Emergency Flasher Switch Removal
Discussion in '5th Gen 4Runners (2010-2024)' started by gdk67, Mar 17, 2019.
  1. Mar 17, 2019 at 8:10 AM
    gdk67
    gdk67 [OP] New Member
    I recently completed the Takita airbag replacements on my 14 4runner, both driver side & passenger side. Since then, my emergency flashers do not work. PA state inspection is next month and flashers are req'd to pass. I hope the problem is either a bad switch (doubtful) or the switch wires are not connected. The fuse is good. Can anyone help answer these questions?
    What other electrical components are on the same circuit as my emergency flashers? I can check these to help isolate the problem. Also, need some advice on the switch removal to check for connected wires.
    I could take it back to my dealer but I'd rather avoid them if possible. I know they will charge me $$$ to even take a look.
  2. Mar 17, 2019 at 8:17 AM
    Just a guess, but it sounds like they forgot to plug the connection in, but i would take it back, just to be on the safe side, they may have missed something else in the process.
    jester243 and Backslider like this.
  3. Mar 18, 2019 at 7:59 AM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    "You recently completed" or a dealer? Obviously if a shop bring it back. Hopefully the time span isn't to large and they don't tell you "they worked when it left here."
    WallyT4R, jester243 and Backslider like this.
  4. Mar 18, 2019 at 9:04 AM
    gdk67
    Still need to know what other electrical components are on the same circuit as my emergency flashers? I can check these to help isolate the problem. Also, need some advice on the switch removal to check for connected wires. I don't want to screw up my plastic dash.
  5. Mar 18, 2019 at 10:46 AM
    redneckj
    redneckj New Member
    2018 TRD Off Road 4Runner
    working on it
    Take back to your dealer that did the work. have them plug it back up
    WallyT4R, 2016Pro and jester243 like this.
  6. Mar 18, 2019 at 11:34 AM
    jester243
    Dan
    Spokane, WA
    how long ago was the work done, doesn't the work come with a warranty that would cover this even if only for 90 days or so?
