Changing your own oil
Discussion in '5th Gen 4Runners (2010-2024)' started by PCRIDE4RUNNER, Apr 16, 2024.
  1. Apr 16, 2024 at 5:23 PM
    PCRIDE4RUNNER
    PCRIDE4RUNNER [OP] New Member
    SUPER DUPER
    I’ve always done my own oil knowing that I can do at on my time, and do it right without breaking other things, like stripping out the skid plate, running the 4runner through the dealer car wash , scratching the bottom of the doors with vacuum, getting oil all over the inside…. Thanks Toyota.
    Anyways, dealer charges about $60 per change and handles all the disposal.
    Who changes their own oil and is the process pretty straight forward? Drop the skid plate, replace the filter, replace the oil drain seal, refill the oil. Is that about all there’s to it?
    TrailSpecial22 and ColoradoTJ like this.
  2. Apr 16, 2024 at 5:29 PM
    Yes. Buy the Motivx tool kit to make life easier.
    vthoky, lyodbraun, Static03 and 4 others like this.
  3. Apr 16, 2024 at 5:32 PM
    Bagman
    Bagman Dental Floss Tycoon
    Georgia
    Very simple process with one caveat; if the dealer torqued the filter housing on to 100 ft/lbs like they have a tendency to do, it'll be a pain to remove it without a breaker bar or something more... Once the 1st change is completed, easy peasey from then on. I installed a Fumoto valve on mine (as I do on all my vehicles) to make it easier and no mess.
  4. Apr 16, 2024 at 5:40 PM
    PCRIDE4RUNNER
    SUPER DUPER
    Thanks. Another reason to do my own. I actually bought a T bar type wrench to get the drain plug out without torquing it to one side using breaker bar. Equally turning it.
  5. Apr 16, 2024 at 5:41 PM
    Texoma-Brad
    Texoma-Brad OK Yota
    Brad
    Texoma USA
    tk421, ziva, Yotaholic and 3 others like this.
  6. Apr 16, 2024 at 5:47 PM
    The real question is, HOW often do you change it? 1k, 3k, 5k or 10k miles? Let's start a REAL discussion (read: argument)!
  7. Apr 16, 2024 at 5:49 PM
    There are some oil filter wrenches out there that will engage on both the flats of the housing *and* the tabs molded into housing. Having good engagement on both helps with loosening them without breaking them. Napa has them. But if you don’t verify the wrench is fully seated over the ears, it can easily deform the flats.
    I’m a rebel and never change the washer on the pan drain plug. I just lap the face of the drain plug a by tightening and loosening it lightly a few times before final torque. My rebellious attitude on this point probably stems mostly from laziness, and the fact that I don’t feel like chiseling off the washer that came on it from the factory.
    It’s a straight forward normal oil change like most other cars. I’d say the skid plates are a pain in the ass, but it’s no different than other new toyotas. They all seem to have something covering things up. I changed the oil on a 22 highlander, and I had to remove way more crap.
  8. Apr 16, 2024 at 5:51 PM
    I put this together for my daughter. A tool user in training.
    MajinDan, Starkhaus, vthoky and 10 others like this.
  9. Apr 16, 2024 at 6:08 PM
    ColoradoTJ
    ColoradoTJ I drink...and I know things. Staff Member
    Chris
    I will probably always change my own oil until I can no longer physically do it. (Will have post lift in my next place). By then most everything will be electric anyway.
    4.0 is pretty straight forward and easy to do. As others said, do a Fumoto drain valve to make life easy.
  10. Apr 16, 2024 at 6:09 PM
    PCRIDE4RUNNER
    SUPER DUPER
    I’ve always sworn on Valvoline. After using it in two previous vehicles and driving to 250k with no issues the life of the vehicle. My current Toyota dealer where I’ve been going up to 60k miles, they have been using Valvoline/
  11. Apr 16, 2024 at 6:13 PM
    PCRIDE4RUNNER
    SUPER DUPER
    Very nice! I printed it out. Thanks!
  12. Apr 16, 2024 at 6:15 PM
    PCRIDE4RUNNER
    SUPER DUPER
    Yea I’ve never done the oil plug seal in past vehicles either. It’s overrated !
  13. Apr 16, 2024 at 6:25 PM
    steelevo
    Utah
    The process is pretty simple. With tire rotation, it takes me about 45-60 minutes to do the full service every 5k miles. It takes longer to drive to the dealer and back home.
  14. Apr 16, 2024 at 6:27 PM
    cbrake
    cbrake New Member
    Cliff
    2019 Silver 4Runner
    What process (jacks, stands, etc) do you use to rotate tires?
  15. Apr 16, 2024 at 6:48 PM
    java
    java fauxrunner
    2023 ORP ice cap
    RCI skid with filter door, and Fumoto. Motivx helps too. Mobil1 from costco, uder 30$ for 6qt when on sale.
