Door sill rust...
Discussion in '5th Gen 4Runners (2010-2024)' started by Oey12, Oct 8, 2019.
  1. Oct 8, 2019 at 2:23 PM
    Oey12
    Oey12 [OP] New Member
    Joey`
    2017 SR5
    Eibach Pro Sport leveling shocks, Firestone airbags, and Baja Design fog lights...
    Literally as I getting ready to go to work I noticed a small bubble right next to the plastic door still plate on my front drivers side door. I scratched it with my fingernail and it was all rusty. I can’t post any pictures till tomorrow because I have my commuter car. But has anyone else dealt with this? And how would I properly repair it? I am planning to take the plastic will plate off this week...
  2. Oct 8, 2019 at 2:53 PM
    Oey12
    Joey`
    2017 SR5
    Was able to get them sooner...05524BF1-E587-49AE-87C6-56E975583C52.jpg 36074A25-E450-4EDE-8F92-34724C54B922.jpg
  3. Oct 8, 2019 at 3:32 PM
    Remove cancer paint be done with it.
    Hopefully it doesn't go all the way under.
    KSJ08 and Strandskov like this.
  4. Oct 8, 2019 at 6:50 PM
    Oey12
    Joey`
    2017 SR5
    Is it better to sand down or use a wire brush? And as far as sealing should I coat it with anything before I use touch up paint?
  5. Oct 9, 2019 at 6:01 AM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    since this is a very small rust spot looks like the plastic strip had a high spot that worn down the paint in that rust area. removal of that plastic piece is tough you need the plastic pry tools Harbor freight has them ..
    use a small piece of metal to carefully remove the rust. wipe it down with mineral spirits then use a primer paint touch up .. do it 3X .. do not use too much on each prime. sand the edge of the plastic with some fine sand paper so that plastic is smooth.. then after a few days put the color touch up on that spot .. give it a week before it is hardened ...
  6. Oct 9, 2019 at 6:51 AM
    Oey12
    Joey`
    2017 SR5
    Thanks! Here are more pictures...12051D97-ADC1-45B3-95C5-6712032BECFE.jpgCBAEA479-B8D1-46E8-BE5F-37DB19A78F4D.jpg
  7. Oct 9, 2019 at 7:49 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Might be something worth swinging by the dealership about
  8. Oct 9, 2019 at 7:57 AM
    I am guessing this is from stepping on the plastic trim piece getting in and out of the vehicle? This caused the paint to wear off so i am not sure the dealership would cover that.
    KSJ08 and Oey12[OP] like this.
  9. Oct 9, 2019 at 8:14 AM
    Oey12
    Joey`
    2017 SR5
    I agree that the dealership probably isn't going to do anything but I feel at that point it will be documented though a dealership and I will most definitely go through corporate as well. My opinion is that a plastic sill that was factory installed should not cause this much damage on an above average cleaned vehicle. Meaning frequent washes year round which included all possible areas for rust..doorjams/sills etc etc. If its documented I will have grounds in the future if there is even a recall or something similar. I am almost thinking about going to an auto body shop to have it professionally fixed if Toyota doesn't take care of it. Just for the purpose of having it air fingers quote "professionally" fixed.
  10. Oct 9, 2019 at 8:57 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    I know on most enthusiast forums like this one, we love to bash the dealerships and treat them like they are vile cash sucking monsters who wants nothing more than to rape your family and destroy your vehicle...
    BUT
    Outside of documentation (which is a great start) some dealerships out there are helpful, some are worth less than a wet newspaper. It's worth talking to your service department regardless. Ultimately you're right, no reason for a factory door sill to cause that damage to a factory door on factory paint.
    WallyT4R, toy33 and Oey12[OP] like this.
  11. Oct 9, 2019 at 10:31 AM
    thirdgen
    thirdgen New Member
    Ive had good luck gixing rust by taking it down tobthe metal with phosproric acid. Kills the rust and leaves s primable surface.
    There are several spray versions or you can buy it in bulk.
  12. Oct 9, 2019 at 10:45 AM
    Prob has something to do with eletrolisis? Put an oversized AGM battery in on the next change and ground that sucker good....
  13. Oct 9, 2019 at 11:08 AM
    thirdgen
    thirdgen New Member
    Probably not electrolysis. It isnt happening atcany joints ir dissimilar metals.
    Sitting on 4 rubber tires isolates you from outside " charges". The battery source has nothing to do with it.
  14. Oct 9, 2019 at 11:16 AM
    j cat
    j cat New Member
    massachusetts
    LOOKS LIKE THE FACTORY DID NOT PUT THE PROPER AMOUNT OF PAINT !!!
    TOO THIN . BRING TO DEALERSHIP .Your pictures are very good ...
    Oey12[QUOTED][OP] likes this.
  15. Oct 9, 2019 at 11:18 AM
    I know but they do install Zinc Anodes on engines/metal that come in contact with water. So by adding one somewhere to attract/absorb the corrosion is a thought?
  16. Oct 9, 2019 at 11:23 AM
    Agent_Outside
    Built 2011 T4R Limited
    Every new vehicle comes with a corrosion warranty.
    Oey12[OP] likes this.
