BRAKE LIGHT,ABS AND VSC LIGHT ON IN MY 05 4 RUNNER
Discussion in '4th Gen 4Runners (2003-2009)' started by jollygal2005, Jun 29, 2021.
  1. Jun 29, 2021 at 9:22 AM
    jollygal2005
    jollygal2005 [OP] New Member
    Sherri
    05 4 ruuner
    Started it this morning and brake light,VSC and ABS lights all stayed on - emergency brake not on and brake fluid fine- drove a couple of minutes and light went off then about a mile down the road they came on again- stopped, turned engine off and re-started - got about 3-4 miles and came on again- any ideas whats causing this?
  2. Jun 29, 2021 at 11:01 AM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    Check your gas cap. Make sure it is tight.
  3. Jun 29, 2021 at 1:08 PM
    jollygal2005
    Sherri
    05 4 ruuner
    Thank you - Im sure its a quirk of some kind- it seems to be running just fine but I will check the gas cap
  4. Aug 1, 2021 at 6:03 PM
    CobraSC
    CobraSC New Member
    2006 4Runner
    Freedom OffRoad adjustable struts, UCA's, rear springs, 33x12.50 on XD 18x9's
    I have the same issue. Gauges look like a chistmas tree with all the warning lights lit but everything works fine.
    At some point I will have to do some research
  5. Aug 1, 2021 at 10:37 PM
    sergie
    sergie New Member
    2003 silver 4runner
    It happened to my 2003 4R,Check engine, VSC and ABS light always comes and go, went to the dealer and they did a zero calibration still the same, lights comes and go, I asked a mechanic in a small auto shop and he told me to change the gas cap, went to the dealer bought a gas cap for less than $30.00 and since then lights has not come back. I was not charged by the dealer for calibration because they did not fixed the problem.
  6. Jan 21, 2024 at 7:28 AM
    erfer1
    erfer1 New Member
    Eric
    SW NM
    2019 Limited
    Sounds like Toyotas' version of the 3 Amigos.
