CTH folding mirrors
Discussion in '5th Gen 4Runners (2010-2024)' started by Daytonaviolet, Sep 5, 2020.
  1. Sep 8, 2020 at 6:52 PM
    Daytonaviolet
    Daytonaviolet [OP] TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
    And the other two pairs of wires are self explanatory, each pair connects to a motor in the mirrors :)
  2. Sep 8, 2020 at 6:59 PM
    Mowerman
    Mowerman New Member
    David
    2020 limited 4Runner
    Congrats on who has them and ordered them. Post all your videos, info or questions here. It will only help the people out on the forum!!..
    Daytonaviolet[OP] likes this.
  3. Sep 8, 2020 at 6:59 PM
    Daytonaviolet
    Bay Area, CA
    Then perhaps I don’t need to make a DIY :)
  4. Sep 8, 2020 at 7:06 PM
    Daytonaviolet
    Bay Area, CA
    I want to add this issue you may run into. Once you take apart the mirror housing, you’ll see a round metal plate with two holes. You can release this plate with a pair of needle nose pliers. Under the plate is a spring and plastic washer. Just rotate it until it lines up with the shaft sleeves. It will then release. As long as the metal plate is removed while the mirror is in the unfolded position, the spring will not shoot out. Once removed, the plate, spring and washer will no longer be used.
    Mowerman likes this.
  5. Sep 8, 2020 at 7:12 PM
    Mowerman
    Mowerman New Member
    David
    Awesome! Fantastic to know
  6. Sep 8, 2020 at 7:13 PM
    Daytonaviolet
    Bay Area, CA
    When swapping out the mirror arms with the motorized mirror arms. Make sure to remove all the screws on the new motorized arms. These screws will not be used and may effect fitment if accidentally left on. The original mirror arms screws (qyt 7) will all be reused.
  7. Sep 8, 2020 at 7:31 PM
    energie23
    energie23 New Member
    Canada
    2017 4Runner TRD PRO Cement Grey
    Please still make one :)
  8. Sep 8, 2020 at 7:40 PM
    Daytonaviolet
    Bay Area, CA
    Hope to be complete by tonight ;-)
    energie23[QUOTED], Mowerman and DVS1 like this.
  9. Sep 8, 2020 at 7:45 PM
    DVS1
    DVS1 New Member
    Ray
    Oahu, HI. to Tampa, FL.
    18 TRD Off Road Premium w/KDSS
    Fuzzy dice
    Following for install video.
    Mowerman and Daytonaviolet[OP] like this.
  10. Sep 8, 2020 at 8:49 PM
    Jemplyr77
    Jemplyr77 New Member
    Brian
    Oklahoma
    2019 MGM Nightshade
    Tinted windows. USR tail lights.
    Ordered with 20% off!
  11. Sep 9, 2020 at 1:59 PM
    Daytonaviolet
    Bay Area, CA
    Attaching DIY installation guide. Let me know what you think and i'll make some updates if needed
    DIY
    erfer1, DVS1, siblue and 3 others like this.
  12. Sep 9, 2020 at 2:55 PM
    Mowerman
    Mowerman New Member
    David
    :hattip::cheers:
    I can’t speak for anyone else but I’m sure they would agree. This is exactly what we needed. Thank you for making this happen because I know it takes time to do. Again, thank you
  13. Sep 9, 2020 at 3:10 PM
    Jemplyr77
    Brian
    Oklahoma
    2019 MGM Nightshade
    Thanks Daytona! I am sure this will come in very handy when my set finally arrives...probably next month.
  14. Sep 9, 2020 at 3:28 PM
    Daytonaviolet
    Bay Area, CA
    Just trying to help out as others helped me :)
    ElectroBoy likes this.
  15. Sep 9, 2020 at 3:39 PM
    Daytonaviolet
    Bay Area, CA
    Your welcome :)
  16. Sep 9, 2020 at 7:19 PM
    energie23
    Canada
    Awesome! Thank you for the writeup!
  17. Sep 10, 2020 at 7:54 AM
    Daytonaviolet
    Bay Area, CA
    My pleasure :)
  18. Sep 14, 2020 at 10:00 PM
    Daytonaviolet
    Bay Area, CA
    I chose DHL and got mine in 10 days
  19. Sep 27, 2020 at 9:11 AM
    #49
    Mowerman
    Mowerman New Member
    David
    Good morning all. I just wanted to 1st thank Daytonaviolet for posting his detailed how to. It was really straight forward but I want to add 1 thing.
