Fluid Film every year?
Discussion in '5th Gen 4Runners (2010-2024)' started by Technologic80, Dec 17, 2024.
  1. Dec 20, 2024 at 10:41 AM
    Yup, that body mount area is a salt and dirt trap. Both behind the mud flap, and inside it. It has drains holes, but dirt and mud can plug them up.
    I pay extra attention to rinsing those areas out with the garden hose after a trip or in spring after the salt is done flying.
    There’s a lot of little nooks and crannies like this, and only a frame nerd like me will care to find them all. There are a few threads that detail all those areas.
    Oil changes, rotations etc take me forever because I usually end up distracted by doing a spot treatment here or there or just “inspecting”. I usually take my gallon bucket of wool wax and a brush with me whenever I’ going to crawl under it for maintainance. @djwantke is a kindred spirit in this regard…we’ve described it as feeling like michealangelo working on the cistene chapel.
    The best thing for “normal”people to do is remove the spare and engine skid plates and then spray your favorite wet-film product liberally and thoroughly inside and outside the frame, crossmembers, and mounting brackets. Mind the cv boots and rubber bushings. Or pay a thourough person to do it). Then drive it down some dusty gravel roads to build a dry crust. Do this once, and forget about it.
    (A previous post mentioned the gas tank straps. Guaranteed, in 15 years it will be hanging on by a thread if you don’t take care of the gas tank strap.)
    As long as you make sure to regularly rinse the salt off the frame during warm spells or springtime, this treatment will buy you years and years of frame life. Some people don’t like the idea doing an underbody spray if you have a wet film, but since the wet-film cant be perfectly applied, I think it’s good to wash salt off regularly.
    A thorough one time application won’t give you a perfectly rust free frame in 15 years, but it will be good enough. If you actually want perfect, it will need as much attention as a wood boat (no joke).
    But, as they say…perfect is the enemy of good. The goal is to enjoy using the 4runner, and giving it a long service life by making sure the frame outlasts the body and the engine.
  2. Dec 20, 2024 at 4:00 PM
    What do you use to spray inside of the frame’s boxed sections? I need to do a better job at that then just spraying in each hole.
  3. Dec 20, 2024 at 4:14 PM
    Yes I used CRC Marine with similar properties on my Tacoma, which sees off-road use. However, I don't have any local shops that spray this, so it had to be DIY.
  4. Dec 20, 2024 at 4:56 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Ain’t that the truth lol I’ve learned all I know from McSpaz and the gang, if I’m honest
    :laugh: also me (favourite movie):
  5. Dec 20, 2024 at 5:51 PM
    deltabravo
    deltabravo WUBBA LUBBA DUB DUB!!!!1!
    East Coast USA
    I did my 2023 this year and last year
  6. Dec 20, 2024 at 5:57 PM
    Higgbra73
    Higgbra73 Nitrous Fixes Everything
    Brad
    Chicago
    16' SR5 Premium 4WD
    Voxx "PRO's" Bronze (17x8.5) wrapped in 285/70-17 Mickey Thompson Baja Boss A/T's, 5100's with Dobinsons C59-302 2.5" front coils and Ironman 1.5" Light Load rear coils. RCI Engine Skid plate. CAT Shield SS. Freedom Offroad UCA's. 14" Borla Pro XS Muffler (40358)
    Yes, DIY it
  7. Dec 20, 2024 at 10:43 PM
    I used wool wax aerosol cans with the cheap little spray tube/ wand they sell for it. Good enough. Actually, I probably used some fluid film too because it creeps better. The cheap plastic wand doesn’t have a great spray pattern, and it gets messy leaks at the can…so I probably went through a lot more product than if I had a better wand.
    I borescoped some of the holes last year…seems like I got decent coverage.
    However, there are better “cavity wax” products on the market…I kinda like the look of the one that 3M sells. I think it’s an actual paraffin based wax. But a lot of those have pretty strong VOCs and should probably be applied with a paint respirator if you want to avoid a wicked headache. Fluid film isn’t noxious, it just smells like dirty wet sheep. And wool wax smells like…cleaner dry sheep?
  8. Dec 20, 2024 at 10:49 PM
    LOL, that’s probably the face I make when neighbors look at me weird wondering why the heck I need to be under my 4runner constantly “working on it”.
    icebear and Higgbra73 like this.