  17. Oct 9, 2019 at 12:11 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Truth be spoken!
    Toyota's is 60 month/60,000 miles
  18. Oct 9, 2019 at 12:40 PM
    Oey12
    Joey`
    2017 SR5
    I called my dealership and they are awesome! My paperwork is getting submitted within the next few days. And I am dropping the truck off next week.
    batman900, toy33, 4Runner fun and 2 others like this.
  19. Oct 9, 2019 at 6:25 PM
    4Runner fun
    Ryan
    Nebraska
    Just so all know...
    You would be surprised @ how thin the paint is on a Toyota. When we took ours in for the Xpel wrap with 900 mile on it. It still took $900 in paint corrections (some caused by the dealer). Anyhow, the Xpel installer said Toyota paint is 0.02" inches. He said it is the only flaws with Toyota's. I may be a little off as that was 6 months ago & I have a lot going on.
    Joey,
    I hope your dealership helps you as they should!
  20. Oct 9, 2019 at 6:45 PM
    Oey12
    Joey`
    2017 SR5
    The dealership actually has been awesome so far. That told me they are contacting corporate first but the told me it will be fixed. They were surprised at the year, color, and level of damage. And they clearly saw how well kept my truck is so clearly it’s nothing I caused.
    j cat, SCMountaineer, toy33 and 2 others like this.
  21. Dec 6, 2019 at 6:48 PM
    Oey12
    Joey`
    2017 SR5
    I got my truck back today and I am very pleased. The auto body guys weren’t the cleanest but I have to say Crestmont Toyota in Pompton Plains NJ did right by me. You can barely tell it was painted. Not all dealerships are horrible...there is hope.
  22. Dec 6, 2019 at 7:25 PM
    4Runner fun
    Ryan
    Nebraska
    Congratulations on the repair! I am glad the dealership stood behind you.
    Any before & after shots? Also, any problem areas to look out for, or was this a door alignment issue?
    Much thanks,
    Ryan
  23. Dec 7, 2019 at 8:04 AM
    Oey12
    Joey`
    2017 SR5
    Here are the fixed pictures. I got real lucky when I dropped the truck off. A representative for Toyota quality assurance happened to overhear my conversation with the service manager and asked if he could look at it. He said he never heard or see anything like my problem on the 4Runner and he personally helped with the case. He helped get both front sills refinished and painted. If it wasn’t for the dealership and this gentleman fighting I believe Toyota would have told me to take a walk.
  24. Dec 7, 2019 at 8:07 AM
    Oey12
    Joey`
    2017 SR5
  25. Dec 7, 2019 at 8:09 AM
    Oey12
    Joey`
    2017 SR5
    And they put some heavy duty clear plastic under the plastic so it doesn’t rub the paint again.AAF3C86A-CAE6-45BB-9EF5-F4E84CD3CACB.jpgFABD4224-D411-430E-AC44-EC1C05DF4636.jpg
    WallyT4R and 4Runner fun like this.
  26. Dec 7, 2019 at 8:22 AM
    toyotabuiltnotbought
    toyotabuiltnotbought New Member
    1987 4Runner
    Lifted
    Wow, they did a great job!
    Hard to believe a truck that new would start rusting already. Do you live where they Salt roads, or where vehicles tend to rust?
    I'd look over that truck carefully for anymore spots.
    For future reference, whenever you see rust, be sure to sand it down (wire brush takes off the bulk, but you will want to remove as much as you can) all the way around it, even onto the solid metal along the edge of the rust spot. Of course if the dealership will cover it then that's #1.
    I treat all the rust I encounter with this stuff called Ospho. It works magic, I believe I bought a bottle pretty cheap of Amazon. Turns the rust into another substance that you can sand or brush off. A few coats of it and rust will not come back.
  27. Dec 7, 2019 at 8:56 AM
    Oey12
    Joey`
    2017 SR5
    Thanks I am always looking around for rust spots and things of that nature. I was pretty surprised myself especially how often I cleaned and waxed those areas but the NYC area gets heavily doused with salt for the lightest of storms. But in all honesty I will always have a concern for this particular 4Runner...maybe this will be the end of it. Luck really hasn’t been on my side with my 4Runner...I had this rust issue, my hitch is flaking very badly already, the middle of my drivers seat is heavily worn, and I need a front windshield to a chip, and my rear passenger side window has a huge gouge in it. Some of these can be attributed to quality in my opinion but I still love my truck.
  28. Dec 7, 2019 at 11:32 AM
    4Runner fun
    Ryan
    Nebraska
    Congratulations, looks beautiful. Glad they took care of you!
  29. Sep 1, 2023 at 2:03 AM
    TheSponge
    TheSponge New Member
    I know it’s an older thread, but I’d rather revive this then start a new but are there other areas that should be done with this clear protective film? Curious as I want to do this to a newly acquired 2016 I got.
  30. Sep 1, 2023 at 6:10 AM
    @Oey12 hasn't been around for a while; sold his 4R and got a Tundra. As far as your question - I imagine any spot you feel might get moisture and/or wear would be a candidate for the clear film protection.
    regius123 and TheSponge[QUOTED] like this.