    Yotaholic likes this.
  16. Apr 16, 2024 at 6:49 PM
    java
    java fauxrunner
    2023 ORP ice cap
    I have found a local garage that lets me rent a bay for 45$ an hr.
    RingSteel and VegasWon like this.
  17. Apr 16, 2024 at 7:04 PM
    1k oil changes and make sure to use impact on everything.
  18. Apr 16, 2024 at 7:14 PM
    Go Birds
    Go Birds New Member
    23 ORP
    I'm a bit conservative and believe in the wisdom of AMD, aka the Car Care Nut, on YouTube, a Toyota Master Tech. I use the manufacturer specified oil (0W-20, I personally use M1 EP) and change it at 5,000 miles or 6 months, whichever comes first. This also aligns with the 4Runner Warranty and Maintenance Guide which states 5,000 miles or 6 months for severe duty, which includes repeated short trips in cold weather, applicable to my 4Runner.
    Oil is cheap, and I like changing it.
    Static03, Yotaholic, Startrek and 2 others like this.
  19. Apr 16, 2024 at 7:24 PM
    I enjoy changing the oil too. But only if I can take my sweet time. Every time I do one and Im in a rush, it always seems to result in huge mess of sort lol.
  20. Apr 16, 2024 at 7:29 PM
    Go Birds
    Go Birds New Member
    23 ORP
    Wind is my worst enemy. I try to change oil only on days with wind under 5 mph, as I do it outside.
    Trail Runnah likes this.
  21. Apr 16, 2024 at 7:30 PM
    UncleShorty
    UncleShorty New Member
    You %$#@*...
    Go Birds likes this.
  22. Apr 16, 2024 at 7:36 PM
    Go Birds
    Go Birds New Member
    23 ORP
    I do it outside with a cheapazz Harbor Freight 3-ton floor jack. It helps to have a square piece of 2x4 to put on the jack and protect your frame. I tried a hockey puck, but it started shifting mid-pump and scared the hell out of me.
    It helps to have two sets of wheel/tires on hand, as you have a readily available placeholder while you place the shell game with the four on the truck. Otherwise, you can just drop the spare to be the placeholder.
  23. Apr 16, 2024 at 7:48 PM
    PCRIDE4RUNNER
    SUPER DUPER
    so $45.94 per oil change DIY. Dealer is advertising $57 happy hour 1-4PM. Additional time in disposing the oil, collecting it at the house.
    I suppose its still worth it and not having issues with Dealer screwing things up!
    Priced for 3 oil changes
    4 - 5quart Valvoline $26.97 = 107.88
    Oil plug seal $1 x 3 = $3.00
    Oil filter with seal $8.98 x3 = 26.94
    Total $137.82 / 3 = $45.94 - Per oil change
  24. Apr 16, 2024 at 7:51 PM
    Startrek
    Startrek New Member
    I cannot believe it. Please provide evidence that dealership using Valvoline oil. As I understand, Toyota dealerships contractually obligated to buy at bulk and use Exxon Mobile oil, and due to volume, at big discount.
  25. Apr 16, 2024 at 8:04 PM
    PCRIDE4RUNNER
    SUPER DUPER
    ah you're right, its 00279-0W201 which is the Toyota brand!! I guess with all the Valvoline flags and sticker I assumed the oil was also Valvoline.
    I do see them use Valvoline brake system oil for the flush I got a while back , part 608334 and Valvoline gear lube 75/90 for the Diff/Tcase - Documented as such on the service invoice.
  26. Apr 16, 2024 at 8:06 PM
    Go Birds
    Go Birds New Member
    23 ORP
    I'm willing to bet he can't get a dealer to provide evidence to a random internet poster to prove what oil they're using. I also bet you can't get Toyota to give you proof that their dealers are contractually obligated to use bulk XOM.
    I also bet that I won't bet more than $5, because I'm risk-averse.
    Acesandeights and akakaiser like this.
  27. Apr 16, 2024 at 8:18 PM
    Any off the shelf oil of the correct viscosity will work well so Valvoline it up.
    Bagman, 2ndGen22re and Trail Runnah like this.
  28. Apr 16, 2024 at 9:01 PM
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    Get an RCI skid plate and a Fumoto and you won't have to remove the skid plate. I go to Valvoline Instant Oil change though, I love their machine.
  29. Apr 16, 2024 at 9:03 PM
    Yotaholic
    Olympia, WA
    Buy it from the dealer, not Amazon.
  30. Apr 16, 2024 at 9:14 PM
    Yotaholic
    Olympia, WA
    Ha! Dealerships probably do a half and half, half your old oil and half the cheapest crap they can buy in bulk. And 16 year olds do the oil change. They can keep their free oil changes, I never went to them.
    MajinDan and Trail Runnah like this.
