Build List: 35s IFS 96 4Runner
Discussion in '3rd Gen Builds (1996-2002)' started by t4rlady, Feb 15, 2024.
  1. Feb 15, 2024 at 4:01 PM
    t4rlady
    t4rlady [OP] New Member
    Nat
    1996 Toyota 4Runner
    Here is my build list for my 96 4Runner! Instagram is @t4rlady and I listed all discount codes I have for products!
    Full build walk around is on Youtube.
    1996 Toyota 4Runner SR5 5-speed manual transmission with a factory rear locker and factory 4.10 gears.
    Tires:
    Falken Wildpeak AT3W 315/75/16
    On road: front 28 psi & rear 25 psi
    Off road: front 10 psi & rear 8 psi
    Wheels:
    Toyota Factory 3rd gen 4runner limited 5 spoke wheels spray painted grey
    Spidertrax 1.25” hub centric blue spacers
    Front suspension:
    Toytec Lifts Boss 2.0 Front Aluma series coilovers set at 3’ of lift (600 lb spring rate)
    Specialty Products Company upper control arms
    Toytec Lifts front differential 1” drop spacers kit
    Rear suspension:
    Toytec lifts Rear 3-Inch Lift Coil Springs spray painted black
    1” coil spring spacer
    Bilstein 5th Gen 4Runner 1” lift shocks
    Toytec Lifts rear extended bumpstops
    Armour:
    Western Ascent Fabrication custom rear bumper with a single swing out tire carrier
    Western Ascent Fabrication custom sliders with kick out
    Lighting:
    SRQFabrications 3rd gen 4Runner filler plate turn signals
    Vivid Lumen FNG5s pair with amber and clear combo lenses (on front bumper) - discount code T4RLADY10 for 10% off
    Vivid Lumen Led FNG SAE amber driving pods (on front as fog lights) - discount code T4RLADY10 for 10% off
    Vivid Lumen Led FNG Intense Standard Amber pod wide floods (on rear bumper) - discount code T4RLADY10 for 10% off
    TEQCustoms retrofit headlights (Turbine shroud, front and rear RGB halos, LED projectors)
    Audio:
    Kenwood excelon dpx794bh deck
    Diamond Audio front and rear speakers
    Diamond Audio amp
    Rockford Fosgate P2 Punch 8 inch subwoofer built into the bed platform
    Cargo:
    Rear seats removed
    Solid Wood Worx sleeping platform and full sized mattress on top
    Air system:
    Trailhead automatic tire deflators in blue
    Up Down Air air compressor
    Princess Auto air hose
    Western Ascent Fabrication custom box holding all air up supplies
    Little things:
    Exedy clutch
    Western Ascent Fabrication cup holders + phone holders
    Honda odyssey washer nozzles
    Teal painted front Toyota emblem
    Teal painted tundra brake calipers
    Black painted and trimmed front bumper
    SPScoatings graphene coating over the paint and windows - discount code t4rlady10 for 10% off
    Princess Auto dual airhorns
    Princess Auto 6ft awning
    Next up dual axle SAS onto landcrusier 80 series axles and 37s!
    Han4Run and SR5 Limited like this.
  2. Feb 15, 2024 at 4:55 PM
    You go girl, very nice setup also, and welcome to the forum.
    t4rlady[OP] likes this.
  3. Feb 16, 2024 at 6:09 AM
    Great year!
  4. Feb 16, 2024 at 6:37 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Welcome. I've seen your build on insta.
  5. Feb 16, 2024 at 9:52 AM
    steelevo
    Utah
  6. Feb 16, 2024 at 12:00 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Did you and your SO start company to to try to make some money on a YouTube channel but also have modding your 4runner be a tax write off?
