Click noise in reverse from front end (video)
Discussion in 'Wheels & Tires' started by DavidLRoth, Aug 8, 2022.
  1. Aug 8, 2022 at 12:44 PM
    DavidLRoth
    DavidLRoth [OP] New Member
    2017 4Runner Limited
    I hope you can view the video?
    I'm getting this click noise, consistently from the passenger front (sometimes drivers too), in reverse. Not in drive.
    Had the shop foreman at my dealership listen and he says "it's the caliper". That isn't a caliper noise.....so I'm hoping someone here has had a similar issue.
    This started after a trip to a hilly area a couple months ago. Noise started then, and only in reverse. I was baking up onto a steep driveway everyday for a week.
  2. Aug 9, 2022 at 4:17 PM
    PC836
    PC836 New Member
    Fresno, Ca
    2022 White 4Runner PRO
    Have you try jacking up the vehicle, not on gear and spin the tires to see if it reproduce the noise? Check front suspension, nuts and bolts. to see if anything is loose. Maybe a rock stuck in between caliper and pads. Sound sure like metal to metal. GL.
  3. Aug 10, 2022 at 8:10 AM
    Deuxdiesel
    Deuxdiesel New Member
    SE MI
    '18 SR5P
    Hmm, mine does the same thing.
  4. Aug 10, 2022 at 8:20 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    Is the click happening while backing up - and braking? If so, it could be the emergency brake self adjusting.
  5. Aug 11, 2022 at 1:48 PM
    Deuxdiesel
    SE MI
    '18 SR5P
    Mine comes from the front end, and is louder when the skid plate is off. I could maybe see stuck caliper pins or something brake related because the sound is very similar to the sound the baking plates make when gravel pings off them.
  6. Aug 12, 2022 at 12:27 PM
    DavidLRoth
    Thanks for the responses. The sound happens when I press the brakes in reverse, not forward. The sound probably is brake related.....had to think long on this one, but it makes sense. It's just the loudness of it which was making me second guess that.
  7. Aug 18, 2022 at 7:07 PM
    KYFHO
    KYFHO Generic Scumbag
    UT
    2017 SR5P with some stuff
    I just went through this. I had an alignment done a month ago. Started having the exact problem you are describing last week. I crawled under my 4R this afternoon and checked the LCA bolts. They were all at 65-80 ft/lbs. I torqued them down to 129 torques (fun!) and tested it out. No sound yet, I’ll see how it goes. It goes back to the shop on Monday. Hopefully my bushings aren’t torched.
  8. Aug 19, 2022 at 7:43 AM
    Agreed on LCA torque to 130.
  9. Sep 22, 2022 at 2:42 PM
    Zano77
    Zano77 Teflon Zan
    Zano
    2022 TRD ORP
    Dobinsons 1.5" front coils, stock height Dob's rear coils,.60" rear spacers, Dob's twin tube shocks
    I had this issue on my Tacoma after about 10k miles. Its the brake pads shifting slightly in the calipers when the brake is applied at very slow speed.. The noise happens at the guide pins on top of the brake pads. I solved the problem by adding an additional brake pad retaining spring (shaped like W) on each caliper. Each caliper has a place for an upper & a lower retaining spring but for some reason they only install one of these springs from the factory. Cheap & easy fix.
  10. Sep 22, 2022 at 2:51 PM
    i dig it!! Nice work!
  11. Sep 22, 2022 at 7:48 PM
    ShimStack
    ShimStack New Member
    Ben
    NC
    '91 Truggy & '16 Tacoma Locked F/R
    40's, lockers, crawl box
    Absolutely brake pads shifting when you apply the brakes. Try the clips.
  12. Feb 27, 2023 at 10:10 PM
    calli
    calli New Member
    2021 TRDOR 4runner
    I'd been having this problem recently. Turns out the clip had popped off the inner pad. 30 second fix with a flat blade screwdriver - no jacking or wheel removal needed.
  13. Dec 31, 2023 at 3:29 PM
    Brad14
    Brad14 New Member
    Did you ever find out if it was the brakes?
    Mine is doing exactly the same noise. Front passenger side.
