FJ shift knob
Discussion in '5th Gen 4Runners (2010-2024)' started by Hillzz, Oct 23, 2018.
  1. Oct 23, 2018 at 7:09 AM
    Hillzz
    Hillzz [OP] New Member
    2018 Bright White TRD Pro
    I just bought a brand new 2018 4runner TRD pro and love it. However, I'm not in live with the large shift nob. I like the compact and neat transfer case shift nob and would like to match it. I did a little research online and it looks like a stock FJ shift job matches up identical. However, I have seen some posts that say it fits a 4runner and some that say it does not. I also saw a post that says if you take off the very bottom silver transition piece this makes the FJ knob fit.
    I need help from someone on this forum that knows the real answer to these questions.
    Can I buy the stock FJ shift knob for my 2018 trd pro? Will it require modifications to fit?
    Thanks all. Glad to be part of the 4runner fam. Below is a pic of what I'm talking about in this post.
  2. Oct 23, 2018 at 9:02 AM
    rkwfxd
    rkwfxd New Member
    Rich
    Whittier - So Cal
    I'd also be interested in this.
  3. Oct 23, 2018 at 1:55 PM
    Rahl
    Rahl New Member
    2018 4Runner
    Watching
  4. Nov 12, 2018 at 2:22 PM
    siblue
    siblue Old member
    Ryan
    Socal
    24 Land Cruiser
    The photo attached is a 5th gen with the FJ knob
  5. Nov 12, 2018 at 6:18 PM
    edgesalon
    edgesalon New Member
    Te
    18 FunRunner :-)
    i be interested in your 19 TRD PRO shifter nob any pictures thanks
  6. Jan 7, 2019 at 11:44 AM
    PaulB-2006 T4R
    PaulB-2006 T4R New Member
    Paul
    Twin Cities, MN
    2016 Trail MGM
    Falken Wildpeak AT3W. Matte Black TRD Wheels. Leveled with 2" spacer. All LED interior. Mud flaps deleted. TRD Air Filter. TRD Oil Cap. Heated Front Seats. FJC Shifter. Subaru Kicker tweeters.
    I also did this minor mod. I found a FJC shifter on eBay and then had to shorten it to fit the Gen5. I love the look.
    jr15642, DrewMan and 7385 like this.
  7. Jan 8, 2019 at 9:39 AM
    Crossfit4Runner
    Crossfit4Runner New Member
    Saint Louis
    2018 TRD Off Road Permium
    To many to list
    What did you have to do?
    ManBeast likes this.
  8. Jan 8, 2019 at 10:46 AM
    ManBeast
    ManBeast New Member
    Zach
    Jax FL
    2014 TRAIL
    Agreed
  9. Jan 8, 2019 at 3:57 PM
    jdevtac
    jdevtac New Member
    04 V8 4WD
    It’s a 2 piece shifter so the top knob pops off the shaft. I’m assuming he then cut the shaft portion down.
    ManBeast[QUOTED] likes this.
  10. Jan 8, 2019 at 4:50 PM
    ManBeast
    ManBeast New Member
    Zach
    Jax FL
    2014 TRAIL
    Intresting. How much is it at dealer? Part number?
  11. Jan 8, 2019 at 5:44 PM
    jdevtac
    jdevtac New Member
    04 V8 4WD
    No idea. I bought one off eBay years back and put it in my Tacoma by doing the opposite of this thread and actually extending it up from the shift rod. I spent $25 for a used one.
    Part #s I found if you are an auto:
    3350435103B0 (w/ metal trim)
    3350435093B0 (w/o metal trim)
    I don’t know what metal trim means. I know the FJ shifters were either gray/black or all black so maybe that’s what it means.
    7385 and ManBeast[QUOTED] like this.
  12. Jan 8, 2019 at 6:33 PM
    ManBeast
    ManBeast New Member
    Zach
    Jax FL
    2014 TRAIL
    Awesome thanks
  13. Jan 10, 2019 at 5:06 PM
    PaulB-2006 T4R
    Paul
    Twin Cities, MN
    2016 Trail MGM
    https://www.ebay.com/itm/1x-Oem-Shi...h=item33a8f0d2a8:g:L8cAAOSwu4BV7ZOC:rk:1:pf:0
    looks like there are 3 available. The shifter has 3 parts to it, the middle pieces pull apart and the silver part on the bottom. I first pulled off the silver piece and it fit but I did not like the look then I cut 3/4" off the middle. Here is a great write up...
