Engine Bay LED Lighting w/ Switch
Discussion in 'Lighting' started by Bluesky 07, Oct 31, 2023.
  1. Oct 31, 2023 at 11:10 AM
    Bluesky 07
    Bluesky 07 [OP] Not a New Member
    Russell
    Northern Georgia
    Switched engine bay lighting on my ’07 Sport is hands down one of my favorite convenience mods. Here’s how I did it; as with everything, YMMV.
    Materials:
    LED strip (Amazon)
    Switch (Amazon) (Amazon's pic shows 5 switches but you can order just one.) Electrical wire (~16 gauge)
    Ring connector
    Your choice of splice connector
    Wire stripper
    3/4“ keyhole bit
    I didn’t want the LED strip to turn on automatically so I added a rocker switch. Mounting it here on the radiator shroud looked like the most convenient place.
    Use a small, regular bit to drill a pilot hole then go to the ¾” keyhole bit to make the opening. Smooth the edges with sandpaper or a file, something I hadn’t done yet when I took the pic.
    The installed switch looks clean.
    Here's where to place the strip. Wipe the metal down first with alcohol on a rag to help ensure the best adhesion.
    Run the wires through the wrap then route the wrap under the hood pad. I brought it out at the driver's side rear corner and used a zip tie to secure it there, then tucked and/or zip tied it along the inside top of the fender up to where the wires connect to the switch, battery, and ground.
    The switch prongs, from left to right in this pic, are:
    1. Left, dark colored: ground
    2. Middle: Battery (constant 12V power)
    3. Right: Red wire from the LED strip
    It's been a minute so forgive me if this is off, but a black wire and a red wire come off the LED strip and - IIRC - this is how everything connects using the prong numbers listed above. Figuring it out is easy enough if this isn't exact:
    1. Run a ground wire off the dark-colored switch prong, splice the black one from the LED strip to it, and connect it with the ring connector to the ground bolt as shown below.
    2. Constant 12V goes to the battery; in my case, a Blue Sea Systems fuse box.
    3. Connect the red wire from the LED strip to this prong.
    [​IMG][​IMG]
    Done. This mod is way up there in usefulness and bang for the buck.
  2. Dec 4, 2023 at 11:36 AM
    trail_runner_93
    trail_runner_93 New Member
    South Central PA
    Looks great! Thanks for the share!
  3. Dec 4, 2023 at 11:47 AM
    BgBmBoo
    BgBmBoo New Member
    Kansas
    Looks like a great way to destroy a spade bit. ;)
    But very good idea! I’ve thought about doing something similar.
