Engine number decoding/ECU & Wire harness question
Discussion in '2nd Gen 4Runners (1990-1995)' started by BryS, Dec 8, 2019.
  1. Dec 8, 2019 at 4:30 PM
    BryS
    BryS [OP] New Member
    I just purchased a 1988 Gen 1 that has what I believe is a 1996 engine in it. The last two digits of the engine number are 96. I'm assuming this is 1996. Does anyone know if this is correct?
    Also, if the above is correct, I'm looking for an ECU and engine wire harness for a 1996 3zve 3.0 M/T 4runner.
    Thanks.
  2. Dec 8, 2019 at 4:34 PM
    BryS
    Another pic...
  3. Dec 8, 2019 at 4:38 PM
    4scooter19
    4scooter19 New Member
    Oregon
    98 and 86 4Runners
    They didn't make 3vze is 96. Does it have a spring tensioner or a hydraulic tensioner for the belt?
  4. Dec 8, 2019 at 5:02 PM
    4scooter19
    Oregon
    98 and 86 4Runners
    From what I know 88-92 uses a spring tensioner and 93-95.5 uses a hydraulic tensioner. Hopefully this helps
    Sorry I should have specified, the timing belt will either have a spring or hydraulic tensioner. So if you have a hydraulic tensioner it's not the original motor.
    BryS[OP] likes this.
