Brake Replacement Parts List- 5th Gen
Discussion in '5th Gen 4Runners (2010-2024)' started by Gripster, Oct 19, 2023.
  1. Aug 7, 2025 at 12:11 PM
    Greg D
    Greg D TJ312
    TJ312
    2013 4runner
    These are the best 4runner brakes to date compared to older. My rear pads wear out about 2/1 compared to the front. I got a hardware kit from Rockauto for $6 with 2 springs, etc. per front caliper, greased pins and pads good and no more occasional squeal in the morning.
  2. Mar 2, 2026 at 5:23 AM
    mrt6644
    mrt6644 New Member
    2015 Trail Edition
    this is great info. I’ve been researching the parts list here and there and it’s confusing as to what and how may of each are necessary.
    Your list matches most of mine except the brake pad part number. Mine is a 2020 so not sure if they changed that.
    Thanks for the great info
    Guppy1301 likes this.
  3. Mar 2, 2026 at 5:54 AM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    Brake pad part #'s are correct. Don't buy pads with -AZ in the part#. Those are the economy pads. I just did a brake job recently with the part #'s specifically from this list.
  4. Mar 2, 2026 at 6:26 AM
    Snow Packed
    Snow Packed New Member
    That’s a great list to work with. I’ll always go with Toyota factory parts over any other when possible, but getting the small part numbers packaged is difficult looking at the items online. Parts departments often don’t want to help so it’s even more difficult to find.
  5. Mar 5, 2026 at 3:43 PM
    Grug556
    Grug556 New Member
    Kings, Crestone Rack, Baja S8, Baja Fogs, Baja XL80s, Baja mini cubes, SPOD, ARB compressor, RCI full skids, ROAM box and stuff. ST Pros. Shrockworks sliders... GOAT armour
    Akebono or nothing. While youre at it, consider changing out rear soft lines as they are cheap and help firm up the pedal.
  6. Mar 5, 2026 at 4:00 PM
    Charlievee
    Charlievee Not new member.
    Old thread but my experience is the toyota brake assist will lock up your brakes. Did this by accident just trying to scrub spead while rolling to a red light. Apparently i moved my foot from the gas to the brake peddle to fast, everything not tied down flew to the front and i was at a dead stop 200 feet from the intersection. I then pondered how the ABS locked all four tires and my research pointed to the brake assist.
  7. Mar 6, 2026 at 12:40 PM
    harsh
    harsh New Member
    Harsh
    2016 Limited 4Runner
    Is there any way to improve the pedal feel?
  8. Mar 6, 2026 at 1:23 PM
    Grug556
    Grug556 New Member
    yes better pads, maybe swap fluid, new rotors, but also the final one that did it for me with substantial improvement was changing rear lines.
    I added this
    Powerstop drilled and slotted rotors all 4 corners
    Akebono pads all corners
    New Toyota Brand DOT3
    New rear centric brake lines
    New sliders and basic hardware
    This made the car feel like my old Audi, nice and tight and progressive brake feel. No stupid mushy dead zone where nothing happens followed by soft grab. Akebono pads dont require a break in period either just put them on and go.
    harsh[QUOTED] likes this.
  9. Mar 6, 2026 at 1:51 PM
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
    Advics is good too. Many original Toyota brake parts are by Advics.
    Grug556[QUOTED] likes this.
  10. Mar 6, 2026 at 2:03 PM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    ADVICS is owned by Aisin which is partly owned by Toyota.
    ADVICS was established as a joint venture between Aisin, Denso, Sumitomo, and Toyota.
    4onto[QUOTED] likes this.
  11. Mar 6, 2026 at 2:11 PM
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
    I have a pair of Advics front rotors waiting to go on my Tacoma (same 319 mm rotors as the 4Runner) and the boxes do say Aisin as well.
    AuSeeker[QUOTED] likes this.
