Drive Shaft Grease Gun
Discussion in '5th Gen 4Runners (2010-2024)' started by 4Runner22, Apr 25, 2020.
  1. Apr 25, 2020 at 7:49 AM
    4Runner22
    4Runner22 [OP] New Member
    2019 VooDoo Blue 4Runner TRD Pro
    I recently purchased a Grease Gun from Lock N Lube to lube my drive shaft. It has a Max PSI of 5000. A friend of mine recommended a more heavy duty Grease Gun with a Max PSI of between 7000 to 8000. Do you I really need a grease gun that puts out that much PSI? Or my 5000 PSI grease gun should work just fine?
  2. Apr 25, 2020 at 8:04 AM
    I'm sure you'll be fine.
    Mine's rated for 6,000psi and I had zero issues.
  3. Apr 25, 2020 at 8:20 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    I didn't even realize grease guns had a PSI rating! Any old shitbox grease gun will work fine.
    Crikeymike and thirdyota like this.
  4. Apr 25, 2020 at 8:47 AM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    Same here. Never seen that before.
  5. Apr 25, 2020 at 8:53 AM
    4Runner22
    I didn't know that either until my friend pointed it out. Here's the one he has.
    Here's the one I bought. The yellow one is rated at 8000 PSI the green one is at 5000 PSI.
  6. Apr 25, 2020 at 8:58 AM
    4Runner22
    In my opinion I really don't think you need a HIGH PSI Grease Gun for 4Runner drive shaft like some of you said any will do. I'm just asking to make sure and to see what are your thoughts about the heavy duty grease guns.
    How much PSI does it take to push that grease into the zerks? I'm sure 8000 is whole lot of push right?
  7. Apr 25, 2020 at 9:30 AM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
