Differential Oil Question
Discussion in '5th Gen 4Runners (2010-2024)' started by Cowboy59, Dec 24, 2022.
  1. Feb 20, 2024 at 12:45 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
  2. Feb 20, 2024 at 1:50 PM
    I used Ravenol SAE 75W in the TC on my Tacomas. Now use it in the TC of the SR5. No problems.
    3JOH22A likes this.
  3. Feb 21, 2024 at 4:11 AM
    4R4L_2023
    4R4L_2023 New Member
    24' XP UndGrnd 23' XP Mag Grey
    Staying Stock
    Ravenol straight 75W (This is for transfer case only). Use any name brand 75W-85 GL-5 for front/rear diff.
    https://www.blauparts.com/ravenol-manual-transmission-fluid-mtf-3-75w-1l.html
    Edit: 75W MTF-3 (equivalent to GL-3, GL-4) is a ultra-low sulfur content oil and does not react with brass or copper. CCN mentioned only manual transmission has brass syncro-ring that can be damaged. Since Ravenol makes 75W affordable to us then I don't see why not.
    BS67 likes this.
  4. Feb 21, 2024 at 6:30 AM
    Dawglover08
    Dawglover08 New Member
    Jordan
    Atlanta
    2020 TRD ORP
    How much does it cost to do on your own?
  5. Feb 21, 2024 at 6:52 AM
    MooreKen
    MooreKen 2023 TRD PRO “Solar Octane”
    I did a lot of research and over thought this one but after watching the CarCareNut, etc I went with Red Line from Amazon shipped direct from R/A Hoerr which is an authorized seller of Red Line (MT-LV Transfer Case)(75W85 front and rear Diffs)IMG_0600.png
    nimby and Rocko9999 like this.
  6. Feb 21, 2024 at 8:46 AM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    This is exactly what I have in the garage awaiting my next change.
    MooreKen[QUOTED] likes this.
  7. Feb 21, 2024 at 10:45 AM
    This is exactly what I did.
    Closest aftermarket oil viscosities and ratings to stock.
    Cheap insurance!
    MooreKen[QUOTED] and Rocko9999 like this.
  8. Feb 21, 2024 at 10:57 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    $25 per axle thereabouts.
  9. Feb 21, 2024 at 10:58 AM
    Rocko9999
    2011 Limited
    Me too. Red Line is good stuff.
    MooreKen and nimby[QUOTED] like this.
