First Mods for my 2015 TE
Discussion in '5th Gen 4Runners (2010-2024)' started by Havik, Aug 3, 2015.
  1. Aug 3, 2015 at 6:49 PM
    Havik
    Havik [OP] New Member
    This site panders to vendors and doesn't allow its actual users to post their valid thoughts and opinions.
    Stev0 and UssMoGn like this.
  2. Aug 8, 2015 at 12:50 PM
    wnelax04sr5
    wnelax04sr5 New Member
    Ethan
    CT
    2004 SR5 4X4 Galactic Gray
    you've got quite a good start going!
    Havik[OP] likes this.
  3. Sep 3, 2015 at 1:28 AM
    tundradog2000
    tundradog2000 New Member
    2014 Trail Premium
    Looks Great! What Mods did you have to do to the front end once you put in the Lift? Did you get a alignment? If you used the Lift Kit you referred too did you have to use the Front Diff drop?
  4. Sep 11, 2015 at 9:34 PM
    tundradog2000
    2014 Trail Premium
    Thank you very much Havik. Hope to have mine completed soon enough. Looks great!
  5. Sep 12, 2015 at 10:46 AM
    4X4Runner
    The left coast
    What was the procedure to reset the KDSS? When I installed my OME lift I wrapped a ratchet strap around the cylinders to keep them from moving and installed the lift. I haven't noticed any lean post install.
  6. Sep 16, 2015 at 1:54 PM
    LTDSC
    Northern California
    that looks good, probably my favorite color on those.
  7. Sep 23, 2015 at 11:41 AM
    Balakay
    Balakay New Member
    Blake
    Cleburne, TX
    2017 TRD ORP
    Method MR305, 285 Toyo AT3, ARB Safari Snorkel, King 2.5" F&R w/ Resis, SPC UCAs, Alpine Halo9, FrontRunner Roof Rack, SSO Front Bumper, Warn 10k Winch, Midland MXT275, RCI Skids, Sliders, Magnaflow Catback Exhaust, Dual Battery System
    Do you have any detailed pictures of how you installed the ARB compressor? I'll be looking to do the same on my 2016. Thanks!
  8. Sep 23, 2015 at 4:22 PM
    Balakay
    Balakay New Member
    Blake
    Cleburne, TX
    2017 TRD ORP
    That would be great. Bracket is all I need pictures of. I won't have problems making a bracket but seeing one already done would make it a bit easier. Thanks!
  9. Nov 11, 2015 at 8:23 PM
    J.J
    J.J New Member
    What size tires did you go with?
  10. Nov 11, 2015 at 9:20 PM
    J.J
    J.J New Member
    Thanks. I'm picking up mine next week and the first thing I'm doing is a lift and tires. I'm back and forth between 275/70/R17 and 285/70/R17
  11. Nov 11, 2015 at 9:28 PM
    J.J
    J.J New Member
    From what I've read, 275's are the largest I can go to guarantee I won't have any rubbing.
  12. Nov 11, 2015 at 10:02 PM
    J.J
    J.J New Member
    The plan is to do a 3" lift so maybe I will go with the 285's. Thanks for the advice.
    Havik[QUOTED][OP] likes this.
  13. Nov 19, 2015 at 3:31 PM
    raycie
    raycie New Member
    2016 TEP
    Did you lift the rear at all?? Recently got a '16 TEP w/KDSS and have been reading about the adjustable track bar that is needed...
  14. Nov 19, 2015 at 3:55 PM
    raycie
    raycie New Member
    2016 TEP
    Do you wheel it or just the street??
  15. Nov 19, 2015 at 9:50 PM
    16.T4R@JPN
    16.T4R@JPN New Member
    Muneyuki
    Hello. I have question for you. Do you install wheel spacers too?
  16. Nov 19, 2015 at 10:47 PM
    16.T4R@JPN
    Muneyuki
    thank you your tires go on inside of bodyline? or stick out little?
    I sorry about my english:(
  17. Nov 27, 2015 at 9:48 AM
    J.J
    J.J New Member
    Havik, I'm getting my toytec lift installed next week and going with the 285/70/r17 BFG KO2's. You indicated that you don't have any rubbing with a similar setup, but did you have to do any mods to get to that point?
  18. Jan 25, 2016 at 8:16 AM
    CR_CO_4RTEP
    CR_CO_4RTEP New Member
    15 4R Trail Premium
    I have the same rig with a 3/2 Ready lift. Speaking to the Toyota parts, they suggested going to an 18" rim with the 285s. Said the stock 17 are too narrow and wear faster, mushier in turns, etc. I would think the 18 might ride better but not sure I see much down side to stock rims. The rims are 7.5" which is within the spec of the 285.
  19. Jan 26, 2016 at 9:48 AM
    RIZ4RNR
    RIZ4RNR New Member
    Awesome rig Havik! I'm looking to do the same suspension on my '16. Did you upgrade your UCA's?
  20. Jan 26, 2016 at 3:48 PM
    RIZ4RNR
    RIZ4RNR New Member
    Did you notice any difference after you lifted it? I know when I lifted my Tacoma it felt like it was "skating". It felt like I was on ice skates.
  21. Aug 18, 2016 at 11:34 AM
    BLVCK
    BLVCK New Member
    Taylor
    16 Trail Premium
    N/A
    how do the billys ride? I want the king but 4k is pretty expensive and your lift is perfect.
