Cornfed 1" rear spacers and driver side lean?
Discussion in 'Suspension' started by sv102, Jul 30, 2020.
  1. Jul 30, 2020 at 5:32 PM
    sv102
    sv102 [OP] New Member
    2019 ORP
    Bilstein 5100s Cornfed 1” rear spacers
    I had a dealer install Bilstein 5100 on all four corners today (1.75" in the front) and 1" Cornfed spacers to the rear (stock coils). I noticed that the whole driver's side (front and back) has 0.5" lean. Is this supposed to happen with the Cornfed spacers. I thought that the driver side spacer was taller to compensate the lean? Or could it be that the dealer installed the spacers wrong way around?
  2. Jul 30, 2020 at 7:58 PM
    Mtbpsych
    Mtbpsych New Member
    Common issue with the 4runners, when your gas tank is on the full side it’ll sag on the drivers side. It can be remedied by installing a .25” spacer on the front drivers side.
    sv102[OP] likes this.
  3. Jul 30, 2020 at 8:18 PM
    ForRun
    ForRun 4Runner
    2020 orp
    Commonly discussed but did you ever try the gas thing? I did. Pulled into station near empty. No one in car. Measured all 4 corners and for those that know me I'm anal for accuracy. Filled the tank up and all 4 corners did not move so much as a 32nd. Nada, zip, zero
    This is with Eibach springs. Never tried it oem
  4. Jul 30, 2020 at 8:21 PM
    sv102
    2019 ORP
    The tank is indeed almost full. I guess I’ll have to measure again once the tank is almost empty.
