Do you use different tire pressure than what's on the door jam?
Discussion in 'Wheels & Tires' started by Elvis4R, Oct 19, 2022.
  1. Feb 1, 2024 at 3:51 PM
    richierrich13
    richierrich13 New Member
    Richard
    Still sensitive for 2023 models. Door says 32 but after talking to the dealer I just learned they now recommend 35. Anything above 38 or below 28 triggers the sensors. I had mine at 32 and last night the temperature was just at freezing which dropped my tire pressure to 27 all around and triggered the warning!
  2. Feb 1, 2024 at 7:51 PM
    The dealer recommends 35? Or, Toyota does? It seems weird to change the recommended tire pressure when nothing else has changed. I'd follow the manufacturer's recommendation over the dealer.
    icebear, wdsteven and Toy4X4 like this.
  3. Feb 2, 2024 at 2:42 AM
    wdsteven
    wdsteven New Member
    Agree Tire Pressure should be set to manufacturer's specs when "Cold" not after driving a crap load of miles or more, if you check your pressure before you drive it could be 32 Psi then you drive for a few miles and check it again you will see that it went up 2 or 3 more.
  4. Feb 2, 2024 at 12:12 PM
    Pentangler
    Pentangler Happy Member
    Chalk test is best & increase cold psi when loaded up or towing.
  5. Feb 2, 2024 at 1:09 PM
    34 psi cold for me
  6. Feb 2, 2024 at 1:15 PM
    2016Pro
    Door jamb, easy peasy
  7. Feb 2, 2024 at 7:27 PM
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    Math is quicker than a chalk test...and more accurate (well, at least if you can math it is). Almost everything else you said is wrong too...
    BC Hunter likes this.
  8. Feb 2, 2024 at 7:28 PM
    mainerunr
    Maine
    '23 TRD ORP
    Sensors on a 23 do not trigger above 38, I've had 42-44psi in mine for over a year (stock size LT).
  9. Feb 3, 2024 at 3:09 AM
    wdsteven
    wdsteven New Member
    :popcorn::popcorn::popcorn::popcorn:
  10. Feb 3, 2024 at 2:33 PM
    Shanky
    Shanky New Member
    Wouldn’t something like 15 PSI maximize contact patch?
  11. Feb 3, 2024 at 2:37 PM
    Yes it would, thats what i run off road.
  12. Feb 15, 2024 at 10:21 AM
    mtnslyr
    mtnslyr New Member
    How accurate is this site tiresize.com? It’s telling me to run 25 psi, that can’t be right.
  13. Feb 15, 2024 at 12:42 PM
    Yeah, that's weird. Toyota recommends 32 for an SL 265/70/17.
    That calculator is good for switching to tires of a different size or load range.
    mtnslyr[QUOTED] likes this.
  14. Feb 15, 2024 at 2:07 PM
    West Coast, Sierra Mountains
    For standard all weather ‘street’ tires like the Bridgestones that were equipped on my T4R the stated pressure works just fine. After switching over to Mickey Thompson’s Baja Boss XLs I run 38-40 psi.
  15. Feb 15, 2024 at 2:13 PM
    Door jamb plus one cold works for me.
    2016Pro likes this.
  16. Feb 26, 2024 at 8:46 AM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    I run 40 PSI in my trucks for decades.
    Not sure if that's good or bad.
    So don't expect anyone to follow suit.
  17. Feb 26, 2024 at 9:35 AM
    J.A.
    J.A. New Member
    NY
    2007 4Runner Sport 4WD V-8
    www.top4runners.com
    same here, 40 psi.
  18. Feb 26, 2024 at 1:46 PM
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    I use 34 PSI cold on all 4. I get a good patch on Toyo Open Country AT3's. They cover the ground from side to side, completely, but aren't showing any unusual wear. IE: they wear evenly, side to side. They ride nice, good wet and snowy condition traction, and they steer quite well. Decent mileage. Not great, like 20 MPG, but right about 19 MPG, as long as I drive decently. Stay easy on the clutch, and brakes. They grab good if I need sudden, hard braking action.
    It took me a bit to re-learn good clutching habits, and gas/brake pedal control, after I lost my leg, but I'm getting better all the time :)
    Just my personal experience.
    Pat☺
    Toy4X4 likes this.
  19. Feb 26, 2024 at 1:58 PM
    #49
    Careful, by contact patch on street driving is one thing, maximizing traction off-road by airing down is an entirely different purpose. Airing down for off-road allows a tire, more specifically the tread to conform to irregular surfaces. In street driving the contact patch is defined by a line (of varying thickness) that runs transverse to the wheel itself so if you are referring to running 15 psi on the street, well, that's an accident waiting to happen.
  20. Feb 26, 2024 at 2:04 PM
    #50
    Basedon the stock tire size and load range, 40 is a little high for a 4Runner. The biggest negative to overinflated tires would be uneven wear. Severely overinflated tires could also reduce traction, and cause a rough ride. But, a lot of people run a few PSI over the recommended pressure without issues.
    Toy4X4 and BS67 like this.
  21. Feb 26, 2024 at 2:40 PM
    #51
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    Really depends on the tire in particular. When I ran Hankook Dynapro AT's on my Titan they liked the OE pressure recommendation. My Duratrac's liked a bit higher pressure.
    Toy4X4 likes this.
  22. Apr 9, 2024 at 10:53 AM
    #52
    2016Pro
    Door jam for me, easy peasy
    BC Hunter and RumHamRunner73 like this.
