Fiber Splicing!!
Discussion in 'Off-Topic Discussion' started by SR5 Limited, Feb 13, 2019.
  1. Feb 13, 2019 at 5:26 PM
    SR5 Limited [OP] New Member
    One of my many rings I have installed. 36 Ribbons, 432 Fibers, Tested with my Optical Time Domain Reflectormeter.E7B89155-026D-4ED7-8F72-AC892375B718.jpg1C09C2C1-866C-4E51-BC0C-79EE43F94DA2.jpgC213FB27-0E57-4068-845E-5F305EF57939.jpg
    That’s a Fitel ribbon Fusion splicer!!! And there’s like seven feet of slack.(never enough)
    LostHusker and scottalot like this.
  2. Feb 13, 2019 at 5:28 PM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    2004 SR5 V6 4WD 4Runner
  3. Feb 13, 2019 at 5:30 PM
    Great trace I zoomed in on all the splice points and double check with Power Meters. You can see the reflection from the connector on the other side.:)
  4. Feb 13, 2019 at 5:32 PM
    5C571F2B-7141-4954-AB8F-372C809E3295.jpg I have a cheat sheet for setting parameters..I’ve seen an 864 opened up and being spliced..
    scottalot likes this.
  5. Feb 13, 2019 at 5:41 PM
    There’s a miss print on this schematic I found it once I think. See if u can find it?
  6. Feb 13, 2019 at 5:49 PM
    scottalot
    scottalot Stockalot
    Scott
    Charleston SC
    2018 T4R offroad
    To be determined
    All I can find is this yellow box missing info
  7. Feb 13, 2019 at 6:20 PM
    4X4Runner
    The left coast
    Fancy!!!
    I miss the old days where we actually terminated fiber and copper.
    I still have the remnants of a 24pr fiber cable that rats had chewed through laying around somewhere. Nothing like unicam terminations in a 19” rack in a military guard shack at 0100 by flashlight.
    I’ve done my fair share of butterfly tool amphenol connectors.
    Also, exothermic welding ground bars!!!
    Takes me back!
    LostHusker and SR5 Limited[OP] like this.
  8. Feb 13, 2019 at 6:21 PM
    4X4Runner
    The left coast
    Color deficiency?
    LostHusker and scottalot[QUOTED] like this.
  9. Feb 13, 2019 at 6:48 PM
    Well shucks, I just went over it again, no misprint. It must of been a different sheet. It’s writin it white on the yellow buffer tube 21..Ribbbon tubes are only “striped” on an 864. I know I found a misprint twenty years ago..
  10. Feb 13, 2019 at 6:57 PM
    And I’ve spliced/tested a custom 516 count cable..
  11. Feb 13, 2019 at 7:03 PM
    I’m running THREE! Lol OTDR’s at the same time...4E405E48-3D0E-483D-98EE-3FF323FB95CE.jpg
  12. Feb 13, 2019 at 7:04 PM
    I just got an adapter for RCA to HDMI so going over my 8mm tapes..
  13. Feb 13, 2019 at 7:26 PM
    That was right before they hit us!!!! You guys got them SOB’s!!!
  14. Feb 13, 2019 at 7:32 PM
    I never touched copper...
  15. Feb 13, 2019 at 7:37 PM
    4X4Runner
    The left coast
    It’s fun! Nothing like terminating patch panels to EIA/TIA standards with sausage fingers!
    I miss that stuff. I could go to work for a telecom company any day and be happy. Working circuits, terminating cable or fiber, splices.
    Makes the hours seem like minutes
    LostHusker likes this.
  16. Feb 13, 2019 at 7:54 PM
    MattAK
    MattAK Headin' for the hills
    Matt
    Utah
    2019 Tundra SR5 dbl cab white
    It took me one time splicing fiber in my cabling class in college to know that's definitely not what I wanted to do with my career. Stuff is hard if you have shaky hands!
  17. Feb 13, 2019 at 8:00 PM
    4X4Runner
    The left coast
    That’s why you need a good fusion splicer! Does all the work for you.
  18. Feb 13, 2019 at 8:14 PM
    I’ve used Xfo and Sumitomo too
  19. Feb 13, 2019 at 8:20 PM
    MattAK
    Matt
    Utah
    Yeah we used one, they're pretty cool. I actually got mine to certify, albeit just barely. My issue was the prep of the fiber. I broke it several times trying to cut and strip it clean because my hands shake when I do fine detail work like that. :annoyed:
  20. Feb 13, 2019 at 8:22 PM
    Want to see the cleaver?
  21. Feb 13, 2019 at 8:31 PM
    FD59C1DD-6647-4337-AFBD-3BBA61E29331.jpg Yes that’s my finger.. Cleaves twelve at one time...E4567B0A-4D92-4C8B-A996-F27D7E562C76.jpg
  22. Feb 13, 2019 at 8:37 PM
    I’m trained in Polarization and Chromatic Mode dispersion testing..
  23. Feb 13, 2019 at 9:13 PM
    I’m nearsighted. So I can see almost like a microscope..
  24. Feb 14, 2019 at 3:10 AM
    scottalot
    scottalot Stockalot
    Scott
    Charleston SC
    2018 T4R offroad
    To be determined
    :notsure: I looked at that for a few minutes
  25. Feb 14, 2019 at 3:23 AM
    The key to doing a mid-sheath entry on a hot 432. You soak the ribbon in alcohol for five minutes to separate the fibers and then complete the tail installation.
  26. Feb 14, 2019 at 9:05 AM
    scottalot
    scottalot Stockalot
    Scott
    Charleston SC
    2018 T4R offroad
    To be determined
    I have absolutely no earthly idea what you’re talking about:rofl:
    LostHusker and WallyT4R like this.
  27. Feb 14, 2019 at 3:05 PM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    Right there with you...:cheers:
    scottalot[QUOTED] likes this.
  28. Feb 14, 2019 at 4:08 PM
    scottalot
    scottalot Stockalot
    Scott
    Charleston SC
    2018 T4R offroad
    To be determined
    :fistbump:
  29. Feb 14, 2019 at 4:26 PM
    LostHusker
    LostHusker New Member
    South TX
    2015 SR5
    Well it’s been a little bit since I logged on but OtDR shot was great, what type of cleaver are you utilizing? Been in the business for 20+ but more of a copper and back in the day PBX guy so fiber is not my strong suite but know what I’m looking at. I now stand up new facilities and bring Ethernet to the desktop for commercial builds, this includes both horizontal and vertical build outs.
  30. Dec 18, 2020 at 11:26 PM
