Calling All Tire Wear Experts
Discussion in 'Wheels & Tires' started by Toyota.ARK, Jun 3, 2021.
  1. Jun 3, 2021 at 7:59 AM
    Toyota.ARK
    Toyota.ARK [OP] New Member
    2021 Magnetic Gray TRD-ORP
    Question:
    What would cause all 4 Wildpeaks to be clean on the outside edge after driving through a gravel easement? This has happened since they were new and they have 6K miles on them now.
    I understand it can’t be alignment since the rear is doing what the front is doing and the rear can’t be adjusted.
    I’m all ears! Please chime in.
    04B44A54-D83E-44EE-8340-83B538124641.jpg 8B5151FB-58C2-4CB5-A754-332E627DF074.jpg
  2. Jun 3, 2021 at 8:07 AM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    Ridiculously overinflated.
    OverRunner likes this.
  3. Jun 3, 2021 at 8:15 AM
    Toyota.ARK
    Won't overinflated tires result in a worn center?
  4. Jun 3, 2021 at 8:15 AM
    LandCruiser
    East Bay Area
    5th Gen OG TE
    You went through gravel.
    There’s no dust on the tire shoulders.
    The center IS wearing.
    a47chuck and OverRunner like this.
  5. Jun 3, 2021 at 8:37 AM
    doc4216
    doc4216 New Member
    Shannon
    The Land of Cle
    2015 SR5 Premium
    Dasaíta HU, Bilstein 5100s, AT Tires, Coveted grill lights
    Concur on the overinflated. That means only the center is touching, as previously stated.
    a47chuck likes this.
  6. Jun 3, 2021 at 8:46 AM
    I agree with above, over inflated.
  7. Jun 3, 2021 at 8:49 AM
    OverRunner
    OverRunner rebmeM weN
    Jared
    Denton, TX
    ‘21 ORP w/KDSS
    I recommend checking your air pressure. Also, check the far inside of the tire. It’s likely doing the same thing as the outside that the photo shows.
    As it overinflates, the center protrudes, as it’s not held back by the sidewalls. So, you’re riding on a much smaller patch of center tire, and your outsides aren’t making contact with the gravel below.
  8. Jun 3, 2021 at 9:06 AM
    Toyota.ARK
    w
    The inside is as dirty as the center, and only the outside is like this. I'm running at 36-37psi and if I air down to 32, the tire looks flat. I did notice that on hot days the tire psi goes up to 40-41. They fluctuate about 5-6psi on the dash monitor from cold to warm.
  9. Jun 3, 2021 at 9:16 AM
    OverRunner
    Jared
    Denton, TX
    ‘21 ORP w/KDSS
    In that case, I bow out. Probably not an alignment, doesn’t sound like psi, would be a strange occurrence to have four tires all have the same shorter outside edge manufacturing flaw.
    Last effort: I see there is water on the outside of the tire and the fender flare. Is it possible that that edge is simply getting rinsed off by the moisture falling from above? The gravel line on the tire isn’t exactly a straight edge.
    doc4216 likes this.
  10. Jun 3, 2021 at 10:23 AM
    Toyota.ARK
    [QUOTE="Last effort: I see there is water on the outside of the tire and the fender flare. Is it possible that that edge is simply getting rinsed off by the moisture falling from above? The gravel line on the tire isn’t exactly a straight edge.[/QUOTE]
    I thought that too, but it’s this way wet or dry when I drive over the easement to park. I can try to lower psi to 32-33 and see how it goes after warming up to 37-38.
  11. Jun 3, 2021 at 3:47 PM
    LandCruiser
    East Bay Area
    5th Gen OG TE
    I ran my Bridgestone Blizzaks at 38 psi and the centers turned bald after four seasons.
  12. Jun 3, 2021 at 4:10 PM
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    2016 4Runner TRD Pro, 2023 Tundra Platinum Hybrid
    Guys, I've done it. After years and years of us wondering what our tire pressure is supposed to be, chalk tests, discussions and arguments I've done it. I found the answer we've been questing for. This may be a bigger find than Pandora's Box or the Arc of the Covenant. Bestow your eyes upon all the answers you've been waiting for.
    Legend has it there's also a book containing what kind of oil we should use and how often it needs replacing.
    I'm still trying to crack the code if I can fit 33's with no lift however. I'll report back when I have more info.
  13. Jun 3, 2021 at 4:12 PM
    doc4216
    doc4216 New Member
    Shannon
    The Land of Cle
    2015 SR5 Premium
    ^ LOL. You win
    7385 and Thatbassguy like this.
  14. Jun 3, 2021 at 4:17 PM
    LandCruiser
    East Bay Area
    5th Gen OG TE
    I don’t even recall the last time I had stock size and load rating tires on my truck.
  15. Jun 3, 2021 at 4:26 PM
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    It was between 2010-2013.
  16. Jun 3, 2021 at 4:40 PM
    SYTY
    SYTY New Member
    THE ARM PIT OF AMERICA NY STATE THE ROTTEN APPLE
    The tire looks wet outer edge any pics dry close up?
  17. Jun 3, 2021 at 4:44 PM
    RSG sliders, Yakima Megawarrior basket, Black Rhino wheels, SOS Streamline bumper and skids, Warn VR EVO10S winch, OME MT64, Bilstein rear lift coils, Rigid Dually SS ditch lights, SR light bar, and Diode Dynamics SS3 fogs.
    What size and load range?
  18. Jun 3, 2021 at 5:51 PM
    Toyota.ARK
  19. Jun 3, 2021 at 5:53 PM
    Toyota.ARK
    I did lower the pressure to 35 and got a dirt strip on the outside tread!
    doc4216, mrmike7189 and Thatbassguy like this.
  20. Jun 3, 2021 at 5:59 PM
