brake rotors
Discussion in '3rd Gen 4Runners (1996-2002)' started by rangerrunner, Sep 26, 2015.
  1. Sep 26, 2015 at 10:34 PM
    rangerrunner
    rangerrunner [OP] New Member
    Charlie
    Need some advice on rotor upgrades for my 2000 4runner, rotors are warped.
    Was looking at some slotted and drilled ones, not sure what brand to go with.
  2. Oct 5, 2015 at 1:14 PM
    RussToy
    RussToy New Member
    Russel Lee
    Granville Ohio
    2000 4Runner SR5
    A Work in Progress
    Hello Sir, here's a link that will explain how you can use Toyota Tundra brakes...complete bolt on using all Toyota parts if you want. You can do this for less than $400. You'll never have any brake problems again...stop on a dime and be able to give a nickel back in change...lol!! There's several place that sell "Big Brake Kit" for us. Here the 1st one I found...
    http://eastcoastgearsupply.com/i-17...04-4runner-96-02-upgraded-disc-brake-kit.html
    Enjoy your reading. And good luck...
    - Russel
  3. Oct 18, 2015 at 8:35 PM
    tbird
    tbird New Member
    Randy
    1999 4runner limited
    Tundra front brakes 17 inch wheels and after market radio
    Hey I just did the mod on a 1999 limited. Got the parts from 2005 tundra at a pick and pull yard. Had the rotors turned for 30bucks and put reybestos ceramic pads on. I used my bolts to mount the calipers because the tundra bolts were about an 1/8 " longer and would bind a little before bottoming out. Just follow the the mod in the posting. Got 70 bucks in the deal and the brakes are great. And if your fluid is needing changed this is a perfect time. After assembling everything I just started with the furthest wheel from the master cylinder and worked my way forward. Takes a while to gravity bleed the whole system but thats what I did. Used some vaccum line and a clear plastic catch bottle. When you see clear fluid collecting in the plastic bottle you good with that wheel. Don't let the master cylinder run dry or you'll have to start over. just buy a quart can of dot 2/3 and go for it.
  4. Oct 19, 2015 at 12:59 AM
    RussToy
    RussToy New Member
    Russel Lee
    Granville Ohio
    2000 4Runner SR5
    A Work in Progress
    Great job on your conversion. That awesome you were able to get all your parts at a pick-in-pull (wrecken/junkyard) for only $70. I wish we had one around here! Frik'in super awesome price for your parts...a lot better than $400. That's great you were able to use your old bolts to attach the Tundra's calipers. I haven't read anyone having that problem yet...have you? Quick thinking...and great job.
    Since your swap...how's your 4Runner stopping now?? I'm sure way better. That was a smart heads up...changing out our 16-17 year old brake fluid...I'm sure just having fresh clean brake fluid in the system probably made a difference. Did you have any other problems except the caliper bolt issue?
    Thanks for sharing...
    - Russel
  5. Oct 20, 2015 at 1:14 PM
    tbird
    tbird New Member
    Randy
    No other problems except I cut a little too much of the shield when I did the mod and I did use my old bolts. Brakes are great. Just took it on the first long trip to ocracoke island N.C. and it was great on the beach.
    Husky Driver likes this.
  6. Oct 21, 2015 at 3:34 AM
    RussToy
    RussToy New Member
    Russel Lee
    Granville Ohio
    2000 4Runner SR5
    A Work in Progress
    This is definitely a mod I wanting to do then!! @tbird did you get the PM I sent you?
    Thanks
    - Russel
  7. Jan 19, 2016 at 10:50 PM
    rangerrunner
    Charlie
    Well I know its been awhile...reason I switched rotors was i had vibrations when braking.
    I ended up putting EBC slotted and drilled rotors on.
    Worked great...then after a 3000 mile trip through Montana this winter the vibrations came back.
    Had a quick (free) inspection from Les Schwab and they said it was the rear brakes..
    So a quick trip to O'reilly Auto Parts...i replaced...
    -drums
    -pads
    -hardware
    -wheel cylinders
    So nowwww i still have vibrations and pretty sure i screwed up the bleed...
    any advice? could it be wheel bearings? or ball joint?
    im currently rocking 235,000 miles (purchased with 218,000)
  8. Jan 20, 2016 at 4:56 AM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    2007 4runner SR5 4WD
    Is the vibration only during braking?
  9. Jan 21, 2016 at 5:52 AM
    rangerrunner
    Charlie
    Yes, only during braking and it seems to be coming from the front and you can feel it in the steering wheel a bit
