Compatible Tires and Wheel Spacers
Discussion in 'Wheels & Tires' started by RonD105, Feb 24, 2024.
  1. Feb 24, 2024 at 9:57 AM
    RonD105
    RonD105 [OP] New Member
    2023 Black 4Runner SR5
    I haven’t seen a thread like this yet but was thinking people can post their tire/wheel spacer sizes so others (like myself) can get an idea for what works and what doesn’t without have to do trimming and without any lift kit.
    For context, I’m looking to put on wheel spacers on my 4Runner SR5 but I have no clue what will or won’t rub. I currently have 265/70R17 tires and stock TRD wheels. I don’t have the resources to do any trimming or to add a lift kit myself. I was thinking about 2 inch spacers but I’m afraid they’re going to rub and I barely see anyone saying they use 2 inch spacers. I’d also like to keep this tire size. If 2 inch spacers don’t work what size will with this tire size?
    Thoughts please, or if there’s already a thread like this please share!
  2. Feb 24, 2024 at 10:38 AM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    For every inch of spacer you are adding 25.4 mm of negative offset. Using 2" spacers is 50.8 mm of negative offset!
    Even with your 265/70/17 tires, you'll likely rub the mud guard on the front, the lower front wheel well possibly the body mount. Two inch spacers will also cause premature ball joint and front end component wear.
    Go ahead and google wheel spacers @ 4Runner forums and you'll find plenty of threads about spacers. FYI, doing a lift does not negate the increased arc the wheel/tire makes or the relationship of interference i.e. body mount.
    djwantke likes this.
  3. Feb 24, 2024 at 10:49 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Hey OP,
    1.25" spacers are common and are probably as big as you should go. But certainly people run 2" spacers and even negative offset wheels at the same time, for a super wide stance. But, those people certainly wear out a number of front end parts.
    I run 1.25" Spidertrax wheel spacers in black aluminum.
    And I have 0 offset wheels (9" wide though).
    I rubbed all sorts of sh*t. And I have a lift.
    Even with stock, positive offset wheels (+4-+15mm), 100% you're rubbing and chopping. But you can't chop. Don't do 2"
  4. Feb 24, 2024 at 10:51 AM
    Do I clear body mounts if I do an 8" lift!? Haha
    RonD105[OP] and Rob41[QUOTED] like this.
  5. Feb 24, 2024 at 10:54 AM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    Lol, wheel much bro ;)
  6. Feb 24, 2024 at 10:59 AM
    RonD105
    Wow ok so 2 inches is probably overkill then. Ok thanks for the info guys!
  7. Mar 4, 2024 at 3:42 PM
    Hilux1
    Hilux1 New Member
    Jon
    2024 TRD Off Road-Premium
    I have a similar question. Been surfing around the forum and haven't seen anyone with the stock ORP wheels with a 1.25” spacer mention rubbing or not. I traded my Tacoma last weekend and had spacers on it. Took them off before I traded the truck and turns out, they are the same part number.
    Since I have these sitting here, I’d like to put them on but it’s brand new and would prefer not cut anything on it just yet.
    Anyone with a stock ORP add a 1.25” spacer and experience rubbing or not?
  8. Mar 4, 2024 at 4:40 PM
    this gentleman has a similar setup, but +5mm offset wheel as opposed to your +15mm.
    Do you have a lift, or aftermarket UCA's?
  9. Mar 4, 2024 at 8:02 PM
    Hilux1
    Hilux1 New Member
    Jon
    Nope, just picked it up a few days ago. Completely stock as of now. I do plan to lift it but that’ll be later on. Just had these from my Taco and figured why not…..but wasn’t sure how much it would rub. I may go ahead and install them this week and just check full lock to see if or where it rubs.
  10. Mar 6, 2024 at 10:50 AM
    jason5641
    jason5641 New Member
    Jason
    Quakertown, PA
    2023 ORP w/KDSS
    I maybe trimmed 3/8 to a 1/2 inch from the front bumper overhang. Can't see it at all. And I had 10 mm more "poke" offset if reading right. Took like 5 minutes. Easy job. I am totally stock also. Orig tires at 10k even
    Hilux1[QUOTED] likes this.
  11. Mar 6, 2024 at 2:36 PM
    Hilux1
    Hilux1 New Member
    Jon
    Thanks for the info. I may go ahead and install these spacers this weekend.
  12. Mar 6, 2024 at 2:49 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Just want to add this tidbit of knowledge. Spacers and shims are two different things. Never use shims! That is all :)
    Hilux1 likes this.
