Driver side lower than passenger side after lift kit
Discussion in '5th Gen 4Runners (2010-2024)' started by 1961 TRD, Mar 16, 2021.
  1. Mar 16, 2021 at 3:34 PM
    1961 TRD
    1961 TRD [OP] New Member
    yoram
    2021 4Runner TRD
    lift kit
    Hi I'm new here
    I got 2021 4runner TRD off road premium, I had icon lift kit put 3 weeks ago
    icon 2.5 adjustable 0 - 3.5 in the front,
    icon 2.0 with oil reservoir in the back. new coil in the back 1" higher.
    when job was done the driver side was lower than the passenger 1/2'' in the rear
    3/4" in the front, the front shocks adjusted the same, no kdss
    can anyone suggest why ?
  2. Mar 16, 2021 at 3:57 PM
    Mtbpsych
    Mtbpsych New Member
    Well, what’s your lift in the front? Lol 0”-3.5” tells us nothing. You probably need to adjust them. They’re coilovers, shouldn’t be hard for you to do. You probably need to adjust drivers side coilover to compensate for the lean you get from a full tank of gas. I have a .5” spacer on the drivers side shock for this reason, so you probably just need to crank up the drivers side coilover by .5”
    Look up specs on how much lift you get from turning the coilovers.
  3. Mar 16, 2021 at 5:24 PM
    Need to adjust drivers side for compensate for the lean.
    Not sure why the rear is off I say do the front first.
  4. Mar 16, 2021 at 7:18 PM
    1961 TRD
    yoram
    2021 4Runner TRD
    lift kit
    Thanks
  5. Mar 16, 2021 at 11:27 PM
    pcstockton
    pcstockton New Member
    Its a 4RNR They ALL lean that way. Tank and driver on same side.
    Get a fridge and mount your spare on the passenger side. Done.
  6. Mar 17, 2021 at 9:35 AM
    So when he throw a load on the drivers side it leans again? Best idea I've heard.
  7. Mar 17, 2021 at 9:49 AM
    Like the others said, adjust the coilovers to compensate.
    I load heavier items on the passenger side as well to try balance it out. My coilovers are adjusted the same on both sides and I don't have a noticeable lean.
  8. Mar 17, 2021 at 9:59 AM
    Not sure if its the talent of the installer. Here's my measurements;
    <Update this is ELKA suspension not ICON. It was pretty much same when I had OME>
    (Screen capture from my Youtube video)