  9. Dec 21, 2024 at 1:44 AM
    broken-giver
    broken-giver BFD
    Applied once and will re-touch every year. They asked me not to spray underside anymore.
    I honestly don’t baby mine as you do. It’s a truck it better work when I need it. It’s always garaged and I am taking more precaution than what Toyota recommends.
  10. Dec 21, 2024 at 3:01 AM
    Matt83
    Matt83 New Member
    Northeast
  11. Jan 31, 2025 at 1:11 AM
    Technologic80
    Technologic80 [OP] Sexy Member
    Chris
    SE Michigan
    '23 TRD Off Road Premium
    Just an update. Got around to bringing it into the shop, $200 to reapply FF the 2nd time around, the original spray last year was $300. Worth it to me - no rattle cans, laying on my back, mess in my garage or driveway. Anyways he said it still looks brand new down there, not a speck of rust. For future record that’s 1 Michigan winter worth and 10,200 miles at the time of re-coat. Next time I’ll ask to go under and snap some pics just to post every year for comparison.
    TimGinCentralNJ, Sin4R and ChessGuy like this.
  12. Jan 31, 2025 at 1:49 PM
    Shredder
    Shredder New Member
    tip of the mitt, Michigan
    23 OR
    Tires, shocks
    I had mine done with FF in Johannesburg Michigan for $170. But they did not remove the skid plate or lower the spare. They said they get good coverage spraying through the spare wheels holes. Dubious claim, but then I never checked. Maybe this summer, I did a quick look on each side after I got home and it did look good.
  13. Jan 31, 2025 at 2:17 PM
    mac1usa
    mac1usa New Member
    The spare is not bad to just crank down yourself and do that area. I also did the wheel on my spare with fluid film. That’s just more steel to rust.
    Shredder likes this.
  14. Jan 31, 2025 at 2:28 PM
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    If you really want to be thorough, remove the rear bumper skin and spray that area of the frame. I had my bumper off to swap valances so I used half a can spraying down all the metal covered by the bumper skin.
    Technologic80[OP] likes this.
  15. Jan 31, 2025 at 2:35 PM
    Technologic80
    Chris
    SE Michigan
    Johannesburg? I live half time in Lewiston... Surprised we haven't run into each other, I make my way to Vienna every now and then and never see any other 4R's around (well, a month or two ago I talked to some guy with a Green 4R at Glens but thats about it).
    Shredder[QUOTED] likes this.
  16. Jan 31, 2025 at 7:51 PM
    Shredder
    Shredder New Member
    23 OR
    Tires, shocks
    I live near Indian River, but went to Joburg to get my 4runner undercoated. There’s a place in Petoskey that does undercoating but was like 3x as expensive. Lots of 4runners and Tacomas up here, our local dealer is in Cheboygan.
  17. Jan 31, 2025 at 8:05 PM
    mac1usa
    mac1usa New Member
    It’s a small world I spend a lot of time with my family in Onaway and they have a place on Black Lake. It’s heaven up there for me especially being from down state. I get off at exit 310 from 75 in Indian River and get some Vivios pizza before going east. If I could just learn to catch more of the Burt Lake walleye life would be so much better
    Technologic80[OP] and Shredder like this.
  18. Jan 31, 2025 at 8:54 PM
    Shredder
    Shredder New Member
    23 OR
    Tires, shocks
    Big fish here!
  19. Feb 1, 2025 at 2:59 AM
    #49
    mac1usa
    mac1usa New Member
    Yep you got it.
  20. Feb 1, 2025 at 4:22 AM
    #50
    Technologic80
    Chris
    SE Michigan
    I think I see a future meet forming....
  21. Feb 1, 2025 at 6:02 AM
    #51
    roc
    roc New Member
    Michigan
    2021 4Runner TRD ORP
  22. Mar 22, 2025 at 11:15 AM
    #52
    I was under the 4runner today and found a good example of paint separating at sharp corners and a weld beads. Even though it was all well coated with a woolwax crust, if the paint peels off on a corner, water gets behind there and starts rusting. This example shows why occassional inspections and touchups are a good thing if you seek perfection.
    Pictured below, this is the spot on a bracket on the rear axle after I scrapped away the loose paint, and sprayed it liberally with fluid film spray (ran out of WW).
    Tooly likes this.
