Removing condensation from headlights?
Discussion in 'Lighting' started by Azores4runnin, Jul 28, 2021.
  1. Jul 28, 2021 at 4:40 PM
    Azores4runnin
    Azores4runnin [OP] New Member
    Fernando
    2018 4RUNNER limited
    Anyone know the best way to remove condensation in my headlights without removing them?? I just noticed the other day where it’s been hot here in Toronto Ontario
  2. Jul 28, 2021 at 4:47 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Are your dust caps properly installed?
  3. Jul 28, 2021 at 4:51 PM
    kmeeg LionRunner
    ...or drilled for HIDs?
    Pics front and rear?
  4. Jul 28, 2021 at 5:14 PM
    doxidad
    doxidad New Member
    Tom
    NE Ohio
    2024 TRD ORP White w/KDSS
    I had that problem with one of my headlights when I replaced the bulbs with LEDs. I found that the dust cover wasn't on correctly. To dry it out, I took the dust cover off and placed a hair dryer on hot and high pointed into the headlight cavity. I think it took about 45 minutes or so to clear out the moisture. After replacing the dust cap and checking it to make sure it was on correctly I haven't had a occurrence of moisture again - that was over 2 1/2 years ago. These covers were also drilled but sealed with silicon.
  5. Jul 28, 2021 at 5:31 PM
    Azores4runnin
    Fernando
    Yeah I did put leds in and cut out a hole so I’m figuring condensation I ordered new dust caps hopefully will solve the problem and I most definitely will try fiancé’s hair dryer hope I don’t Burt it out or else I will be sleeping in the dog house . Much appreciated for the advice
  6. Jul 28, 2021 at 5:32 PM
    Azores4runnin
    Fernando
    Oh and by the way I wanted to get new OEM HEADLIGHTS do you know a reliable source that I can purchase a pair and not from the dealer that will cost me a lung and liver here in Canada
  7. Jul 28, 2021 at 5:41 PM
    Dillusion New Member
    KYle
    You mean just the bulb? Go to your local auto store and buy.
  8. Jul 28, 2021 at 5:54 PM
    Azores4runnin
    Fernando
    No the whole headlight assembly for both sides
  9. Jul 28, 2021 at 5:56 PM
    Azores4runnin
    Fernando
    And I stay away from halogen bulbs Toyota makes great rides but there bulbs are awful
  10. Jul 28, 2021 at 5:57 PM
    Azores4runnin
    Fernando
    I put in H11 GTR ULTRA 2 awesome LEDS and lasfit has sone great bulbs also
  11. Jul 28, 2021 at 6:07 PM
    kmeeg LionRunner
    I used HIDs in the past with drilled holes on dust cap. I was always worried about this problem. Then I got GTR Ultra 2 and got 2 new dust caps as well.
    https://youtu.be/ADUV156Rr7c
  12. Jul 28, 2021 at 8:30 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Do you need new headlight housings? I would use large desiccant pack in each headlight, seal it properly and wait a few days. That condensation will be absorbed and the headlights will be good to go.
  13. Jul 29, 2021 at 12:12 PM
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    Some white rice, before it's cooked, in a small bag made of women's nylons, will absorb a huge amount of moisture.
    There's also, of all things, cat litter, made up of the crystals that are used for holding liquid in women's pads, diapers, plants without dirt, etc etc. Readily available in pet stores, and on-line from pet sources like Chewy, and so on.
    Again, a small bag made of women's nylons filled with the litter will absorb a ton of moisture. It's also cycleable. Once the crystals absorb moisture, it can then be dried out. A short stint in an oven on warm, they get dry as a bone again, ready to absorb like crazy once more.
    I keep a couple socks, one inside the other, filled with the stuff in all my vehicles. It absorbs moisture out of the interior, reducing the amount of fog on the windows and windshield when it's cold out.
    You can even our some rice, or the cat litter crystals, into the headlights directly, and then dump it out when the moisture's been absorbed. Both cheap, easy to obtain, solutions.
    The dehydrator packets mentioned above have the same crystals the cat litter is made of in them, and are readily available at most firearms stores. Many people throw a few into their gun cases to keep their guns from rusting during storage. The cat litter crystals are just a cheaper source. Couple them with a pair of L'Eggs (anyone still use those??) and you've got all the dehydrator packets of whatever size you desire.
    Have fun!
    Pat☺
