not familiar with the difference between those and the Factory Race Series, here is a great article that compares the two. We should be getting our first shipment before the end of the year, so if its something you've been holding out for keep us in mind!
    Reminder: All the shocks we sell will be custom valved specific to your 4Runner model and total weight FREE of charge. We will also work with you on spring rates and proper shock setup. :cheers:
  2. Nov 17, 2023 at 3:44 PM
    Wren
    Wren New Member
    Work with kdss?
    What’s the pricing?
  3. Nov 17, 2023 at 3:58 PM
    AccuTune Offroad
    2.5" Fox Suspension
    Its about $4k for the front and rear complete set. Fox has 2 rear lift height versions, so if you get the longer of the two, we suggest KDSS drop brackets. Front should play just fine with KDSS.
    More kits and pricing here
  4. Nov 17, 2023 at 4:50 PM
    mtothek2210
    mtothek2210 New Member
    Just looked at the website regarding these shocks. Are they set at 2" lift out the box for front coil like fox 2.0? I'm currently running fox 2.0 front and rear w/ B12 400lbs springs looking for an upgrade. Thanks
    AccuTune Offroad[OP] likes this.
  5. Nov 20, 2023 at 7:35 AM
    AccuTune Offroad
    2.5" Fox Suspension
    There are two front coilover options, one is rated for 2" lift, the other is 2-3". This is just a lift range, I am not sure what lift height they will provide out of the box since that is dependent on each vehicles specific weight. Example, 2wd vs 4wd will have different weights that affect lift height. For most cases, we recommend the installer make adjustments after they are installed. When we do installs, we are always making fine tune adjustments. We set ride height based on shock lengths at ride height to get the best overall performance. A lot of specifics about that can be found here: https://accutuneoffroad.com/preload-adjustments-on-oem-fit-coilovers/
  6. Feb 5, 2024 at 12:16 PM
    Tacodaco89
    Tacodaco89 New Member
    14 4runner sr5 4wd
    I have a set of these coilovers on my 14 SR5 4Runner and the reservoirs contact the inner fender with the revised mounts from Fox. I have moved the reservoir down as much as possible and the clamps now contact the fenders. I massaged the inner fender as much as I dare. Is there any other mounting solution for these?
  7. Feb 5, 2024 at 1:35 PM
    AccuTune Offroad
    2.5" Fox Suspension
    Not at the moment.
    Do you have photos of where it was hitting?
  8. Feb 5, 2024 at 1:36 PM
    Tacodaco89
    14 4runner sr5 4wd
    I do not currently have pictures, I will have to take some when I get home
  9. Feb 5, 2024 at 4:52 PM
    Tacodaco89
    14 4runner sr5 4wd
    From driver and passenger side pictures aren’t great due to the angle. This is after moving the reservoirs down on the mounting bracket and trying to clearance the fender some. I have the reservoir clamps in the required position. I could move the clamp down but it’s probably not going to retain the reservoir as well. Prior to moving the reservoir down it had been higher up and shows wear from rubbing on the fender
  10. Feb 13, 2024 at 1:41 AM
    ballz
    ballz New Member
    Bryan
    Bfe Sf Bay Area
    2024 4Runner Trd Pro
    Here’s mine installed on my 24’ TRD Pro. 3” front and 2” rear, Icon 2” rear springs and Icon UCA’sIMG_1092.jpg
    MEski4x4, Mr.DRZ, CygnusX-4 and 3 others like this.
  11. Feb 15, 2024 at 2:52 PM
    Levi9
    Levi9 New Member
    Portland, Oregon
    24 TRD Pro, Super White
    Ballz,
    What’s your wheels specs?
  12. Feb 15, 2024 at 5:00 PM
    ballz
    ballz New Member
    Bryan
    Bfe Sf Bay Area
    TE37xt m-spec 17 x 8.5 -10 with Toyo rt trail 295/70-17
    Levi9[QUOTED] likes this.
  13. Feb 26, 2024 at 8:22 PM
    Tacodaco89
    14 4runner sr5 4wd
    So additional question with these shocks. Both reservoir lines are rubbing on the Total Chaos control arms. The drivers side seems to be worse than the passenger currently. Any solution to stop this aside from trying to move them back up? I could try to roll the reservoir on the mount but I’m doubting that it will move enough to make a difference since the mounts are not great. I’m curious if the original reservoir mounts these came with are any better since I’m not running a front sway bar any more. These are out of the box installed without changing any factory settings. They have been on the truck for roughly 3 weeks to an month and have 300-400 miles tops on them.
  14. Feb 27, 2024 at 12:47 AM
    ballz
    ballz New Member
    Bryan
    Bfe Sf Bay Area
    Let’s see some smaller pics of how it’s mounted. Kinda hard to help with the close up pics
  15. Feb 27, 2024 at 4:53 AM
    Tacodaco89
    14 4runner sr5 4wd
    They’re mounted per the instructions that Fox sends with the shocks on the updated reservoir mounts. Aside from moving the reservoirs down on the mounts so they aren’t rubbing on the inner fender they are installed correctly.
  16. Feb 27, 2024 at 8:25 AM
    Tacodaco89
    14 4runner sr5 4wd
    Got some answers from another thread
  17. Feb 27, 2024 at 10:02 AM
    ballz
    ballz New Member
    Bryan
    Bfe Sf Bay Area
    Turn the driver side resi clockwise a lil and passenger side resi counter clockwise and it should clear better.
  18. Apr 5, 2024 at 9:50 AM
    AccuTune Offroad
    2.5" Fox Suspension
    **UPDATE**
    Several Customers with KDSS noticed an interference issue fitting the Fox reservoir mount that comes with the Fox Performance Elite Series coilovers. This issue is with the passenger side windshield washer fluid tank not allowing the Fox reservoir bracket to be properly mounted. Customer satisfaction is extremely important to us, so we designed a new reservoir mount to specifically address this issue. This design will allow for hassle free installation of the reservoir and alleviate any clearance or interference issues. With the slight angle change to the reservoir, the hose and fittings stay the same, so no need to adjust fittings or lose the gas charge in your shock. Here's a couple of "Before" and "After" Photos to visually explain the difference.
    [Link to AccuTune Mounting Bracket]
    We'd like to clarify that AccuTune Offroad, as a reseller of Fox products, cannot be held responsible for issues stemming from the Fox supplied brackets. Therefore, we cannot accept full liability for problems arising from installation or usage of their brackets. We are committed to assisting our customers who encounter difficulties by providing solutions to resolve any issues they may face. This is why we spent time and resources to produce a solution for our customers.
    **If you recently purchased these coilovers from us, you will get an email shortly**
  19. Aug 1, 2024 at 12:41 PM
    JimBo58
    JimBo58 New Member
    2023 White 4Runner
    what UCA's are you using? and are you set at a two inch height increase?
  20. Oct 13, 2024 at 6:58 PM
    Tacodaco89
    14 4runner sr5 4wd
    Same issue for my non KDSS sr5 just fyi.
  21. Oct 13, 2024 at 7:00 PM
    Tacodaco89
    14 4runner sr5 4wd
    Total chaos upper control arms. The shocks were set at 3 inches of lift from the factory according to Fox. They’ve been lowered to roughly 2.5 inches of lift now. The issue is with the brackets