    When I was looking at the website for these actuators it only went up to ‘18 or ‘19 but NOT 2020. Still thought it would work though. Received them yesterday and installed them this morning. I bought these for a 2020 limited and all worked install wise EXCEPT the unlock detection wire. Can’t speak for any other years/models other than 2020 limited with smart key BUT the harness for the power/lock/unlock is NOT the same. There is NO unlock detection wire in that harness. I pulled my multimeter out and metered the wires in the drivers door where the solenoid is and found that it is a GREEN wire and NOT WHITE. it is in a black 12 pin harness (pin 1 ) right above the harness containing 12v and lock detection. I will include a photo so if anyone runs into the issue I did, here is the answer. EVERYTHING works as expected!
    Thanks again!
    David
    onaquest and Daytonaviolet[OP] like this.
  20. Sep 27, 2020 at 11:10 AM
    #50
    Daytonaviolet
    Bay Area, CA
    so the location of the white wire was completely missing ?
  21. Sep 27, 2020 at 11:23 AM
    #51
    Mowerman
    Mowerman New Member
    David
    Yes, completely missing. Before just probing every wire in the kick, I just made it easy since the door panel was off and went to the source to at least find the color of wire. Obviously hoping it didn’t change color from the door to the kick or from 1 color going in the harness and a different coming out. Gauge of wire was the same, so I easily identified it and luckily it was in that black harness right above in pin 1.
  22. Sep 27, 2020 at 11:35 AM
    #52
    Daytonaviolet
    Bay Area, CA
    thanks fir the info. I’ll update the DIY :)
    Mowerman[QUOTED] likes this.
  23. Sep 27, 2020 at 1:08 PM
    #53
    ATCRich
    ATCRich New Member
    Rich
    2020 Super White TRD ORP
    Thanks for all this info guys. I'll be ordering these for my @)@) 4R TRDORP. This is the one option I always felt was missing!! YAY!
  24. Sep 28, 2020 at 6:17 AM
    #54
    Hrjaw
    Hrjaw New Member
    Roger
    2019 TRD ORP
    Ironman lift, JBA UCA
    Does anyone have a current coupon code for CTH?
  25. Sep 28, 2020 at 9:24 AM
    #55
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Here’s a PSA:
    I placed my order on 9/9/2020 and paid for faster DHL delivery. Well, it’s been 20 days and no delivery. I got an email from them on 9/19 saying the order was “shipped”. But when I click on the tracking link it still says today for the latest status that it is being prepared for shipment. On a slow boat from China I presume. Buyer beware.
    Origin Post is Preparing Shipment -> We have received notice that the originating post is preparing to dispatch this mail piece.
    2020-09-20 02:47
    CHINA, GUANGZHOU EMS, Processed Through Facility
    2020-09-20 00:20
    2020-09-19 20:41
    CHINA, Acceptance
  26. Sep 28, 2020 at 1:53 PM
    #56
    Mowerman
    Mowerman New Member
    David
    That stinks... I just looked at my order and I purchased on the 9/9, opted for the free slow boat. Got it on the 26th and installed. Sorry to hear that.
    I’m sure it will be here soon.
  27. Sep 28, 2020 at 5:09 PM
    #57
    Daytonaviolet
    Bay Area, CA
    have you reached out to the folks on the CTH group?
  28. Sep 28, 2020 at 8:37 PM
    #58
    Jemplyr77
    Brian
    Oklahoma
    2019 MGM Nightshade
    Ordered mine on the 11th and tracking reads the same as Electroboy. Not upset as it said up to 65 days but looks like you got your quick!
  29. Sep 28, 2020 at 10:06 PM
    #59
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Yes, I reached out and they did respond tonight. They made a mistake and did not give me the expedited DHL delivery. They apologized and will refund my extra delivery payment. And if I don’t get the item next week they will re-send it via DHL. So I’ll just wait and see what happens next week. Fingers crossed.
  30. Oct 12, 2020 at 10:32 AM
    #60
    20RORP
    20RORP New Member
    Now that I see the kit works with the 2020 this looks perfect! Is there an available coupon code? Thanks!
