Dash cam suggestions
Discussion in 'Audio & Video' started by edgesalon, Aug 31, 2020.
  1. Aug 31, 2020 at 9:58 AM
    edgesalon
    edgesalon [OP] New Member
    Te
    18 FunRunner :-)
    I need help Guys & Gals please guide me on what is a good Dash Cam to purchase any info will be useful to me thank you
    User friendly would be nice
    What would makes one good or bad
  2. Aug 31, 2020 at 11:15 AM
    Agent_Outside
    Built 2011 T4R Limited
    I was between the Thinkware Q800Pro and the Blackview dr900s, those were the two best to pick from. I cant remember why specifically I opted for the Thinkware over the blackvue but I did. Nowadays the Blackvue is dated and the competition has left it behind. Thinkware u1000 is the probably the best on the market right now. That said I’m about to buy another Q800Pro for the wife’s highlander
    edgesalon[OP] and DreamsComeTrue like this.
  3. Aug 31, 2020 at 11:24 AM
    DreamsComeTrue
    DreamsComeTrue New Member
    2020 Venture
    Did you hard wire it or are you using a battery?
  4. Aug 31, 2020 at 11:25 AM
    Mtbpsych
    Mtbpsych New Member
    edgesalon[OP] likes this.
  5. Aug 31, 2020 at 11:51 AM
    Agent_Outside
    both, kinda.
    I built a pretty elaborate dual battery setup, everything that is not factory on the vehicle is ran through and auxiliary fuse/relay panel and powered by the second battery second battery which is protected by its own low voltage disconnect. The only place I have anything connected into the stock electronics anywhere is a ignition on signal for the dash cam and the DCDC charger.
  6. Sep 2, 2020 at 6:19 AM
    dcgarcia5
    dcgarcia5 New Member
    2020 4Runner OR
    Anyone knows of an article or youtube video on installing the camera on windshield and hard wiring it on 5thgen?
  7. Sep 2, 2020 at 6:36 AM
    Agent_Outside
    There’s no 1 correct way and it depends on what you’re installing easiest way is fuse taps, one for key on power, one for constant power, and ground. Just make sure the cable isn’t routed somewhere that can interfere with curtain or knee airbag deployment.
  8. Sep 10, 2020 at 12:39 PM
    toddsing
    toddsing New Member
    Todd
    2019 White SR5 Premium XP 4Runner
    Morimoto XB LED Headlights All Interior LEDs
  9. Sep 10, 2020 at 12:59 PM
    edgesalon
    Te
    18 FunRunner :-)
    I went VAVA its really small nice has GPS and parking sensors you control from an app and it connects to the holder via magnets give you a long wire and a cigarette lighter adapter will update after a little time thanks every one
  10. Feb 27, 2021 at 6:16 AM
    retired
    retired New Member
    Al
    2017 Magnetic Grey 4Runner Limted
    I also purchased the Garmin 46 and looking to install it. The dongar connection is nice and neat, except it does not activate the parking mode feature. To access Parking Mode you need the hardwire cable from Garmin.
  11. Feb 27, 2021 at 11:14 AM
    T4Rrunning
    T4Rrunning New Member
    I tried the garmin 56 first and was not impressed with the quality. The Viafo V119 V3 is much better and cheaper.
  12. Sep 16, 2021 at 1:44 PM
    sduck
    sduck New Member
    2021 4runner TRD Off Road Premium
    I installed the blackvue 900x dual system in my 2021 TRD ORP, hardwired. It works well. Fairly easy install once you figure out what you need to do.
  13. Sep 22, 2021 at 2:23 PM
    gkomo
    gkomo New Member
    San Diego, CA
    2004 4Runner Limited V8
    If you want super simple, and cheap, YET quality video, the Apeman C450 was a great choice for me. Buy a MicroSD card, put it in, hide some wires and use a 12v source and bam you are in business. It doesn't record sound, only records whatever way your camera is facing (no back and front). It just continuously records over itself in 3 or 5 minute increments up to the capacity of the memory card. I finally had a close call and i wanted to check the camera out and was very surprised at how good the quality was for like a $50-60 camera.
  14. Sep 22, 2021 at 4:00 PM
    I've used Viafo a119 ($89.90) on 2 4runners and they are very good. I've tried BlackVue DR590X ($189.99 ) and not that impressed for more than twice the price I paid for it.
    Last weekend I installed the newer 4K Viafo a129 pro duo (Front and Rear dash cam) on a Telluride & Palisade.
    SlvrSlug likes this.
  15. Oct 20, 2021 at 8:17 PM
    Crank_Mancastle
    Crank_Mancastle Professional Wanker
    Austin
    2016 Trail Premium
    Eibach Pro Truck kit Ironman Pro-forge UCS's Rocktrix RT110'S in bronze, 17x9 Toyo AT3'S 285/70/17
    I have the Viofo 129 pro duo in my 5g. Works great, only real issue is I need to 3D print a mount for the rear camera so I can screw it in instead of using 2 sided tape. Couldn't be happier with it.
  16. Oct 20, 2021 at 8:42 PM
    I wish there is someone selling that mount on Amazon or some safe payment platform. I love to have a rear cam.
  17. Oct 21, 2021 at 4:33 AM
    BourbonNcigars
    BourbonNcigars New Member
    I've been researching dash cams for far too long. Talk about analysis paralysis. There's so many choices out there now.
  18. Oct 21, 2021 at 6:37 AM
    Crank_Mancastle
    Austin
    2016 Trail Premium
    I found some 3D printing instructions from either Reddit or one of the forums a while back that I saved, I just need to get a 3D printer and get it done. Seemed like the best option so I could shoot a small screw into the mount and use the factory push plug thing to keep it in. I'll put up a few pictures when I get it done.
  19. Oct 21, 2021 at 10:20 AM
    I thought that's TRD Pro :p
  20. Oct 22, 2021 at 8:24 AM
    Scoobyvroom
    Scoobyvroom New Member
    2020 Tundra
    Had a Thinkware in my Taco and nothing but problems. Overheating, not recording. PITA.
    Have a Viofo A129 Dual and love it. Putting one in the wifes car soon.
    Ordered from here and had it within a couple days:
    https://www.blackboxmycar.com/
    kmeeg[QUOTED] likes this.
  21. Oct 31, 2021 at 5:21 PM
