Burning smell?
Discussion in '5th Gen 4Runners (2010-2024)' started by COexplorer, Nov 27, 2017.
Are you getting a burning smell from the rear wheelwells?
  1. Yes
    37.5%
  2. No
    62.5%
  1. Nov 27, 2017 at 5:27 PM
    COexplorer
    COexplorer [OP] New Member
    Graham
    2018 TRD Off Road
    Anyone else get the burning rubber smell from the rear wheelwells? At first I figured it was some sort of coating burning off the exhaust, but now with about 2000 miles I am starting to doubt that.
    I researched a bit and I cannot find an concensous on the cause, but it seems to be a common issue. Most commonly people seem to think it is the muffler. Can anyone with an aftermarket exhaust speak to whether or not that fixed the issue?
    Thanks for any input.
  2. Nov 27, 2017 at 6:22 PM
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    2017 T4R Pro 040
    Is plasti-dip a mod?!
    No burning rubber smell here. It took a couple hundred miles for the cats to break in, they were a little stinky at first. Maybe crawl up under it and see if an exhaust hangar is broken and the rubber hangar thingy is melted? I just fluid filmed my runner so I have a different kind of stink going on right now,lol.
  3. Nov 28, 2017 at 8:20 AM
    jester243
    Dan
    Spokane, WA
    I had some weird smells for the first maybe up to 1,000 miles as everything broke in but nothing past that point. I have had in the past a plastic bag get caught underneath and caused a smell, maybe check that. :notsure:
    BassAckwards likes this.
  4. Dec 13, 2017 at 5:45 AM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    I also had this smell and I read about this before I purchased my 2016 SR5. when drive on hywy speed then stopped I would smell a rubber burn smell..crawled under and I felt that the rubber exhaust supports were up on the pipe /muffler. so I moved these away from the hot parts. problem reduced a lot and now no smell.
    the other item I recommend is put an extension on the tail pipe as IMO too short could damage the rear plastic bumper / paint from heat and exhaust .
  5. Dec 13, 2017 at 8:16 AM
    COexplorer
    Graham
    2018 TRD Off Road
    I thought about the rubber exhaust hangers as well, but they did not look like they were burning at all to me. My truck is at the dealership right now and I asked them to take a look at it. I will post back if they find anything.
    Tacoblue17 likes this.
  6. Dec 13, 2017 at 12:14 PM
    j cat
    j cat New Member
    massachusetts
    not burning but they get hot and then they smell .. not like they got torched ..
    I got my 2016 in july so hot out added to it so I knew it would do this burn smell as IT IS well known .. rubber is soft also.
