Dull Thumps at Start and Stop
Discussion in '4th Gen 4Runners (2003-2009)' started by yoho360, Apr 5, 2022.
  1. Apr 5, 2022 at 11:28 AM
    yoho360
    yoho360 [OP] New Member
    Chris
    2004 4Runner SR5 V8
    none
    Good Afternoon - I'm experiencing a single dull thump when first accelerating and then again when coming to a complete stop. Anny suggestions what this may be? Thanks!
  2. Apr 5, 2022 at 11:45 AM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    Torque converter
  3. Apr 5, 2022 at 11:46 AM
    yoho360
    Chris
    2004 4Runner SR5 V8
    none
    Would it also cause a delay in shifting from first to second? sometimes , not often, it seems to stay in first a little too long.
  4. Apr 5, 2022 at 11:46 AM
    MrSmartypants
    MrSmartypants New Member
    '17 4R TRD Pro
    Front prop shaft binding.
  5. Apr 5, 2022 at 11:52 AM
    LandCruiser
    East Bay Area
    5th Gen OG TE
    Yes. I had the same problem with a six speed in a GM truck.
  6. May 27, 2022 at 9:58 AM
    TX4runner21
    TX4runner21 New Member
    B-Rod
    Dallas, Texas
    '07 V8 4x4 T4R
    Fox Suspension, LFD Rack, Magnaflow Muffler
    Your driveline (propellar shaft) needs to be lubricated. A lot of the v8's have it, I do as well. Servicing the trans can help as well, lots of opinions out there tho in regards how to depending on mileage. I'd ask a toyota mechanic and follow their advice.
    kolter45 likes this.
  7. May 27, 2022 at 9:41 PM
    When was the last time you greased your driveline? If you have 4wd there are two zerks on each driveshaft on the transfer case side, and one on each driveshaft on the differential side.
    You just have to be careful greasing the zerks for the slide yoke since too much grease on those can pop a seal. The regular Ujoint zerks you can keep pumping grease till you see it come out the center cross-looking thing. Easy to do, just watch a video or two.
    if I dont grease them every 15,000 miles or so, I can end up hearing a bit of a dull thump. I think it’s just the little bit of slop when they dry out.
    nomad_4runner, cdevs67 and 2Toys like this.
  8. Jun 18, 2022 at 12:51 PM
    SnakeDoc
    SnakeDoc New Member
    Eric
    Just a suggestion, had something similar happened, by my own fault, I neglected to tighten one wheel after changing brake pads.
