Fog Light Operation
Discussion in '5th Gen 4Runners (2010-2024)' started by Pain Level A 10, Jul 6, 2018.
  1. Jan 31, 2019 at 8:17 PM
    4runningMan
    4runningMan New Member
    New Mexico
    I have the Philips LED fogs and they're ok so far on the factory wiring.
    WallyT4R likes this.
  2. Jan 31, 2019 at 8:19 PM
    WallyT4R
    WallyT4R New Member
    I do also, they work well.
  3. Jan 31, 2019 at 8:19 PM
    4runningMan
    New Mexico
  4. Jan 31, 2019 at 8:24 PM
    4runningMan
    New Mexico
    This wiring diagram is from the link for the wiring harness on Amazon. I inserted the 4 arrows. So do these 4 wires all go to the battery-- two per terminal?
    And the relay just gets attached somewhere under the hood?
    What about a ground?
    This would be my first time ever messing with electrical. Just want to be sure I got it right.
  5. Jan 31, 2019 at 8:25 PM
    4runningMan
    New Mexico
    And what is the square thing at bottom center with two reds coming out of it?
  6. Jan 31, 2019 at 8:59 PM
    Sparkkky
    Sparkkky New Member
    2018 4 Runner TRD Off-road
    Eiback Pro lift, ARB Summit bumper, Smitty Bilt wench, Summit flood LED
    Fuse holder
  7. Jan 31, 2019 at 9:19 PM
    jtice
    jtice New Member
    West Virginia
    2016 SR5
    Eibach Pro Truck Lift, 255/75/R17 BFG K02s, TRD Pro Wheels, C4Fab Front Bumper, Smittybilt 9.5 Winch, Rocky Road Super Sliders, BajaRacks Rear Hatch Ladder, SSO Roof Rack, RCI Full AL Skids
    Bottom two arrows goto the battery, two on the right, at the switch, those goto what ever you want to power the "system" with, that basically tells it when the fogs can be turned on or not.
    If you connect them to the battery, you can power the fogs ANY time, even if the truck is off,
    if you connect them to say, accessory power, then you can only turn the fogs on when accessory power is on.
    What you are "switching" with the switch, is the relay. Which really doesnt take much power draw all all,
    The relay is drawing its actual power straight from the battery, and feeding it to the fogs (when the switch is on, making the relay flip closed)
    Agent_Outside and 4runningMan like this.
  8. Jan 31, 2019 at 9:22 PM
    jtice
    jtice New Member
    West Virginia
    2016 SR5
    Are any of you running amber/yellow fog leds?
    I am thinking about running these with yellow film over the stock housings.
  9. Jan 31, 2019 at 9:40 PM
    4runningMan
    New Mexico
    I just deleted a previous post asking a question- I wasn't entirely with you but now I understand. Thanks for the info.
    Can you give me an example of something you'd tap into with the wires in the right for ACC power?
  10. Jan 31, 2019 at 9:41 PM
    4runningMan
    New Mexico
    I'm running the Philips 65k White led fogs with yellow laminX film. They're totally awesome.
  11. Jan 31, 2019 at 9:47 PM
    4runningMan
    New Mexico
    They're not this green in person. But a hint of green due to the 65k color + yellow film. But it's not bad. I'd still call them amber. More amber than I was expecting. I thought they'd be yellow.
    They totally overpower the low beams in the near field. Probably at least out to 30 feet, and much better peripherally than the OEM halogens. And yet they aren't glaring at all to oncoming drivers. Cutoff is still far below the low beams.
    I'm a stickler about not bothering other drivers with light scatter. I will NOT do it. So I had someone drive all around me from every angle and distance to verify they weren't bothersome. They're totally fine.
  12. Jan 31, 2019 at 9:50 PM
    4runningMan
    New Mexico
    Some reviews I read about the Philips yellow led fogs mentioned the yellow coating wearing off with time and use. Apparently they've addressed the problem but I didn't want to take a chance. Plus the white ones were much cheaper on Amazon than the yellow ones were from other retailers.
  13. Feb 1, 2019 at 4:09 AM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    Can't argue with that logic. :D
  14. Feb 1, 2019 at 5:19 AM
    jtice
    jtice New Member
    West Virginia
    2016 SR5
    Not tried it, but there is acually a ACC on the fuse block, upper right, which I would think would work. You can use an add-a-circuit to tap into it.
    https://www.amazon.com/gp/product/B0742BZXC2/ref=ppx_yo_dt_b_asin_title_o02__o00_s01?ie=UTF8&psc=1
  15. Feb 1, 2019 at 5:21 AM
    jtice
    jtice New Member
    West Virginia
    2016 SR5
    I have some yellow film over the fogs on my BRZ, and while it looks cool in the daylight with the lights off, when on they are very sickly green.
    And what they shine on the road even has a green tint to it, I hate it.
    Thats why I will probably go with some sort of amber led.
    Good point on the philips ones, they arent even a true amber led, which is silly,
    these are an actual amber led and people seem to like them alot.
    https://www.xenondepot.com/H16-Xtreme-LED-Bulb-pro-yw-p/xt-led-h16-pro-yw.htm
  16. Mar 28, 2019 at 3:11 PM
    Emmantik
    Emmantik New Member
    2015 Magnetic Grey SR5P
    Sorry to bump an old thread but would a mod like this for a 4th gen be feasible on a 5th gen? I'm not electrical expert or anything just throwing it out there as this seems the simplest way from all the other threads I've read here and on the other forum.
    https://www.top4runners.com/ja/2007/fogmod.html
  17. Mar 28, 2019 at 5:37 PM
    jtice
    jtice New Member
    West Virginia
    2016 SR5
    This is what you want for the 5th gen.
  18. Mar 29, 2019 at 8:34 AM
    Emmantik
    Emmantik New Member
    Yup saw that mod also. But was hoping for something less intrusive and still allowed the fog light indicator in dash to function. As a side note, I did see where Antman added an LED to the indicator but was a lot of work for a silly little light.
    I'm not a big fan of cutting up wires. I'd rather find a plug and play mod in case I ever change my mind down the road or need to revert back to stock. The 4th gen mod was the least intrusive method I found. Hoping there was a way to do the same on a 5th gen but I'm not big on electrical/wiring etc to test and experiment.
    But so far there hasn't been a plug and play work around for this yet...
  19. May 31, 2019 at 6:04 PM
    #49
    AVH128AVH128
    AVH128AVH128 New Member
    Where is the location of the fog light relay on 2019 4runner?
  20. May 31, 2019 at 6:19 PM
    #50
    edgesalon
    edgesalon New Member
    Te
    18 FunRunner :-)
    please up date after your done i am interested in doing this mod also but do not want go the antman's way i appetite all the help
