Dashcam - which fuse?
Discussion in '5th Gen 4Runners (2010-2024)' started by Curlystooge, Apr 26, 2023.
  1. Apr 26, 2023 at 12:20 PM
    Curlystooge
    Curlystooge [OP] Member
    Flyover
    2022 limited in magnetic grey
    2022 Limited adding dashcam, anyone have a recommendation for a fuse location for add-a-fuse. (Switched)
  2. Apr 26, 2023 at 12:26 PM
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    2016 4Runner TRD Pro, 2023 Tundra Platinum Hybrid
    Which camera are you running and how do you plan to run it?
  3. Apr 26, 2023 at 12:32 PM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
  4. Apr 26, 2023 at 12:36 PM
    Curlystooge
    Flyover
    Using a viofo A119 out for my old car. Have the existing cable to add to fuse box. My limited does not have access port on rear view mirror and I currently have everything I need to install.
    JETSPD1477 likes this.
  5. Apr 26, 2023 at 1:16 PM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    P/OUTLET is ACC switched.
  6. Apr 26, 2023 at 2:34 PM
    Curlystooge
    Flyover
    Good call, p outlet it is. Thanks to all of you.
  7. Apr 27, 2023 at 7:50 AM
    Curlystooge
    Flyover
    Oppps, add a fuse limited to 10amps. P outlet is 15. So, will find another slot.
  8. Apr 27, 2023 at 7:58 AM
    Tap it into the rear view mirror. There are easy easy easy kits on Amazon with the connector and fuse built in. I did my radar detector that way. Very clean install
  9. Apr 27, 2023 at 10:27 AM
    Curlystooge
    Flyover
    I will take a look. Tks.
  10. Apr 27, 2023 at 11:36 AM
    yeah no problem and if you still go to the fuse panel go with the 7.5 ACC fuse in the bottom right of your picture. That way when you turn on the car it turns on and when you shut it off it also shuts off
  11. Apr 27, 2023 at 5:57 PM
    Curlystooge
    Flyover
    Ordered the dongar rear view mirror wiring. Hope to get it next week. Thanks.
  12. Apr 27, 2023 at 6:14 PM
    Awesome. Congrats. You will love how clean your install looks.
  13. Apr 27, 2023 at 7:08 PM
    Curlystooge
    Flyover
  14. Apr 27, 2023 at 7:17 PM
    I watched a few videos on the Dongar adapter installation. This one was the most helpful.
    a66 likes this.
  15. Apr 27, 2023 at 7:58 PM
    Curlystooge
    Flyover
    Thanks Cap’t, seems simple enough.
  16. May 6, 2023 at 3:39 PM
    Curlystooge
    Flyover
    Well, not totally simple. It was a little struggle with the plastic pieces, BUT all is well that ends well. Very happy with the result. Thanks for the help!
    Captain Spalding likes this.
