Bucking at low speed after warm-up
Discussion in '3rd Gen 4Runners (1996-2002)' started by dkm3033, Jan 10, 2020.
  1. Jan 10, 2020 at 7:27 AM
    dkm3033
    dkm3033 [OP] New Member
    2000 Silver 4Runner
    I have a 2000 4Runner with 427,000 + miles original engine and trans. It bucks in 2nd & 3rd gear. Not as bad at higher speeds, but can tell during deceleration/acceleration. Engine light sometimes, but doesn't last long. Any ideas?
    dkm
  2. Jan 10, 2020 at 7:31 AM
    4scooter19
    4scooter19 New Member
    Oregon
    98 and 86 4Runners
    Scan for codes
  3. Jan 10, 2020 at 7:46 AM
    dkm3033
    2000 Silver 4Runner
    Thanks. I will scan once the light comes on again.
  4. Jan 10, 2020 at 7:54 AM
    4scooter19
    Oregon
    98 and 86 4Runners
    Codes should be stored. Take it to AutoZone and have them pull codes if you don't have a scan tool.
  5. Jan 10, 2020 at 8:17 AM
    only bucks during acceleration/deceleration?
  6. Jan 10, 2020 at 1:33 PM
    captsolo
    captsolo New Member
    Tom
    nassau bahamas
    2005 SR5
    Start by changing the plugs
    Plug it into a good scan tool. That will find the codes and you will solve the problem without "throwing more parts" at it.
  7. Jan 10, 2020 at 10:48 PM
    Welcome and congrats on surpassing the 400k milestone. Hoping to do the same in the next couple years. I second plugs, but do the three coils and three plug wires if it hasn’t been done. OEM will run a few hundred but worth it. I also change two quarts of trans fluid when I do an oil change...
  8. Jan 13, 2020 at 8:26 AM
    I disagree on the coils. They run fine forever. You can also diagnose them fairly easily.
    Plugs and wires. And TOYOTA only plugs and wires.
  9. Feb 7, 2020 at 11:54 AM
    jross20
    jross20 New Member
    Transmission flush with good oem style fluid
    Benny123 likes this.
  10. Feb 7, 2020 at 12:32 PM
    Benny123
    Benny123 Toyota enthusiast
    Southeast Charlotte, NC
    2016 Nautical Blue SR5 Premium
    LEDs all around, otherwise bone stock.
    Check the colors of rad and tranny fluids. Have you changed your radiator at any point? Pink milkshake is a known issue if the two mix.
  11. Mar 3, 2020 at 8:32 AM
    plcfcng
    plcfcng New Member
    2001 SR5
    I had the same condition 6 months ago in my 2001 3.4 2wd. For me the problem was my Cat converter. If you want to check for this condition buy or rent a VAC gauge (they are pretty cheap or rent at Auto Zone or Orelleys) plug it into Manifold vac. Start the 4runner let come to a idle if it reads low VAC them most likely your CAT has gone bad. I chased this condition for about 2 months. To confirm the condtion you can remove the front 02 sensor and drive it a short distance and see if the condition goes away. This means exhaust is plugged some where most likely the CAT. A muffler shop can inspect for I think 25 dollars or so. If this is not it well you have eliminated one thing good luck.
