BODY ROLL
Discussion in '4th Gen 4Runners (2003-2009)' started by grumpy 02, Jun 5, 2024.
  1. Jun 5, 2024 at 6:05 AM
    grumpy 02
    grumpy 02 [OP] New Member
    Stan
    Colorado Springs, CO
    2007 White 4Runner SR5
    None Yet
    2007 SR5, V6. 4WD, 212,xxx miles. I have what I consider excessive body roll. Any "quick" steering input & it feels "soft" initially but then firms up. It has had the following done within the last 5K miles: coilovers, front swaybar bushings/links, front wheel bearings, front brakes, rear shocks, rear swaybar bushings/links replaced. Any thoughts on what I might try?
  2. Jun 5, 2024 at 6:14 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    What spring rate coils are you running?
    Any added weight?
  3. Jun 5, 2024 at 7:20 AM
    grumpy 02
    Stan
    None Yet
    Don't know the spring rate. 2022 Tacoma TRD take offs. RCI engine & trans skid plates.
  4. Jun 5, 2024 at 7:29 AM
    1SilverRunner
    Tejas
    What coilovers are you running
  5. Jun 5, 2024 at 9:36 AM
    grumpy 02
    Stan
    None Yet
    2022 Tacoma TRD take offs. That's all I know about them.
  6. Jun 13, 2024 at 8:14 PM
    LOSTR4
    LOSTR4 New Member
    Just a couple
    Do you still have your rear sway bar connected?
  7. Jun 21, 2024 at 6:53 AM
    grumpy 02
    Stan
    None Yet
    Yes.
  8. Jun 21, 2024 at 7:45 AM
    LOSTR4
    LOSTR4 New Member
    Just a couple
    Have you looked at the bushing on the RSB linkages? I ask as I myself had one side "good" and the other side was gone, cracked, and not connected and it made noise as well as made the body roll more noticeable than not having the RSB even connected...just another spot to check out I suppose. Could be your springs/shocks need rebuilding/swapped too...
  9. Jun 21, 2024 at 9:14 AM
    grumpy 02
    Stan
    None Yet
    Replaced the links & RSB bushings. Shocks have < 4K miles front & rear.
  10. Jun 21, 2024 at 9:27 AM
    LOSTR4
    LOSTR4 New Member
    Just a couple
    Dang! Have you swapped with an OEM replacement or did you "update" to say a Bilstein 4600 et Al? Do you have XREAS by chance on your 4runner? With all you have replaced, it should feel tight and right!
  11. Jun 21, 2024 at 11:34 AM
    grumpy 02
    Stan
    None Yet
    All covered in the OP.
    LOSTR4 likes this.
  12. Jun 21, 2024 at 11:48 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Unless I missed it, I don't see front shocks on that list. How many miles on those?
  13. Jun 21, 2024 at 12:27 PM
    backpacker
    2023 TRD ORP
    Yeah, I interpreted it as just springs. If it was the whole assembly, I still note that they were Tacoma takeoffs, so I wonder how many miles. Also, wasn't there a thread in the last couple month where somebody discussed the characteristics of Tacoma coilovers relative to the 4R?
  14. Jun 22, 2024 at 6:43 AM
    grumpy 02
    Stan
    None Yet
    Just to clarify. Shocks (front & rear) came off a 2022 (I think) Tacoma TRD. Had ~ 4K miles on them when I got them. Now ~ 7K as I just returned from a trip to Victoria, BC. Sway Bar bushings & end links (front & rear) are new as of ~3K ago. On the trip just finished, on roads where there is an undulation in the surface on a curve, the "body roll' is quite pronounced. Not uncontrollable, but pretty bad. My plan is to weigh the truck, front axle, rear axle & total w/ full gas tank & normal "stuff". Measure from ground to fender lip on all four corners on a level surface. Then provide that info to ToyTech or some other Pros & see what they recommend for springs. Good Idea?
    MI-FL off roader likes this.
  15. Jun 22, 2024 at 7:02 AM
    LOSTR4
    LOSTR4 New Member
    Just a couple
    That's a good plan, also, do you have a rack that have been loaded? New springs built for a 4runner to fit the new shocks will greatly help!
  16. Jun 22, 2024 at 7:50 AM
    backpacker
    2023 TRD ORP
    Sounds reasonable.
