Calling all 275/70/17 picks
Discussion in 'Wheels & Tires' started by Murdered out TRD PRO, Jun 30, 2017.
  1. Jun 30, 2017 at 10:29 AM
    Murdered out TRD PRO [OP] New Member
    2015 4Runner TRD PRO
    head rails attitude black, weather tech floor mats, weather tech rain visors.
    Its getting down to crunch time for a new pair of shoes and still not 100 on what size to cop.
    Strandskov likes this.
  2. Jun 30, 2017 at 11:46 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    That really depends on what kind of driving you're going to be doing. Do you need a street, all terrain, mud, snow tire or some combination of the four?
  3. Jun 30, 2017 at 3:14 PM
    PAULJJR2000
    PAULJJR2000 New Member
    PAUL
    2014 LIMITED AWD
    285/70R17 TOYO OPEN COUNTRY AT2'S, 17' RACE LINE IGNITION WHEELS, Toytec 3in front Spacer/leveling lift + 1.5 spacer in rear.
    LOVING my toyo at2's i just put on. i went with 285/70r17.
    Strandskov and 417tundra like this.
  4. Jun 30, 2017 at 4:09 PM
    I'm for sure looking all terrains.
  5. Jun 30, 2017 at 4:12 PM
    Do 275's look to small.. are 285 worth all modification trouble ?
  6. Jun 30, 2017 at 5:30 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Here's the differences between the stock 265/70/17, 275/70/17 and 285/70/17's.
    Width-
    265- 10.4"
    275- 10.8"
    285- 11.2"
    Height
    265- 31.6"
    275- 32.2"
    285- 32.7
    The 275's aren't going to look small because they're bigger than what you got (assuming you're running the stock TRD Pro Nitto's), but the difference between the two is negligible. We're talking less than a half an inch of width and barely over half an inch of height. The question you have to ask yourself is are you happy with the stock tire size? If you are, then you'll be happier with the 275's. If the 265's look small to you, the 275's aren't going to be the ticket either.
    As for trouble with mods with the 285's, its not really that big of deal. You gotta trim some fender/mudflap and may either have to modify the cab mounts (cutting, welding) or/and aftermarket UCA's to get the hub further away from the rear of the wheel well.
  7. Jun 30, 2017 at 5:59 PM
    Awesome thats big help man thanks for the info.
  8. Jun 30, 2017 at 7:36 PM
    DrewMan
    DrewMan 2016 4RTP-KDSS
    Middle Tennessee
    2016 Magnetic Grey 4Runner Trail Premium
    Bilstein 5100 Series Shocks, Daystar 1.5" Rear Coil Spacer (Mid Left), Level 8 Tracker Pros 17x9, 275/70/R17 B.F. Goodrich TKO's, N-Fab Nerf Steps
    Level 8 Tracker Pro 6's, LT275 /70 R17 B.F. GOODRICH ALL TERRAIN T/A KO2's
    ACM0302, Pure4Runner, jgcaps and 5 others like this.
  9. Feb 3, 2019 at 4:53 PM
    Dailey4Runner
    Dailey4Runner New Member
    Ryan
    2019 Trd Off Road
    @DrewMan solid set up! Are running any lift or level kit on this?? Any rubbing?
  10. Feb 3, 2019 at 5:28 PM
    Agent_Outside
    Built 2011 T4R Limited
  11. Feb 3, 2019 at 7:49 PM
    DrewMan
    Middle Tennessee
    Thanks, I’ve only replaced OEM shocks with Bilstein 5100 Series Shocks w/ Daystar 1.5" Rear Spacers… rubbing when backing up so did some minor trimming.
  12. Feb 4, 2019 at 8:18 PM
    redneckj
    redneckj New Member
    2018 TRD Off Road 4Runner
    working on it
    E load range?
    Backslider likes this.
  13. Feb 5, 2019 at 5:14 AM
    karmatp
    karmatp New Member
    Trevor
    2016 SR5 4x4
    No. 275’s are the largest I would personally go.
  14. Feb 5, 2019 at 5:23 AM
    rkwfxd
    rkwfxd New Member
    Rich
    Whittier - So Cal
    I had 31s on my Jeep TJ and then later 35s. I never regretted the larger tires. I added too much lift and a few other things that I regretted but never the larger tires. When I am ready replace my tires I will go with 285s but I will keep my lift in check at about 2" max.
    Strandskov and jgcaps like this.
  15. Feb 5, 2019 at 6:15 AM
    jgcaps
    jgcaps Lovin the Colorado Life.!
    CO
    2018 MGM TRD ORP KDSS 4Runner
    3" Icon Stage 2, 18x9 Fuel Beast wheels, 285/65/18 BFG KO2's, N-FAB Black Rock Rails w/removable steps.
    lookin good.!
  16. Feb 5, 2019 at 6:16 AM
    jgcaps
    CO
    sweet.!
    Strandskov and Backslider like this.
