Brake Assist (EBD) Issue
Discussion in '4th Gen 4Runners (2003-2009)' started by kaidoy888, Nov 16, 2022.
  1. Nov 16, 2022 at 9:28 AM
    kaidoy888
    kaidoy888 [OP] New Member
    Richie
    2005 SR5
    18" AR Rims, LED lighting all around.
    2005 SR5, 4WD.
    I recently upgraded my front brakes to 13.3" rotors, so I replaced the dust shields, rotors and calipers and manually bled the brakes. No problem braking, but the skid light, VSC OFF, VSC TRAC, and ABS lights came on. I did a Zero Point Calibration and an ABS light reset, and while I have no dash lights up, the brake assist randomly kicks in when braking, either lightly or firmly. My mechanic used and ABS reader and didn't find any issues or codes. Real-time wheel speed is okay, so no sensor or sensor ring issues. Had to disconnect the fron ABS sensors to deliberately fail the sysytem so I can stop normally.I can't find anything online about the barake assist, a.k.a. Electronic Brakeforce Distribution or EBD. Anyone else have this issue?
  2. Feb 15, 2024 at 6:37 PM
    Baklao
    Baklao New Member
    I have this same issue on a 2007 Toyota Rav4. Been trying to find a solution for about 2 months now. Did you find a fix for this? I feel like I tried everything and can't fix this problem. I feel like there most some other calibration that I don't know about.
