Clicking/popping noise front end on articulation
Discussion in '5th Gen 4Runners (2010-2024)' started by Pavo, Jun 30, 2024.
  1. Jul 5, 2024 at 4:32 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    That test would rule out the latch, but not necessarily the hinges.
  2. Jul 8, 2024 at 12:10 PM
    Pavo
    Pavo [OP] New Member
    2Toys, Kyblack76, HuskyMike and 3 others like this.
  3. Jul 8, 2024 at 5:04 PM
    Interesting…. Are the coils factory height? Or did they just sag over time. That’s a whole lot of sagging!
    Actually, wait a minute. Do you have the isolators on top of the coils? I’m having a hard time imagining how they could be so loose. Maybe they’re missing?
    Edit: good catch, by the way. I had my coils make a clicking sound a while back after I sprayed some woolwax near the coil seats. Thankfully they quieted down once I sprayed them down with some brake clean
    edit 2: I wonder if they moved because they weren’t clocked/indexed correctly on the seat. The coil end fits into a notch in the seat. It should be impossible to move them in one direction. It would also be extremely difficult the other direction because I’m pretty sure turning the coil end away from the notch effectively requires compression of the coil (it’s like a ramp).
  4. Jul 8, 2024 at 5:35 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    was guessing installed wrong myself
  5. Jul 8, 2024 at 5:37 PM
    Pavo
    Interesting if anything you would think the woolwax would help lubricate and dampen any noise instead of causing it
  6. Jul 9, 2024 at 7:39 AM
    I think the woolwax lubricated the seat and allowed the coil to shift slightly as the suspension moved. Those little micro-movements caused snap/pop sounds. I think everything locks in better when the coil/seat interface is clean and bone dry.
    Pavo[QUOTED][OP] likes this.
  7. Jul 9, 2024 at 11:03 AM
    Pavo
    That actually makes sense
  8. Jul 9, 2024 at 11:45 AM
    That’s my story, anyways, and I’m sticking to it! :D
    I’m curious, how did you fix the loose coil? Is the isolater/internal bumstop installed?
  9. Jul 9, 2024 at 2:23 PM
    HuskyMike
    HuskyMike New Member
    Was it jacked up while you were doing this? I'm trying to figure out how you could turn a spring with the vehicle weight resting on it unless something else is missing.
  10. Jul 9, 2024 at 2:46 PM
    If the coils were loose enough to turn by hand, what's supporting the rear of your 4R?
    Acesandeights likes this.
  11. Jul 9, 2024 at 4:09 PM
    Pavo
    I’m sorry yes jacked up I have some dobinsons on order hopefully it fixes it o wasn’t a fan of my ome coils they are way too stiff
  12. Jul 17, 2024 at 5:45 AM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    Per usual, its usually something stupid. Good shit mate. Happy adventures.
  13. Aug 7, 2024 at 9:25 PM
    Pavo
    To update anyone who cares I finally got my dobinson rear coil springs and swapped them in and the noise indeed went away so it was my ome coils making the noise
    McSpazatron, 2Toys and HuskyMike like this.
  14. Aug 8, 2024 at 2:23 AM
    HotelMedicis
    HotelMedicis No Commercial Interests
    Sounds like a lot of work
  15. Aug 8, 2024 at 6:04 AM
    wafersmith
    wafersmith New Member
    2018 TRD off-road
    I had a similar issue after my lift where the sway bar was contacting the skid plate. I have kdss and the spacer in the system. After cutting out the opening on the side of the skid plate about 1/2 inch larger it’s all good now.
    Pavo[OP] likes this.