  14. Jan 10, 2019 at 5:54 PM
    Crossfit4Runner
    Saint Louis
    To many to list
    Nice, problem for me is I’m terrible with a saw
  15. Jan 11, 2019 at 2:13 PM
    PaulB-2006 T4R
    Paul
    Twin Cities, MN
    2016 Trail MGM
    Me too so I tried a mitre saw for the straight cut, that kind of worked and it didn't. The cutoff piece went flying somewhere yet to be found.
    A&P and Crossfit4Runner[QUOTED] like this.
  16. Nov 3, 2019 at 9:14 AM
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
    Instead of trimming the shaft or taking off the bottom piece of the shift knob, I simply inserted a socket set screw into the shift knob prior to install. It gives just enough space to clear the side of bezel/console when shifting out of park. I used socket set screws, metric M8 x 1.25 x 10mm purchased from our local hardware store. Cost under $2.00 for 2pcs. (only 1 required for this mod, allen keys not included).
  17. Nov 3, 2019 at 8:48 PM
    Dougie
    Dougie New Member
    '19 TRD ORP
    Alternatively, you could just drill and thread a hole in a pepper grinder to have the same effect
    A&P likes this.
  18. Nov 4, 2019 at 6:47 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    I missed this thread when it was originally posted.
    I had a FJ knob from EBay, pull it apart and cut 3/4" from the middle, then reassemble it. Cutting from the middle lets you conceal an uneven cut if you screw it up.
    Nice upgrade.
  19. Aug 20, 2020 at 12:55 PM
    Back from the dead...are these AT shift knobs still available anywhere?
  20. Aug 20, 2020 at 1:06 PM
    CJT4Runner
    CJT4Runner Frosty
    Chris
    ‘20 TRD ORP
    I did see some on EBay.
    https://www.ebay.com/itm/352645792815
  21. Aug 20, 2020 at 2:26 PM
    MeefZah
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    Ebay is the best source.
  22. Aug 20, 2020 at 5:08 PM
    RonH
    RonH New Member
    Ronnie
    Indianapolis, IN
    2019 TRD Offroad
    I ordered mine from Sparks Toyota. Received it in less than a week.
    A&P likes this.
  23. Aug 21, 2020 at 8:37 AM
    Ebay one is about $47, including shipping (from Dubai :eek:), and Sparks' offering is $57.37...edit - Sparks wants $15 for shipping, so $72+/-...
    Question - what is the reason for trimming the middle section? I've read where it's also been installed as is...
  24. Aug 21, 2020 at 8:49 AM
    MeefZah
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    Personally I'd start a saved search on Ebay and give it a month or so, one will pop up cheap and you can snipe it.
    The knob is a hair too long. It has to be trimmed or has to have something inside on the threads to keep from bottoming out (another poster showed his set screw trick). Personally I prefer cutting the mid because it still gives you full engagement of the knob threads, but YMMV
    A&P likes this.
  25. Aug 21, 2020 at 8:57 AM
    Thanks for the insight. I went ahead and ordered the Ebay one...$47.01 to my door.
    I'll check it out once it arrives, and do whatever is necessary for best fitment. I really like that it matches the TC shift knob...
    I may have a TRD shift handle up for sale soon.
  26. Aug 27, 2020 at 1:51 PM
    Ebay FJC knob ordered Monday, arrived yesterday (2-day shipping from Dubai, UAE!), and is a genuine Toyota part, new in the package. I got the length trimmed on my radial arm saw - I started with 1/2" instead of 3/4", just for grins. Before that, though, I threaded the FJC knob onto the shift rod as is, and it actually worked with no trimming, sort of. The only place the lower trim ring hit the bezel was when you move the knob to the right to shift out of P, and just barely. Once you move it back toward the center console into R, N, or D, it doesn't even come close to hitting anything. So for now, 1/2" off. I just need to trim out the small plastic ring inside the lower half of the shaft with either a dremel, a very sharp narrow chisel, or an Exact-o knife.
  27. Aug 28, 2020 at 8:57 AM
    Finished up this morning. I only removed 1/2" from the middle, which gave me plenty of clearance to the shifter bezel:
    MeefZah and CJT4Runner like this.
