Challenging question…
Discussion in '5th Gen 4Runners (2010-2024)' started by Sandbuster, Jan 19, 2022.
  1. Jan 19, 2022 at 9:18 AM
    Sandbuster
    Sandbuster [OP] Breaking Wind
    Central Florida
    2019 TRD Offroad
    .. for me it is. Does anyone happen to know what wire, in the back of OEM head unit for a 2019 4runner TRD-OR, is the video signal from the rear view camera?
    I’m working on a project to divert the rear view camera (along with an additional front camera) to a 8” Samsung tablet. If I can identify the correct circuit I think I’ve got enough other intel to make this work. If successfully completed I will post pics. Thanks in advance for any help rendered.
  2. Jan 19, 2022 at 10:52 AM
    This sounds interesting…:popcorn:
    suaveflooder and peter2772000 like this.
  3. Jan 19, 2022 at 11:03 AM
    Unfortunately I'm not exactly sure what this harness does but it may give you what you need.
    https://www.anytimebackupcamera.com/products/video-harness-24-wire-harness
  4. Jan 19, 2022 at 11:10 AM
    OverRunner
    OverRunner rebmeM weN
    Jared
    Denton, TX
    ‘21 ORP w/KDSS
    I’m pretty sure the harness made by @TundraTex does pretty much exactly what you’re looking for. As far as I can tell, it intercepts the video cable, and converts it to rca yellow so that a selector box can send it from either the front or rear camera to the yellow rca back into the head unit. I don’t see any reason you couldn’t use that port to send signal to the tablet instead of back to the factory head unit. That would also give you everything including a switch to install the front camera. Just a few minutes brainstorming about it though, I could be wrong.
  5. Jan 19, 2022 at 11:21 AM
    TundraTex
    TundraTex FRAC it!
    Lou
    2016 StormTrooper
    You are correct @OverRunner. The FRAC Harness is plug and play so you don't have to splice into any factory wiring. And just as you stated, the rear camera video is broken out to an RCA, and a second RCA input for a front camera is also provided. If for some reason a person wanted to display this on a tablet instead of the OEM Head Unit display, the FRAC output to the Head Unit is also an RCA connector so that could feed a video switch linked to the Tablet. Then you would just need the proper convertor to transition composite video to whatever format is required for the tablet.
  6. Jan 19, 2022 at 11:32 AM
    Sandbuster
    Central Florida
    2019 TRD Offroad
    You are guys are GREAT - that’s exactly what I need! Thank you.
  7. Jan 19, 2022 at 11:49 AM
    TundraTex
    TundraTex FRAC it!
    Lou
    2016 StormTrooper
    @Sandbuster check out www.FRACharness.com for more info if you are interested. I'll be happy to answer any additional questions you might have.
