Eibach stage 1 stance
Discussion in 'Suspension' started by NYRunner322, Feb 19, 2024.
  1. Feb 19, 2024 at 9:28 AM
    NYRunner322
    NYRunner322 [OP] New Member
    New York
    2022 ORP Midnight black
    Hey guys. I searched but hoping for some final feedback before my appointment in a few weeks. Getting the Eibach stage 1 installed with Dobinsons UCA’s
    The kit is 2.75 front and 1in rear. I was worried i might have some reverse rake at the frame or does it sit perfectly level?? I kinda prefer a little rake debating throwing a small cornfed spacer in the back but not sure how it’s gonna sit. Any one running this kit
  2. Feb 19, 2024 at 9:48 AM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    Great choice. I have the Dobinsons UCAS's but went with the Eibach stage 2R. You can make adjustments on the front with the height adjustable clips on the stage 1 vs adjustable collars on the 2R.
  3. Feb 19, 2024 at 10:04 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    You probably won't have reverse rake. The rear 1" eibach netted me 1.25" of lift.
  4. Feb 19, 2024 at 10:16 AM
    djdaves
    djdaves New Member
    SEPA
    2015 4runner SR5
    lift, wheels, tires, stuff.....
    Heres my setup. Eibach stage 1. I also included Cornfed 1'' spacer in the rear.
  5. Feb 19, 2024 at 12:06 PM
    You're going to be level.
    If you want a little bit of rake, add a spacer in the back.
    hossler1788 likes this.
  6. Feb 19, 2024 at 1:12 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    What do you think of the ride quality of the eibach stage one?
    I had it but recently swapped out of trd pro fox. The rear imo rode rough unless I had weight in the back. But ride quality is so subjective.
  7. Feb 19, 2024 at 1:28 PM
    West Coast, Sierra Mountains
    Maybe just place a spirit level on the frame?
  8. Feb 19, 2024 at 2:34 PM
    Forever
    Forever New Member
    Alex
    5th gen SR5
    Eibach Pro stage 1 suspension. Kenda Klever R/T 33x10.5r17 TRD wheels blacked out Freedom off road UCAs Cornfed 1/2” rear spacer Bodyarmor4x4 Hiline bumper Smittybilt X20 10k winch Roadshock LED light bar Badlands D ring shackles TrailGear roof rack Raptor lights, amber fogs, pro grill, etc.
    I have the stage 1. Spring perches are set to the 3rd level. Also running a cornfed 1/2” rear spacer. It sits pretty even, but I also have a bumper, winch, lights, skid plates, etc up front. If you plan on leaving the front end stock, I’d leave your spring perches at the lower settings.
  9. Feb 21, 2024 at 5:43 AM
    NYRunner322
    New York
    Thanks for the responses guys. I’m definitely gonna throw some corned spacers in the back so I have still have some rake
    nimby likes this.
  10. Sep 30, 2024 at 8:22 AM
    CRasch505
    CRasch505 New Member
    Chris
    Rio Rancho NM
    5th Gen 4Runner ORP
    Trail edition wheels, Falken AT4W 255/80, Eibach stage 1, Super Pro UCAs, OEM rock rails, roof rack delete, no-scoop hood, ceramic tint on all glass.
    Here I come with a dumb question. I also have the Stage 1 kit and I'm not entirely positive which perch setting a set it at. How can I easily tell?
  11. Sep 30, 2024 at 9:21 AM
    Forever
    Forever New Member
    Alex
    5th gen SR5
    There should be 3 or 4 ringed grooves on the shock body. The groove closest to the
    Lower eyelet is the lowest setting for stock weight I believe.
  12. Sep 30, 2024 at 9:24 AM
    CRasch505
    Chris
    Rio Rancho NM
    5th Gen 4Runner ORP
    Ok cool! I believe that's what I'm on. It sits perfectly frame lever but, of course, the truck body still makes it look raked a bit by around 1.25"
  13. Sep 30, 2024 at 8:01 PM
    4RunnerTXgirl
    4RunnerTXgirl New Member
    Dallas/Fort Worth, TX
    2022 Black Off Road
    I’m loving my Eibach stage 1 lift. Nice stance & smooth ride
    poncho65 and JlMBO like this.
  14. Oct 1, 2024 at 12:08 PM
    You have to get a good view of which groove the lower spring perch is sitting on. It can be deceiving because of the domed shape of the perch itself. Might need to crawl under the vehicle with a light and shine it up the shock body from underneath.
    Anywho, the lowest groove indicates zero lift. The 2nd one up is a 0.85" lift. The 3rd one up is a 1.6" lift. The 4th one up is a 2.5" lift.
    CRasch505[QUOTED] likes this.
  15. Oct 1, 2024 at 12:41 PM
    Pepper
    Pepper New Member
    Heath
    East Central Alabama
    2022 ORP Barcelona Red
    How's it ride? I'm between stage 1 with spacer in rear vs a full dobinson twin tube setup
  16. Oct 1, 2024 at 3:57 PM
    CRasch505
    Chris
    Rio Rancho NM
    5th Gen 4Runner ORP
    Ok this makes sense. I can see at least two grooves above the bottom of the spring. Maybe I'm only on the .85" lift setting. Mind if I shoot you a PM later today or tomorrow with some pics?
  17. Oct 1, 2024 at 5:00 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Well if you have the stage one eibach lift. It comes with silver coils springs, which net you 2.5" of lift in the front(lowest clip) and 1" in the rear.
  18. Oct 1, 2024 at 5:07 PM
    CRasch505
    Chris
    Rio Rancho NM
    5th Gen 4Runner ORP
    Ah ok, that’s fair. Maybe it’s just all in my head haha.
  19. Oct 1, 2024 at 10:05 PM
    Commited
    Commited New Member
    Oscar
    So Cal
    2019 Silver Metallic TRD ORP
    Tinted fronts, blacked out overlays.
    I have the Stage 1 and with the rear springs it came with it sat level. I did replace the rear springs to Icon 2” springs because I camp and pull a small trailer, the Eibach rear springs were too soft and made the rear sag big time. Happy with the Icons.
  20. Jan 29, 2025 at 5:39 PM
    glc
    glc New Member
    Gregory
    ‘14 sr5
    i just installed the stage 1 on my rig today. it is sitting 1.25” higher in the rear. is that normal ? could i have fucked something up ?
  21. Jan 29, 2025 at 6:54 PM
    CRasch505
    Chris
    Rio Rancho NM
    5th Gen 4Runner ORP
    You're probably fine. Mine measures somewhere around that as well. How does it look? Also, it's worth noting that measuring it can vary a good amount with the slightest angle on the ground. All in all, a slight body rake is normal from what I've seen and experienced.
  22. Jan 30, 2025 at 7:39 AM
    i have the stage 1 kit also. You're good. mine settled after a couple months. The rear is only shocks and springs. no adjusting. So can't really fuck it up on a height setting.
