Error Codes P0345 and C1201 4Runner (4th gen)
Discussion in '4th Gen 4Runners (2003-2009)' started by 4R777, Mar 30, 2022.
  1. Mar 30, 2022 at 5:57 PM
    4R777
    4R777 [OP] New Member
    Engine wouldn't start.
    • Heard a click, but no turn over.
    • Lights on the dash came on and they were bright. Radio worked.
    • Ended up jump starting and drove to auto store.
    • Bought and installed new Duralast Gold Battery 24F-DLG Group Size 24F 750 CCA.
    • Used their scan tool which gave following codes.
    Error P0345
    Camshaft Position Sensor 'A' Circuit (Bank 2)
    Error C1201
    Brake Boost Sensor Circuit
    For P0345
    • Ordered replacement Camshaft Position Sensor - Replace 2CAM0057, 180-0499 Compatible with Toyota, Lexus (Amazon product id: B096QHS6WP)
    • Watched this video on replacing the Camshaft Position Sensor for the 4th gen 4Runner
    For C1201
    • Could be gas gap problem again? Already on my 4th OEM gas cap.
    One website says
    • Large Evaporation system leak
    • Loose/faulty Gas cap
    https://cars-care.net/toyota-c1201-code-problems-and-troubleshoot/
  2. Apr 1, 2022 at 7:00 AM
    iamincrediboy
    iamincrediboy New Member
    South FL
    I mean the 4th gen brake master cylinder is in the engine bay and has electronic connections on it... Have you checked all those for loose wires/bad connections/other visible issues?
