Eibach Stage 2 installed
Discussion in 'Suspension' started by TRDGreen, Apr 13, 2024.
  1. Apr 13, 2024 at 10:57 AM
    TRDGreen
    TRDGreen [OP] New Member
    2022 TRD ORP
    Complete! Ended with about 2” lift up front after alignment and 1.25” in the rear. Out of the box the front was 3.75”-4” lift. I dialed it down to 2” but after settling for 6 hours and a test drive it went to 1.5”. I raised it a bit and had about 2.25”-2.5” before alignment. After alignment it ended at 2” up front which is what I was after. It’s great to be able to fine tune it. Adjustment was very easy. I made my marks on an index card instead of struggling with a measuring tape I marked it on the card. Thanks to Hot shot off-road with a quick one day delivery. @memario1214
  2. Apr 13, 2024 at 11:55 AM
    laxman09
    laxman09 New Member
    Mahoning Valley, OHIO
    Oof that caster. I was annoyed my pass side only was 2.8*
  3. Apr 13, 2024 at 12:00 PM
    TRDGreen
    2022 TRD ORP
    yea once everything is broken in I’ll see if it drops in the front and I’ll get it realigned and see how it goes.
  4. Apr 13, 2024 at 12:05 PM
    iDoc568
    iDoc568 New Member
    23 MGM ORP w KDSS
    Nice! I just installed this same kit on my rig and love it so far. I ended up with a final front height of 2” as well and my caster readings were very similar to yours after I got an alignment. The steering felt loose and unresponsive so I ended up replacing the UCAs. Now it’s much better!
  5. Apr 13, 2024 at 12:24 PM
    TRDGreen
    2022 TRD ORP
    It seemed to drive fine but we’ll see. I have a 2.5” lift on my tundra and JBa UCAs and I’ll say they made that truck pretty smooth. Tundra is my daily. 4Runner is my wifes so I’m not as in tune with how the 4Runner drives. I might throw some JBAs on it at some point.
    iDoc568[QUOTED] likes this.
  6. Apr 13, 2024 at 12:32 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    That looks great. When I put my 2R on I also installed Dobinson's with 3 degrees of castor correction built in which helped my alignment results.
  7. Apr 13, 2024 at 4:18 PM
    Rott4r
    Rott4r New Member
    23 MGM 4Runner TRD orp kdss
    Looks awesome. I Have the stage 2r, happy with them. Your caster might be able to adjust into spec without UCA from the looks of your alignment. Since you don’t have kdss the lower control arm will move/adjust easier. Uca does make the steering feel tighter and drives smoother in my experience.
  8. Apr 14, 2024 at 10:08 AM
    TRDGreen
    2022 TRD ORP
    it’s already settled another 1/4” on top of the original settle of 1/2”. I’ll give it a few months maybe adjust maybe not but either way get it aligned again. I got the Toyota one year warranty alignment and they said I can come back in a few months and get it aligned again under the original cost.
    Mlbdriver, Luna Runner, Rob41 and 2 others like this.
  9. Apr 14, 2024 at 10:22 AM
    garoto
    garoto New Member
    What UCAs did you get? Do they have adjustability for camber? Which would make caster adjustment easier at the bottom. This is the same case for me with Bilstein’s - but the steering feels nice and responsive for me.
  10. Apr 14, 2024 at 10:37 AM
    iDoc568
    iDoc568 New Member
    23 MGM ORP w KDSS
    I got the Old Man Emu UCAs. Caster is fixed and the spec sheet said that it adds 2.5-3.5 degrees. I was able to get closer to 4 degrees and back into spec thankfully.
    garoto[QUOTED] likes this.
  11. Apr 15, 2024 at 9:29 PM
    xrevolver
    xrevolver New Member
    Jarred
    GA
    Great kit and the stance looks good! A buddy is looking to get Eibach as well. He ordered a new set of BFG tires from 4Wheelonline and will start the mod projects next week.
  12. Apr 18, 2024 at 7:20 PM
    Toyotafvr
    Toyotafvr New Member
    Joe
    Looks good OP . I just did the same kit on my wife's Runner. I got the same on the front out of the box 4". The rear I got 2" with the 1" springs . The front has only settled 1/4" after a week and the rear hasn't settled at all . That might be that mine is a 4X2. I will give it same time then make an adjustment. I do agree it rides amazing and my wife loves the look and the ride. I did do the JBA UCA.
  13. Apr 23, 2024 at 11:41 AM
    Luna Runner
    Luna Runner New Member
    Charles
    Oregon
    2023 Lunar Rock ORP
    Stocky stock stock stock....for now. Just got it.
    Would you say the minimum this could have been set to would be 1.5" then? I actually want as little lift as possible in the front so that I don't have to lift my rear a bunch to make up for the extra weight, Tent/Rack/Drawer system/ etc. I'd take 1-1.5" up front for sure, but when I contacted Eibach they said it will give 2" or more but no less....and everyone I've seen with them installed looks like they have a good bit of room to drop that collar even further. and with the approx 2:1 motion ratio, there looks to be about 3/8 to 1/2" of downward adjustment if I had to guess in your pictures? Thanks for posting this!
